[SOLVED]Serviio not showing ".ts" files Recorded TV From PVR
hexeta
Post Wed Feb 22, 2012 10:46 am
As Requested, I've opened a new thread for this problem.
It is the same problem that I experienced with the previous version of Serviio, and it was solved in the linked thread.
viewtopic.php?f=11&t=2492&start=20
In that thread, you offered two edits to the "profile.xml" file, the first didn't work, so I have not tried it on this version.
The second edit worked on the first version of Serviio, but hasn't worked on this one.
Cerberus recommended that I should ask Illico, since he is the expert on Sony products, hence the pm, sorry if this was not the correct way to contact you. :(
Just turned on the TV and run the gauntlet of "Daytime Television" :shock: and behold, Serviio is performing perfectly!
I wasn't aware that the PC/TV (one or the other, or maybe both) needed to be re-booted for the edit to take effect. :roll:
Sorry ! :oops:
Post Wed Feb 22, 2012 1:43 pm
Re: Serviio ver: 0.6.2 not showing ".ts" files
hexeta wrote:Just turned on the TV and run the gauntlet of "Daytime Television" :shock: and behold, Serviio is performing perfectly!
Sorry ! :oops:
Yes, when the profiles.xml was edited, you need to restart the serviio services, for modification to be taken into account.
- Select "Stop Serviio Service" and "Start SErviio Service" on windows start program menu.
or
- Restart your PC.
So the solution for your issue is:
<Video targetContainer="mpegts" targetVCodec="mpeg2video" maxVBitrate="17000" targetACodec="ac3" aBitrate="192">
<Matches container="asf" />
<Matches container="avi" />
<Matches container="mp4" />
<Matches container="flv" />
<Matches container="wtv" />
<Matches container="mpegts" aCodec="mp2" />
Confirm?
hexeta
Post Wed Feb 22, 2012 2:59 pm
Illico wrote:Yes, when the profiles.xml was edited, you need to restart the serviio services, for modification to be taken into account.
or
- Restart your PC.
Confirm?
Yes, the above edit was ultimately successful.
I did stop Serviio prior to editing the "profiles.xml" file, but when Serviio was re-started, the edit seemed not to have had any effect.
Only after the TV and PC were re started this morning did I discover that the edit was indeed sucessful.
Could it be that the PC needs to be re-booted after the edit, rather than just re-starting Serviio? :?
Post Wed Feb 22, 2012 4:10 pm
hexeta wrote:Could it be that the PC needs to be re-booted after the edit, rather than just re-starting Serviio? :?
yep
hexeta
Post Wed Feb 22, 2012 4:14 pm
Sorted!! :mrgreen:
Post Wed Feb 22, 2012 4:25 pm
yep
No, its a bug. Restarting serviio service must do the job !
hexeta
Post Wed Feb 22, 2012 4:30 pm
Illico wrote:No, its a bug. Restarting serviio service must do the job !
So what do I do?
It seems to be working OK, should I expect problems?
Post Wed Feb 22, 2012 5:16 pm
Illico wrote:
yep
Nah it the old problem that people are not restart service properly.
hexeta
Post Wed Feb 22, 2012 5:50 pm
Cerberus wrote:Nah it the old problem that people are not restart service properly.
:shock: I think I stopped and re-started serviio from the console! :oops:
Post Wed Feb 22, 2012 6:21 pm
OK, on console you only stop and start the server part of serviio...but not the serviio services !! (Its not clear I know...)
On Windows Start Program Menu, select Serviio --> Stop Serviio Service and Star Serviio Service.
hexeta
Post Wed Feb 22, 2012 6:25 pm
Illico wrote:OK, on console you only stop and start the server part of serviio...but not the serviio services !! (Its not clear I know...)
I'll try and remember that for future, thanks.
kappclark
Post Wed Feb 22, 2012 8:54 pm
Does this change affect the Sony N200 ?
I have not done any editing to the Sony profile - should I do that, or is there a new profile.xml that needs to be downloaded..
