UE40D5500 AllShare over wired LAN Ethernet not working ...
MasterT
Post Fri Mar 09, 2012 10:38 am
I have a Samsung UE40D5500 which has only LAN port, and no build in wireless adaptor.
I connected it to my home network by wire. Tv is working fine on intenet. But AllShare application installed in my computer refuses to detect the TV on the network. Same is happening with Serviio.
I called Samsung and they told me AllShare is only working on wireless connection, which doesn't seem to be right, after all a network is a network, unless they limited AllShare functionality to wireless network by software.
I want to add that I disabled firewall in my computer and in the router, I also disabled antivirus. I set up the TV and computer with a fixed IP adress in the router. If I ping Tv's IP it replies but still ...
Has anyone of you managed to get these D series Samsung TV's to work on wired LAN?
Thank you.
Post Fri Mar 09, 2012 1:25 pm
Re: UE40D5500 AllShare over wired LAN Ethernet not working .
Wow, what a customer support.. only wireless? :-D
Make sure serviio binds to the proper IP address. You can also send detailed log.
MasterT
Post Fri Mar 09, 2012 9:15 pm
Where can i found log?
Searching on samsung site about this problem I found this:
*To use Samsung’s AllShare feature, a Samsung Wireless LAN Adaptor is required if your TV does not have WI-FI inbuilt. Samsung takes copyright seriously. Samsung’s AllShare feature is intended only for private and domestic use by a person. Any other use of Samsung’s AllShare feature may be contrary to the law, including copyright law. Samsung does not authorise, sanction, approve or contenance any use of its AllShare feature that infringes copyright or is otherwise contrary to law. Samsung LED TV’s utilise LCD screens with LED edge lights.
MasterT
Post Sat Mar 10, 2012 9:37 am
2012-03-10 10:27:17,187 INFO [MediaServer] ------------------------------------------------------------------------
2012-03-10 10:27:17,187 INFO [MediaServer] Serviio DLNA media streaming server v 0.6.2 (rev. aec3abd196d6+)
2012-03-10 10:27:17,187 INFO [MediaServer] Petr Nejedly 2009-2011
2012-03-10 10:27:17,187 INFO [MediaServer] http://www.serviio.org
2012-03-10 10:27:17,187 INFO [MediaServer] Java 1.6.0_31-Sun Microsystems Inc.
2012-03-10 10:27:17,187 INFO [MediaServer] OS Windows XP x86 5.1
2012-03-10 10:27:17,187 INFO [MediaServer] File encoding: windows-1252
2012-03-10 10:27:17,187 INFO [MediaServer] Headless mode enabled: true
2012-03-10 10:27:17,187 INFO [MediaServer] User home dir: C:\Documents and Settings\Default User
2012-03-10 10:27:17,187 INFO [MediaServer] Temp dir: C:\WINDOWS\TEMP\
2012-03-10 10:27:17,546 INFO [RestletServer] Starting Restlet server exposed on port 23423
2012-03-10 10:27:17,703 INFO [DBSchemaUpdateExecutor] Checking if DB schema needs to be updated
2012-03-10 10:27:27,359 INFO [ServiioConsole] Starting Serviio Console
2012-03-10 10:27:30,406 INFO [DBSchemaUpdateExecutor] Updating DB schema
2012-03-10 10:27:31,812 INFO [ServiioConsole] Connecting to Serviio REST on localhost:23423
2012-03-10 10:27:50,515 INFO [ProfilesDefinitionParser] Parsing Profiles definition
2012-03-10 10:27:52,062 INFO [ProfilesDefinitionParser] Added profile 'Generic DLNA profile' (id=1)
2012-03-10 10:27:53,187 INFO [ProfilesDefinitionParser] Added profile 'Samsung TV (B-series)' (id=2)
2012-03-10 10:27:53,812 INFO [ProfilesDefinitionParser] Added profile 'Xbox 360' (id=3)
2012-03-10 10:27:54,640 INFO [ProfilesDefinitionParser] Added profile 'Playstation 3' (id=4)
2012-03-10 10:27:55,250 INFO [ProfilesDefinitionParser] Added profile 'Samsung TV (A-series)' (id=5)
2012-03-10 10:27:55,703 INFO [ProfilesDefinitionParser] Added profile 'DirecTV HD-DVR' (id=6)
2012-03-10 10:27:57,187 INFO [ProfilesDefinitionParser] Added profile 'Samsung TV / player (C/D-series)' (id=7)
