Launch script from DLNA Client
therebel22
Post Sun Mar 11, 2012 9:54 am
First, thanks for this great tool !!
A feature that would be great : Serviio could serve virtual files in browser in DLNA Client : When user would choose this specific file, a script would be executed on serviio server side :
Example : For Sopcast, you could have one Sopcast url in each script, and when user chose a virtual file (ie a script), the script would reload sopcast.exe with new sopcast channel, wait for 15 seconds, and would stream the URL http://127.0.0.1:8902/stream
Another example : a script that shutdown server when user would choose it...
Thanks !
Wingsgb
Post Sun Mar 11, 2012 10:20 am
Re: Launch script from DLNA Client
That would be a good idea but you could effectively have other people on your network changing your set channel at the time or shutting down the server once they have watched something.
Ino there are scripts ATM which will run sopcast.exe and load up the channel you origanly clicked on. Whether or not that can be implemented over the UPnP network I don't know.
I think sopcast is great. Only if you could run more than one stream at a time
therebel22
Post Sun Mar 11, 2012 5:26 pm
Thanks for reply. What is scripts ATM ?
Post Sun Mar 11, 2012 5:34 pm
ATM => At the Moment (I think)
Wingsgb
Post Sun Mar 11, 2012 9:00 pm
^^^ as moltra said.
There out there just not on serviio
Return to Feature requests
Users browsing this forum: Baidu [Spider] and 5 guests