Post Wed Feb 22, 2012 9:29 pm
kappclark wrote:Does this change affect the Sony N200 ?
no this is just an edit to solve a specific users files.
phn2
Post Mon Mar 05, 2012 9:49 pm
Re: [SOLVED]Serviio not showing ".ts" files Recorded TV From
Having the same problem, cant play .ts files on Sony Hx800 tv. Somehow it plays .ts files thats recorded in hd, but choppy and no sound, but sd .ts files wont start at all, se log below
best regards, Per.
Edit: the files will play nicely via serviio>ps3
2012-03-05 21:41:45,215 INFO [LibraryAdditionsCheckerThread] Finished looking for newly added files
2012-03-05 21:41:45,245 INFO [LibraryUpdatesCheckerThread] Finished looking for updates to currently shared files
2012-03-05 21:41:46,746 INFO [LibraryAdditionsCheckerThread] Started looking for newly added files
2012-03-05 21:41:46,746 INFO [LibraryUpdatesCheckerThread] Started looking for updates to currently shared files
2012-03-05 21:42:19,845 WARN [LibraryManager] Cannot read metadata of file /media/MUSIK/Turboweekend/Ghost of a Chance/06 - Up with the Smoke - Down with the Ash.flac via extractor EMBEDDED. Message: org.jaudiotagger.audio.exceptions.CannotReadException: Unable to read file because it is too small to be valid audio file: /media/MUSIK/Turboweekend/Ghost of a Chance/06 - Up with the Smoke - Down with the Ash.flac
2012-03-05 21:42:24,344 WARN [ProcessExecutor] Process ffmpeg has a return code of 1! This is a possible error.
2012-03-05 21:42:31,817 ERROR [ResourceTransportRequestHandler] Error while processing resource, sending back 500 error. Message: Transcoded file '/tmp/Serviio/transcoding-temp-6892-MPEG2PS.stf' cannot be found, FFmpeg execution probably failed
java.io.IOException: Transcoded file '/tmp/Serviio/transcoding-temp-6892-MPEG2PS.stf' cannot be found, FFmpeg execution probably failed
at org.serviio.delivery.resource.transcode.FileBasedTranscodingDeliveryStrategy.createInputStream(FileBasedTranscodingDeliveryStrategy.java:45)
at org.serviio.delivery.resource.transcode.AbstractTranscodingDeliveryEngine.retrieveTranscodedResource(AbstractTranscodingDeliveryEngine.java:129)
at org.serviio.delivery.resource.AbstractDeliveryEngine.deliver(AbstractDeliveryEngine.java:96)
at org.serviio.delivery.MediaResourceRetrievalStrategy.retrieveResource(MediaResourceRetrievalStrategy.java:121)
at org.serviio.upnp.webserver.ResourceTransportRequestHandler.handleRequest(ResourceTransportRequestHandler.java:116)
2012-03-05 21:44:18,914 WARN [VideoExtractionStrategy] Cannot find a valid timestamp in the transport stream packet, setting it to NONE
2012-03-05 21:44:35,979 WARN [OnlineVideoSourcesMetadataExtractor] Online metadata search returned no results for file Braveheart2.ts [VideoDescription [type=FILM, names=[braveheart2, braveheart pvr], year=null, season=null, episode=null]]
2012-03-05 21:44:38,130 INFO [LibraryAdditionsCheckerThread] Added file 'Braveheart2.ts' (title: Braveheart2) to Library
Post Wed Mar 07, 2012 8:37 am
Do you read the Sony FAQ (2011, 2010, wiki):
Q: I can see the file on my TV and has a thumbnail picture, but when I try to play the file I get an error "The server is Temporarily unavailable". Serviio log : ERROR [ResourceTransportRequestHandler] Error while processing resource, sending back 500 error. Message: FFmpeg execution failed java.io.IOException: FFmpeg execution failed
A: Turn on detailed logging (see link) you should be able to see the FFmpeg command that is used for the transcode. Try executing the command manually in a terminal window and post the (error) result here.
Users browsing this forum: Bing [Bot] and 3 guests