2012-03-10 10:27:57,312 INFO [ProfilesDefinitionParser] Added profile 'LG TV / player' (id=8)
2012-03-10 10:27:58,609 INFO [ProfilesDefinitionParser] Added profile 'Sony Bravia TV (2011)' (id=9)
2012-03-10 10:28:00,687 INFO [ProfilesDefinitionParser] Added profile 'Sony BD Player / SMP' (id=10)
2012-03-10 10:28:01,984 INFO [ProfilesDefinitionParser] Added profile 'Panasonic Viera' (id=12)
2012-03-10 10:28:02,781 INFO [ProfilesDefinitionParser] Added profile 'Toshiba REGZA' (id=13)
2012-03-10 10:28:03,265 INFO [ProfilesDefinitionParser] Added profile 'WDTV Live' (id=14)
2012-03-10 10:28:03,375 INFO [ProfilesDefinitionParser] Added profile 'LaCie LaCinema Media Player' (id=15)
2012-03-10 10:28:03,734 INFO [ProfilesDefinitionParser] Added profile 'Manta WIFI Centre' (id=16)
2012-03-10 10:28:03,906 INFO [ProfilesDefinitionParser] Added profile 'Pure Flow' (id=17)
2012-03-10 10:28:04,531 INFO [ProfilesDefinitionParser] Added profile 'Sharp Aquos' (id=18)
2012-03-10 10:28:04,828 INFO [ProfilesDefinitionParser] Added profile 'Sony Bravia TV (2010)' (id=19)
2012-03-10 10:28:05,828 INFO [ProfilesDefinitionParser] Added profile 'Philips' (id=20)
2012-03-10 10:28:06,296 INFO [ProfilesDefinitionParser] Added profile 'Sony Bravia TV (2009)' (id=21)
2012-03-10 10:28:06,875 INFO [WebServer] Socket buffer set to 65535 bytes
2012-03-10 10:28:06,875 INFO [Device] Created UPnP Device with UUID: 3d3a65b8-9910-3111-900d-0c65ab0f6bfa, bound address: 192.168.1.100
2012-03-10 10:28:06,937 INFO [PluginCompilerThread] Looking for plugins at C:\Program Files\Serviio\bin\..\plugins
2012-03-10 10:28:06,968 INFO [PluginCompilerThread] Started looking for plugins
2012-03-10 10:28:08,000 INFO [AbstractTranscodingDeliveryEngine] Cleaning transcode engine and its data
2012-03-10 10:28:08,093 INFO [WebServer] WebServer starting on port 8895
2012-03-10 10:28:08,125 INFO [EventSubscriptionExpirationChecker] Starting EventSubscriptionExpirationChecker
2012-03-10 10:28:08,125 INFO [EventDispatcher] Starting EventDispatcher
2012-03-10 10:28:08,140 INFO [DiscoveryAdvertisementNotifier] Starting DiscoveryAdvertisementNotifier
2012-03-10 10:28:08,140 INFO [RendererExpirationChecker] Starting RendererExpirationChecker
2012-03-10 10:28:08,140 INFO [RendererSearchSender] Searching for Renderer devices
2012-03-10 10:28:08,156 INFO [DiscoverySSDPMessageListener] Starting DiscoverySSDPMessageListener using interface eth0 (Realtek RTL8139/810x Family Fast Ethernet NIC - Packet Scheduler Miniport) and address 192.168.1.100, timeout = 0
2012-03-10 10:28:08,218 WARN [DiscoveryAdvertisementNotifier] Could not advertise the device on any available NIC, will try again
2012-03-10 10:28:08,843 INFO [Messages] Loaded console message bundle for locale: en
2012-03-10 10:28:08,890 INFO [UpdateChecker] Checking if a new version is available
2012-03-10 10:28:11,656 INFO [ContentDirectoryDefinitionParser] Parsing ContentDirectory definition
2012-03-10 10:28:13,328 INFO [BrowsingCategoriesMessages] Loaded browsing categories message bundle for locale: en
2012-03-10 10:28:13,750 WARN [DiscoveryAdvertisementNotifier] Could not advertise the device on any available NIC, will try again
2012-03-10 10:28:18,765 WARN [DiscoveryAdvertisementNotifier] Could not advertise the device on any available NIC, will try again
2012-03-10 10:28:24,093 WARN [DiscoveryAdvertisementNotifier] Could not advertise the device on any available NIC, will try again
2012-03-10 10:28:28,218 INFO [FeedUpdaterThread] Started looking for information about online resources
2012-03-10 10:28:28,234 INFO [LibraryAdditionsCheckerThread] Started looking for newly added files
2012-03-10 10:28:28,234 INFO [LibraryUpdatesCheckerThread] Started looking for updates to currently shared files
2012-03-10 10:28:29,265 WARN [DiscoveryAdvertisementNotifier] Could not advertise the device on any available NIC, will try again
