SONY-KDL40EX520
Golimer
Post Sun Mar 11, 2012 11:46 am
SONY-KDL40EX520
Hello guys
I need yours help, I have MKV which not showing, I checked codecs and in my opinion audio codecs not compatible.....
I have attche picture
Post Sun Mar 11, 2012 1:22 pm
Re: SONY-KDL40EX520
Please, could you provide information with "ffmpeg -i" result and MediaInfo tool result in text format ? (see signature link)
Golimer
Post Sun Mar 11, 2012 2:06 pm
Re: SONY-KDL40EX520
C:\Program Files\Serviio\lib>ffmpeg.exe -i D:\Video\HD\NipTuck.S02.720p.WEB-DL.R
us.Eng\Nip.Tuck.S02E01.720p.WEB-DL.Rus.Eng.mkv
ffmpeg version N-38292-ga4c22e3 Copyright (c) 2000-2012 the FFmpeg developers
built on Feb 27 2012 14:55:47 with gcc 4.6.2
configuration: --enable-gpl --enable-version3 --disable-w32threads --enable-ru
ntime-cpudetect --enable-avisynth --enable-bzlib --enable-frei0r --enable-libope
ncore-amrnb --enable-libopencore-amrwb --enable-libfreetype --enable-libgsm --en
able-libmp3lame --enable-libopenjpeg --enable-librtmp --enable-libschroedinger -
-enable-libspeex --enable-libtheora --enable-libvo-aacenc --enable-libvo-amrwben
c --enable-libvorbis --enable-libvpx --enable-libx264 --enable-libxavs --enable-
libxvid --enable-zlib
libavutil 51. 41.100 / 51. 41.100
libavcodec 54. 4.100 / 54. 4.100
libavformat 54. 1.100 / 54. 1.100
libavdevice 53. 4.100 / 53. 4.100
libavfilter 2. 62.101 / 2. 62.101
libswresample 0. 7.100 / 0. 7.100
[h264 @ 0000000001CC9700] Increasing reorder buffer to 1
Input #0, matroska,webm, from 'D:\Video\HD\NipTuck.S02.720p.WEB-DL.Rus.Eng\Nip.T
uck.S02E01.720p.WEB-DL.Rus.Eng.mkv':
Duration: 00:54:58.02, start: 0.000000, bitrate: 4517 kb/s
Stream #0:0(eng): Video: h264 (High), yuv420p, 1280x720 [SAR 1:1 DAR 16:9],
23.98 fps, 23.98 tbr, 1k tbn, 2k tbc (default)
title : Nip/Tuck - Season 2, Episode 1: Erica Noughton
Stream #0:1(rus): Audio: ac3, 48000 Hz, stereo, s16, 192 kb/s (default)
title : RUS 2.0 (STS)
Stream #0:2(eng): Audio: aac, 48000 Hz, stereo, s16
title : ENG 2.0
And mediainfo tools
Unique ID : 179734686702578384534208183384281778712 (0x8737A43A6DD14E5490688159A8D90A18)
Complete name : D:\Video\HD\Nip Tuck.S03.720p.WEB-DL.Rus.Eng\Nip.Tuck.S03E01.720p.WEB-DL.Rus.Eng.mkv
Format : Matroska
Format version : Version 2
File size : 2.06 GiB
Duration : 1h 9mn
Overall bit rate : 4 267 Kbps
Encoded date : UTC 2010-08-24 08:08:13
Writing application : mkvmerge v3.4.0 ('Rapunzel') сборка от May 15 2010 09:38:20
Writing library : libebml v0.8.0 + libmatroska v0.9.0
Format : AVC
Format profile : High@L3.1
Format settings, CABAC : No
Format settings, ReFrames : 2 frames
Codec ID : V_MPEG4/ISO/AVC
Duration : 1h 9mn
Width : 1 280 pixels
Height : 720 pixels
Display aspect ratio : 16:9
Frame rate : 23.976 fps
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Progressive
Title : Nip/Tuck - Season 3, Episode 1: Momma Boone
Language : English
Default : Yes
Forced : No
Color primaries : BT.709-5, BT.1361, IEC 61966-2-4, SMPTE RP177
Transfer characteristics : BT.709-5, BT.1361
Matrix coefficients : BT.709-5, BT.1361, IEC 61966-2-4 709, SMPTE RP177
Audio #1
Format : AC-3
Format/Info : Audio Coding 3
Codec ID : A_AC3
Duration : 1h 9mn
Bit rate mode : Constant
Bit rate : 192 Kbps
Channel(s) : 2 channels
Sampling rate : 48.0 KHz
Bit depth : 16 bits
Compression mode : Lossy
Stream size : 94.8 MiB (4%)
Title : RUS 2.0 CTC
Language : Russian
Default : Yes
Forced : No
Audio #2
Format : AAC
Format profile : LC
Codec ID : A_AAC
Duration : 1h 9mn
Title : AAC 2.0 @ 160 kbps
Language : English
Default : No
Forced : No
Post Mon Mar 12, 2012 8:29 am
Re: SONY-KDL40EX520
This file looks good.
