Sumvision media player
Wingsgb
Post Sun Mar 04, 2012 1:34 pm
Just connect a old media player onto my serviio network and noticed it was on a generic profile so i want to create a profile for it as its a good player.
Followed Intel UPnP guide but device never showed up. I also checked the DLNA product page and nothing.
Its a "Sumvision Cyclone MKV1 enclosure media player" cant find the info on there website as its old but iv got a data sheet of the same box just different name http://www.traxdata.com/download/4/Datasheet-MMS-EN.pdf
And here's some info of the box
MP3, WMA, WAV, OGG, AAC, LPCM, FLAC, DOLBY Digital, DTS Digital.
Video Codec
H.264, MKV, WMV9, MPEG 1/2/4, HD Divx, Xvid, FLV, RM/RMVB
Video File
mkv, ts, m2ts, mts, tp, trp, wmv, ifo, vob, dat, avi, mpg, mp4, mov, rm, rmvb, divx, xvid, flv
Video Resolution
H.264, MKV, WMV9, TS and HD Divx supports up to 1920 x 1080p 30p RM/RMVB supports up to 720p
Subtitle
sub, smi, ssa, srt, idx + sub
Photo File
JPG, JPEG, BMP, PNG, TIFF, GIF
Post Tue Mar 06, 2012 12:40 pm
Re: Sumvision media player
does it need a custom profile? did you find any files that don't play on it?
Wingsgb
Post Tue Mar 06, 2012 10:29 pm
Yes I think it dose need a profile as the picture on the online feed I tested was not smooth atal were as on my tv it was fine.
I will post file info of the stream when it's next on
Wingsgb
Post Wed Mar 07, 2012 7:37 pm
as requested
Microsoft Windows [Version 6.1.7600]
Copyright (c) 2009 Microsoft Corporation.  All rights reserved.
C:\Users\wings>cd "\Program Files\Serviio\lib"
C:\Program Files\Serviio\lib>cd "http://127.0.0.1:8902/"
The filename, directory name, or volume label syntax is incorrect.
C:\Program Files\Serviio\lib>ffmpeg.exe -i "http://127.0.0.1:8902/"
nfig
  libavutil    51. 32. 0 / 51. 32. 0
  libavcodec   53. 42. 0 / 53. 42. 0
  libavformat  53. 24. 0 / 53. 24. 0
  libavfilter   2. 53. 0 /  2. 53. 0
[wmv3 @ 02395d40] Extra data: 8 bits left, value: 0
[asf @ 01677f20] freeing incomplete packet size 4488, new 8729
[asf @ 01677f20] Estimating duration from bitrate, this may be inaccurate
Seems stream 1 codec frame rate differs from container frame rate: 1000.00 (1000
/1) -> 30.00 (30/1)
Input #0, asf, from 'http://127.0.0.1:8902/':
    WMFSDKVersion   : 12.0.7601.17514
    WMFSDKNeeded    : 0.0.0.0000
    IsVBR           : 0
  Duration: N/A, start: 4221.805000, bitrate: 1880 kb/s
    Stream #0:0(eng): Audio: wmav2 (a[1][0][0] / 0x0161), 44100 Hz, 2 channels,
s16, 80 kb/s
    Stream #0:1(eng): Video: wmv3 (Main) (WMV3 / 0x33564D57), yuv420p, 1280x720,
 1800 kb/s, 30 tbr, 1k tbn, 1k tbc
Wingsgb
Post Sat Mar 10, 2012 8:43 am
Is it the file causing the problem? My device says it plays wmv9 but is that different to wmv3 and intern needs transcoding?
Also while on the subject of transcoding is it possible to create a profile just for mp4/h.264
Post Sat Mar 10, 2012 11:55 am
wmv3 is WMV9 so it should play. Serviio doesn't distinguish between wmv8 and 9 so if you setup transcoding for all wmv it'll work for all of your wmv files.
Ypou can setup transcoding of only mp4/h264, you just need one Matchers element with mp4 container and h264 vCodec.