2012-03-10 10:28:34,281 WARN [DiscoveryAdvertisementNotifier] Could not advertise the device on any available NIC, will try again
2012-03-10 10:28:39,296 WARN [DiscoveryAdvertisementNotifier] Could not advertise the device on any available NIC, will try again
2012-03-10 10:28:44,343 WARN [DiscoveryAdvertisementNotifier] Could not advertise the device on any available NIC, will try again
2012-03-10 10:28:49,359 WARN [DiscoveryAdvertisementNotifier] Could not advertise the device on any available NIC, will try again
2012-03-10 10:28:54,375 WARN [DiscoveryAdvertisementNotifier] Could not advertise the device on any available NIC, will try again
2012-03-10 10:28:59,421 WARN [DiscoveryAdvertisementNotifier] Could not advertise the device on any available NIC, will try again
2012-03-10 10:29:05,031 WARN [DiscoveryAdvertisementNotifier] Could not advertise the device on any available NIC, will try again
2012-03-10 10:29:10,062 WARN [DiscoveryAdvertisementNotifier] Could not advertise the device on any available NIC, will try again
2012-03-10 10:29:17,125 WARN [DiscoveryAdvertisementNotifier] Could not advertise the device on any available NIC, will try again
2012-03-10 10:29:24,062 WARN [DiscoveryAdvertisementNotifier] Could not advertise the device on any available NIC, will try again
2012-03-10 10:29:29,734 WARN [DiscoveryAdvertisementNotifier] Could not advertise the device on any available NIC, will try again
2012-03-10 10:29:35,625 WARN [DiscoveryAdvertisementNotifier] Could not advertise the device on any available NIC, will try again
2012-03-10 10:29:41,218 WARN [DiscoveryAdvertisementNotifier] Could not advertise the device on any available NIC, will try again
2012-03-10 10:29:46,234 WARN [DiscoveryAdvertisementNotifier] Could not advertise the device on any available NIC, will try again
2012-03-10 10:29:51,250 WARN [DiscoveryAdvertisementNotifier] Could not advertise the device on any available NIC, will try again
2012-03-10 10:29:56,265 WARN [DiscoveryAdvertisementNotifier] Could not advertise the device on any available NIC, will try again
2012-03-10 10:30:01,296 WARN [DiscoveryAdvertisementNotifier] Could not advertise the device on any available NIC, will try again
2012-03-10 10:30:06,296 WARN [DiscoveryAdvertisementNotifier] Could not advertise the device on any available NIC, will try again
2012-03-10 10:30:11,421 WARN [DiscoveryAdvertisementNotifier] Could not advertise the device on any available NIC, will try again
2012-03-10 10:30:16,453 WARN [DiscoveryAdvertisementNotifier] Could not advertise the device on any available NIC, will try again
2012-03-10 10:30:21,468 WARN [DiscoveryAdvertisementNotifier] Could not advertise the device on any available NIC, will try again
2012-03-10 10:30:26,468 WARN [DiscoveryAdvertisementNotifier] Could not advertise the device on any available NIC, will try again
2012-03-10 10:30:31,500 WARN [DiscoveryAdvertisementNotifier] Could not advertise the device on any available NIC, will try again
2012-03-10 10:30:36,500 WARN [DiscoveryAdvertisementNotifier] Could not advertise the device on any available NIC, will try again
2012-03-10 10:30:41,515 WARN [DiscoveryAdvertisementNotifier] Could not advertise the device on any available NIC, will try again
2012-03-10 10:30:46,531 WARN [DiscoveryAdvertisementNotifier] Could not advertise the device on any available NIC, will try again
2012-03-10 10:30:51,546 WARN [DiscoveryAdvertisementNotifier] Could not advertise the device on any available NIC, will try again
2012-03-10 10:30:56,562 WARN [DiscoveryAdvertisementNotifier] Could not advertise the device on any available NIC, will try again
2012-03-10 10:31:01,578 WARN [DiscoveryAdvertisementNotifier] Could not advertise the device on any available NIC, will try again