Some tips to try
- You can remux with another mkvmerge version.
- You can remux with TsMuxer tools to mpegts file stream.
You can also read that:
viewtopic.php?f=10&t=3267&start=20#p29382
viewtopic.php?f=10&t=4315#p28644
Golimer
Post Mon Mar 12, 2012 6:58 pm
Re: SONY-KDL40EX520
- You can remux with another mkvmerge version.[ done already same problem]
- You can remux with TsMuxer tools to mpegts file stream. (I will try this one) thanks
Post Mon Mar 12, 2012 7:01 pm
Re: SONY-KDL40EX520
Golimer wrote:- You can remux with another mkvmerge version.[ done already same problem]
And do you check the mkvmerge options, see previous links?
Golimer
Post Mon Mar 12, 2012 7:48 pm
Re: SONY-KDL40EX520
yes i have check but problem is not ff so on just my tv not showing tv says "temporary can reach the file" bla bla bla sometime remuxing helping but not this time..... :(
Post Mon Mar 12, 2012 7:51 pm
Re: SONY-KDL40EX520
Could you enable detailed logging and find the ffmpeg command line used to transcode this file ?
Golimer
Post Mon Mar 12, 2012 7:55 pm
Re: SONY-KDL40EX520
how to do that enable detailed logging and find the ffmpeg command line used to transcode this file ? :)
be the way do you have skype :)
Post Mon Mar 12, 2012 8:50 pm
Re: SONY-KDL40EX520
Golimer wrote:how to do that enable detailed logging and find the ffmpeg command line used to transcode this file ? :)
See signature links...
http://wiki.serviio.org/doku.php?id=detail_logging
Golimer
Post Sat Mar 17, 2012 7:30 pm
Re: SONY-KDL40EX520
2012-03-17 21:27:16,703 ERROR [ResourceTransportRequestHandler] Error while processing resource, sending back 500 error. Message: Transcoded file 'D:\Transcode temp\Serviio\transcoding-temp-491-MPEG2TS.stf' cannot be found, FFmpeg execution probably failed
java.io.IOException: Transcoded file 'D:\Transcode temp\Serviio\transcoding-temp-491-MPEG2TS.stf' cannot be found, FFmpeg execution probably failed
at org.serviio.delivery.resource.transcode.FileBasedTranscodingDeliveryStrategy.createInputStream(FileBasedTranscodingDeliveryStrategy.java:45)
at org.serviio.delivery.resource.transcode.AbstractTranscodingDeliveryEngine.retrieveTranscodedResource(AbstractTranscodingDeliveryEngine.java:129)
at org.serviio.delivery.resource.AbstractDeliveryEngine.deliver(AbstractDeliveryEngine.java:96)
at org.serviio.delivery.MediaResourceRetrievalStrategy.retrieveResource(MediaResourceRetrievalStrategy.java:121)
at org.serviio.upnp.webserver.ResourceTransportRequestHandler.handleRequest(ResourceTransportRequestHandler.java:116)
please xplain me wat is wrong???????? whay i should remux it with mkvmerge sometime its works sometime NOT an this one really p****me :/
Post Sun Mar 18, 2012 8:01 am
Re: SONY-KDL40EX520
Do you read the Sony read-me FAQ section ?
Q: I can see the file on my TV and has a thumbnail picture, but when I try to play the file I get an error "The server is Temporarily unavailable". Serviio log : ERROR [ResourceTransportRequestHandler] Error while processing resource, sending back 500 error. Message: FFmpeg execution failed java.io.IOException: FFmpeg execution failed
A: Turn on detailed logging (see link) you should be able to see the FFmpeg command that is used for the transcode. Try executing the command manually in a terminal window and post the (error) result here.
Golimer
Post Sun Mar 18, 2012 12:49 pm
Re: SONY-KDL40EX520
Please take a look ir debug log,
maybe try to add diferent mmpeg codec?
(201 KiB) Downloaded 663 times
Golimer
Post Sun Mar 18, 2012 8:53 pm
Re: SONY-KDL40EX520
one of sulution i have change version of mmpeg no problem solved with this movie.... we will se what will be with others :)
Post Mon Mar 19, 2012 7:42 pm
Re: SONY-KDL40EX520
Could you try locally in a windows terminal the following command line and post the error log here ?
C:\Program Files\Serviio\bin\\..\lib/ffmpeg.exe -i "D:\Video\HD\Forsag.4.Fast.And.Furious.2009.1080p.BDRip.DTS.x264-RG_Kinomani_FTO.mkv" -y -async 1 -vcodec copy -vbsf h264_mp4toannexb -copyts -acodec ac3 -ab 384k -ac 2 -map 0:0 -map 0:1 -sn -f mpegts D:\Transcode temp\Serviio\transcoding-temp-493-MPEG2TS.stf