2012-03-10 10:31:06,593 WARN [DiscoveryAdvertisementNotifier] Could not advertise the device on any available NIC, will try again
2012-03-10 10:31:11,593 WARN [DiscoveryAdvertisementNotifier] Could not advertise the device on any available NIC, will try again
2012-03-10 10:31:16,625 WARN [DiscoveryAdvertisementNotifier] Could not advertise the device on any available NIC, will try again
2012-03-10 10:31:21,640 WARN [DiscoveryAdvertisementNotifier] Could not advertise the device on any available NIC, will try again
2012-03-10 10:31:26,671 WARN [DiscoveryAdvertisementNotifier] Could not advertise the device on any available NIC, will try again
2012-03-10 10:31:31,671 WARN [DiscoveryAdvertisementNotifier] Could not advertise the device on any available NIC, will try again
2012-03-10 10:31:36,703 WARN [DiscoveryAdvertisementNotifier] Could not advertise the device on any available NIC, will try again
2012-03-10 10:31:41,703 WARN [DiscoveryAdvertisementNotifier] Could not advertise the device on any available NIC, will try again
2012-03-10 10:31:46,718 WARN [DiscoveryAdvertisementNotifier] Could not advertise the device on any available NIC, will try again
2012-03-10 10:31:51,734 WARN [DiscoveryAdvertisementNotifier] Could not advertise the device on any available NIC, will try again
2012-03-10 10:31:56,750 WARN [DiscoveryAdvertisementNotifier] Could not advertise the device on any available NIC, will try again
2012-03-10 10:32:01,750 WARN [DiscoveryAdvertisementNotifier] Could not advertise the device on any available NIC, will try again
2012-03-10 10:32:06,781 WARN [DiscoveryAdvertisementNotifier] Could not advertise the device on any available NIC, will try again
2012-03-10 10:32:11,781 WARN [DiscoveryAdvertisementNotifier] Could not advertise the device on any available NIC, will try again
2012-03-10 10:32:16,796 WARN [DiscoveryAdvertisementNotifier] Could not advertise the device on any available NIC, will try again
2012-03-10 10:32:21,812 WARN [DiscoveryAdvertisementNotifier] Could not advertise the device on any available NIC, will try again
2012-03-10 10:32:26,828 WARN [DiscoveryAdvertisementNotifier] Could not advertise the device on any available NIC, will try again
2012-03-10 10:32:31,828 WARN [DiscoveryAdvertisementNotifier] Could not advertise the device on any available NIC, will try again
2012-03-10 10:32:36,843 WARN [DiscoveryAdvertisementNotifier] Could not advertise the device on any available NIC, will try again
2012-03-10 10:32:41,859 WARN [DiscoveryAdvertisementNotifier] Could not advertise the device on any available NIC, will try again
2012-03-10 10:32:46,875 WARN [DiscoveryAdvertisementNotifier] Could not advertise the device on any available NIC, will try again
2012-03-10 10:32:51,890 WARN [DiscoveryAdvertisementNotifier] Could not advertise the device on any available NIC, will try again
2012-03-10 10:32:56,906 WARN [DiscoveryAdvertisementNotifier] Could not advertise the device on any available NIC, will try again
2012-03-10 10:33:01,906 WARN [DiscoveryAdvertisementNotifier] Could not advertise the device on any available NIC, will try again
2012-03-10 10:33:06,921 WARN [DiscoveryAdvertisementNotifier] Could not advertise the device on any available NIC, will try again
2012-03-10 10:33:11,937 WARN [DiscoveryAdvertisementNotifier] Could not advertise the device on any available NIC, will try again
2012-03-10 10:33:16,953 WARN [DiscoveryAdvertisementNotifier] Could not advertise the device on any available NIC, will try again
2012-03-10 10:33:21,968 WARN [DiscoveryAdvertisementNotifier] Could not advertise the device on any available NIC, will try again
2012-03-10 10:33:26,984 WARN [DiscoveryAdvertisementNotifier] Could not advertise the device on any available NIC, will try again
2012-03-10 10:33:32,000 WARN [DiscoveryAdvertisementNotifier] Could not advertise the device on any available NIC, will try again
2012-03-10 10:33:37,000 WARN [DiscoveryAdvertisementNotifier] Could not advertise the device on any available NIC, will try again
2012-03-10 10:33:42,015 WARN [DiscoveryAdvertisementNotifier] Could not advertise the device on any available NIC, will try again
2012-03-10 10:33:47,031 WARN [DiscoveryAdvertisementNotifier] Could not advertise the device on any available NIC, will try again
2012-03-10 10:33:52,046 WARN [DiscoveryAdvertisementNotifier] Could not advertise the device on any available NIC, will try again
2012-03-10 10:33:57,062 WARN [DiscoveryAdvertisementNotifier] Could not advertise the device on any available NIC, will try again
2012-03-10 10:34:02,062 WARN [DiscoveryAdvertisementNotifier] Could not advertise the device on any available NIC, will try again
2012-03-10 10:34:07,078 WARN [DiscoveryAdvertisementNotifier] Could not advertise the device on any available NIC, will try again
2012-03-10 10:34:12,093 WARN [DiscoveryAdvertisementNotifier] Could not advertise the device on any available NIC, will try again
2012-03-10 10:34:17,109 WARN [DiscoveryAdvertisementNotifier] Could not advertise the device on any available NIC, will try again
2012-03-10 10:34:22,125 WARN [DiscoveryAdvertisementNotifier] Could not advertise the device on any available NIC, will try again
2012-03-10 10:34:27,140 WARN [DiscoveryAdvertisementNotifier] Could not advertise the device on any available NIC, will try again
2012-03-10 10:34:32,156 WARN [DiscoveryAdvertisementNotifier] Could not advertise the device on any available NIC, will try again
2012-03-10 10:34:37,156 WARN [DiscoveryAdvertisementNotifier] Could not advertise the device on any available NIC, will try again
2012-03-10 10:34:42,218 WARN [DiscoveryAdvertisementNotifier] Could not advertise the device on any available NIC, will try again
2012-03-10 10:34:47,218 WARN [DiscoveryAdvertisementNotifier] Could not advertise the device on any available NIC, will try again
2012-03-10 10:34:52,234 WARN [DiscoveryAdvertisementNotifier] Could not advertise the device on any available NIC, will try again
2012-03-10 10:34:57,250 WARN [DiscoveryAdvertisementNotifier] Could not advertise the device on any available NIC, will try again
2012-03-10 10:35:02,265 WARN [DiscoveryAdvertisementNotifier] Could not advertise the device on any available NIC, will try again
2012-03-10 10:35:07,265 WARN [DiscoveryAdvertisementNotifier] Could not advertise the device on any available NIC, will try again
2012-03-10 10:35:12,281 WARN [DiscoveryAdvertisementNotifier] Could not advertise the device on any available NIC, will try again
2012-03-10 10:35:17,296 WARN [DiscoveryAdvertisementNotifier] Could not advertise the device on any available NIC, will try again
2012-03-10 10:35:22,312 WARN [DiscoveryAdvertisementNotifier] Could not advertise the device on any available NIC, will try again
2012-03-10 10:35:27,328 WARN [DiscoveryAdvertisementNotifier] Could not advertise the device on any available NIC, will try again
2012-03-10 10:35:32,343 WARN [DiscoveryAdvertisementNotifier] Could not advertise the device on any available NIC, will try again
2012-03-10 10:35:37,359 WARN [DiscoveryAdvertisementNotifier] Could not advertise the device on any available NIC, will try again
2012-03-10 10:35:42,359 WARN [DiscoveryAdvertisementNotifier] Could not advertise the device on any available NIC, will try again
2012-03-10 10:35:47,390 WARN [DiscoveryAdvertisementNotifier] Could not advertise the device on any available NIC, will try again
2012-03-10 10:35:52,390 WARN [DiscoveryAdvertisementNotifier] Could not advertise the device on any available NIC, will try again
2012-03-10 10:35:55,671 INFO [WebServer] WebServer shutting down
2012-03-10 10:35:55,671 INFO [DiscoveryAdvertisementNotifier] Leaving DiscoveryAdvertisementNotifier
2012-03-10 10:35:55,671 INFO [EventSubscriptionExpirationChecker] Leaving EventSubscriptionExpirationChecker, removing all event subscriptions
2012-03-10 10:35:55,671 INFO [EventDispatcher] Leaving EventDispatcher
2012-03-10 10:35:55,796 INFO [Device] Updated bound IP address of Device with UUID: 3d3a65b8-9910-3111-900d-0c65ab0f6bfa, bound address: 192.168.1.100
2012-03-10 10:35:55,796 INFO [WebServer] WebServer starting on port 8895
2012-03-10 10:35:55,796 INFO [EventSubscriptionExpirationChecker] Starting EventSubscriptionExpirationChecker
2012-03-10 10:35:55,796 INFO [DiscoveryAdvertisementNotifier] Starting DiscoveryAdvertisementNotifier
2012-03-10 10:35:55,796 INFO [EventDispatcher] Starting EventDispatcher
2012-03-10 10:35:55,796 INFO [RendererSearchSender] Searching for Renderer devices
2012-03-10 10:35:55,812 INFO [DiscoverySSDPMessageListener] Starting DiscoverySSDPMessageListener using interface eth0 (Realtek RTL8139/810x Family Fast Ethernet NIC - Packet Scheduler Miniport) and address 192.168.1.100, timeout = 0
2012-03-10 10:35:55,906 WARN [DiscoveryAdvertisementNotifier] Could not advertise the device on any available NIC, will try again
2012-03-10 10:35:58,156 INFO [RendererExpirationChecker] Leaving RendererExpirationChecker
2012-03-10 10:36:00,921 WARN [DiscoveryAdvertisementNotifier] Could not advertise the device on any available NIC, will try again
2012-03-10 10:36:05,921 WARN [DiscoveryAdvertisementNotifier] Could not advertise the device on any available NIC, will try again
2012-03-10 10:36:10,984 WARN [DiscoveryAdvertisementNotifier] Could not advertise the device on any available NIC, will try again
2012-03-10 10:36:13,250 INFO [WebServer] WebServer shutting down
2012-03-10 10:36:13,250 INFO [DiscoveryAdvertisementNotifier] Leaving DiscoveryAdvertisementNotifier
2012-03-10 10:36:13,250 INFO [EventDispatcher] Leaving EventDispatcher
2012-03-10 10:36:13,265 INFO [EventSubscriptionExpirationChecker] Leaving EventSubscriptionExpirationChecker, removing all event subscriptions
2012-03-10 10:36:45,328 INFO [RendererManager] Stored a new renderer: uuid='5eeacc37-b37a-4f5f-a092-673888d2c1c5', name = 'SamsungTV', ipAddress='192.168.1.3', profile = '7'
2012-03-10 10:36:48,062 INFO [DiscoveryAdvertisementNotifier] Starting DiscoveryAdvertisementNotifier
2012-03-10 10:36:48,062 INFO [RendererSearchSender] Searching for Renderer devices
2012-03-10 10:36:48,062 INFO [WebServer] WebServer starting on port 8895
2012-03-10 10:36:48,062 INFO [EventDispatcher] Starting EventDispatcher
2012-03-10 10:36:48,062 INFO [EventSubscriptionExpirationChecker] Starting EventSubscriptionExpirationChecker
2012-03-10 10:36:48,062 INFO [DiscoverySSDPMessageListener] Starting DiscoverySSDPMessageListener using interface eth0 (Realtek RTL8139/810x Family Fast Ethernet NIC - Packet Scheduler Miniport) and address 192.168.1.100, timeout = 0
2012-03-10 10:36:48,156 WARN [DiscoveryAdvertisementNotifier] Could not advertise the device on any available NIC, will try again
2012-03-10 10:36:53,156 WARN [DiscoveryAdvertisementNotifier] Could not advertise the device on any available NIC, will try again
2012-03-10 10:36:58,187 WARN [DiscoveryAdvertisementNotifier] Could not advertise the device on any available NIC, will try again
2012-03-10 10:37:01,718 INFO [DiscoverySSDPMessageListener] Leaving DiscoverySSDPMessageListener
2012-03-10 10:37:03,187 WARN [DiscoveryAdvertisementNotifier] Could not advertise the device on any available NIC, will try again
2012-03-10 10:37:08,203 WARN [DiscoveryAdvertisementNotifier] Could not advertise the device on any available NIC, will try again
2012-03-10 10:37:13,203 WARN [DiscoveryAdvertisementNotifier] Could not advertise the device on any available NIC, will try again
2012-03-10 10:37:18,218 WARN [DiscoveryAdvertisementNotifier] Could not advertise the device on any available NIC, will try again
2012-03-10 10:37:23,218 WARN [DiscoveryAdvertisementNotifier] Could not advertise the device on any available NIC, will try again
2012-03-10 10:37:28,234 WARN [DiscoveryAdvertisementNotifier] Could not advertise the device on any available NIC, will try again
2012-03-10 10:37:33,234 WARN [DiscoveryAdvertisementNotifier] Could not advertise the device on any available NIC, will try again
2012-03-10 10:37:38,250 WARN [DiscoveryAdvertisementNotifier] Could not advertise the device on any available NIC, will try again
2012-03-10 10:37:43,265 WARN [DiscoveryAdvertisementNotifier] Could not advertise the device on any available NIC, will try again
2012-03-10 10:37:48,265 WARN [DiscoveryAdvertisementNotifier] Could not advertise the device on any available NIC, will try again
2012-03-10 10:37:53,281 WARN [DiscoveryAdvertisementNotifier] Could not advertise the device on any available NIC, will try again
2012-03-10 10:37:58,281 WARN [DiscoveryAdvertisementNotifier] Could not advertise the device on any available NIC, will try again
2012-03-10 10:38:03,296 WARN [DiscoveryAdvertisementNotifier] Could not advertise the device on any available NIC, will try again
2012-03-10 10:38:08,296 WARN [DiscoveryAdvertisementNotifier] Could not advertise the device on any available NIC, will try again
2012-03-10 10:38:13,312 WARN [DiscoveryAdvertisementNotifier] Could not advertise the device on any available NIC, will try again
2012-03-10 10:38:18,312 WARN [DiscoveryAdvertisementNotifier] Could not advertise the device on any available NIC, will try again
2012-03-10 10:38:23,328 WARN [DiscoveryAdvertisementNotifier] Could not advertise the device on any available NIC, will try again
2012-03-10 10:38:28,328 WARN [DiscoveryAdvertisementNotifier] Could not advertise the device on any available NIC, will try again
2012-03-10 10:38:33,343 WARN [DiscoveryAdvertisementNotifier] Could not advertise the device on any available NIC, will try again
2012-03-10 10:38:38,343 WARN [DiscoveryAdvertisementNotifier] Could not advertise the device on any available NIC, will try again
2012-03-10 10:38:43,359 WARN [DiscoveryAdvertisementNotifier] Could not advertise the device on any available NIC, will try again
2012-03-10 10:38:48,359 WARN [DiscoveryAdvertisementNotifier] Could not advertise the device on any available NIC, will try again
2012-03-10 10:38:50,015 INFO [WebServer] WebServer shutting down
2012-03-10 10:38:50,015 INFO [DiscoveryAdvertisementNotifier] Leaving DiscoveryAdvertisementNotifier
2012-03-10 10:38:50,015 INFO [EventSubscriptionExpirationChecker] Leaving EventSubscriptionExpirationChecker, removing all event subscriptions
2012-03-10 10:38:50,015 INFO [EventDispatcher] Leaving EventDispatcher
2012-03-10 10:38:50,093 INFO [DiscoveryAdvertisementNotifier] Starting DiscoveryAdvertisementNotifier
2012-03-10 10:38:50,093 INFO [RendererSearchSender] Searching for Renderer devices
2012-03-10 10:38:50,093 INFO [WebServer] WebServer starting on port 8895
2012-03-10 10:38:50,093 INFO [EventDispatcher] Starting EventDispatcher
2012-03-10 10:38:50,093 INFO [EventSubscriptionExpirationChecker] Starting EventSubscriptionExpirationChecker
2012-03-10 10:38:50,093 INFO [DiscoverySSDPMessageListener] Starting DiscoverySSDPMessageListener using interface eth0 (Realtek RTL8139/810x Family Fast Ethernet NIC - Packet Scheduler Miniport) and address 192.168.1.100, timeout = 0
2012-03-10 10:38:50,140 WARN [DiscoveryAdvertisementNotifier] Could not advertise the device on any available NIC, will try again
2012-03-10 10:38:51,484 INFO [WebServer] WebServer shutting down
2012-03-10 10:38:51,484 INFO [DiscoveryAdvertisementNotifier] Leaving DiscoveryAdvertisementNotifier
2012-03-10 10:38:51,484 INFO [EventSubscriptionExpirationChecker] Leaving EventSubscriptionExpirationChecker, removing all event subscriptions
2012-03-10 10:38:51,484 INFO [EventDispatcher] Leaving EventDispatcher
2012-03-10 10:38:54,859 INFO [DiscoveryAdvertisementNotifier] Starting DiscoveryAdvertisementNotifier
2012-03-10 10:38:54,859 INFO [RendererSearchSender] Searching for Renderer devices
2012-03-10 10:38:54,859 INFO [WebServer] WebServer starting on port 8895
2012-03-10 10:38:54,859 INFO [EventDispatcher] Starting EventDispatcher
2012-03-10 10:38:54,859 INFO [EventSubscriptionExpirationChecker] Starting EventSubscriptionExpirationChecker
2012-03-10 10:38:54,875 INFO [DiscoverySSDPMessageListener] Starting DiscoverySSDPMessageListener using interface eth0 (Realtek RTL8139/810x Family Fast Ethernet NIC - Packet Scheduler Miniport) and address 192.168.1.100, timeout = 0
2012-03-10 10:38:54,937 WARN [DiscoveryAdvertisementNotifier] Could not advertise the device on any available NIC, will try again
2012-03-10 10:38:59,937 WARN [DiscoveryAdvertisementNotifier] Could not advertise the device on any available NIC, will try again
2012-03-10 10:39:04,953 WARN [DiscoveryAdvertisementNotifier] Could not advertise the device on any available NIC, will try again
2012-03-10 10:39:09,953 WARN [DiscoveryAdvertisementNotifier] Could not advertise the device on any available NIC, will try again
2012-03-10 10:39:14,968 WARN [DiscoveryAdvertisementNotifier] Could not advertise the device on any available NIC, will try again
2012-03-10 10:39:19,968 WARN [DiscoveryAdvertisementNotifier] Could not advertise the device on any available NIC, will try again
2012-03-10 10:39:24,984 WARN [DiscoveryAdvertisementNotifier] Could not advertise the device on any available NIC, will try again
2012-03-10 10:39:29,984 WARN [DiscoveryAdvertisementNotifier] Could not advertise the device on any available NIC, will try again
2012-03-10 10:39:35,000 WARN [DiscoveryAdvertisementNotifier] Could not advertise the device on any available NIC, will try again
2012-03-10 10:39:40,000 WARN [DiscoveryAdvertisementNotifier] Could not advertise the device on any available NIC, will try again
2012-03-10 10:39:45,015 WARN [DiscoveryAdvertisementNotifier] Could not advertise the device on any available NIC, will try again
Post Sat Mar 10, 2012 11:58 am
Is 192.168.1.100 the IP addres you want to use (the wire connection) ?
Looking at the log it looks like the network ard cannot send multicast messages to let the devices know about the server's presence.
It'd explain why you cannot make it work with any software. See if you have multicast disabled, alternatively try updating the network card driver.
MasterT
Post Sat Mar 10, 2012 1:02 pm
192.168.1.100 is the ip of the desktop computer wired to the router.
It has a Realtek8139 on board with 5.719 version driver which is the latest on realtek webpage.
192.168.1.200 is the ip of the tv.
Router is a D-link, it has a MULTICAST STREAMS option which is enabled.
later edit: i disabled multicast streams option in router and now is working.
Post Mon Mar 12, 2012 2:44 pm
MasterT wrote:later edit: i disabled multicast streams option in router and now is working.
Makes sense :-)
madman10
Post Tue Mar 13, 2012 3:34 pm
I have the same TV you have and Samsung don't know what they are talking about, I have mine hardwired to my network and Serviio does find it. Make sure that there's no IP conflicts on your PC and TV, if there is then that would be a reason for it not being found. Go in the settings of the Samsung TV and make sure it is on a DHCP type connection, not STATIC and also on the PC make sure it is a DHCP type connection . Just go in the adapter settings and choose details it will show a IPV4 address that will be your IP on your PC. Serviio works excellently with your TV just make sure that both TV and PC are set to get a DHCP type IP connection.
The Madman :D
Users browsing this forum: Google [Bot] and 15 guests
