Streams my Samsung UE40D5700 won't play
sigma
Post Sun Mar 11, 2012 9:56 pm
Hi everybody,
I am using Serviio v 0.6.2 with Windows 6.0.6002 and I have a few live streams that work with VLC 2.0, that Servioo finds and lists correctly but that do not play on my Samsung TV UE40D5700. A typical example is
rtmp://nrjlivefs.fplive.net/nrjlive-live/nrjparis live=1
With ffmpeg, I get things like this :
C:\Program Files\Serviio\lib>ffmpeg -i "rtmp://nrjlivefs.fplive.net/nrjlive-live
/nrjparis live=1" test.flv
nfig
  libavutil    51. 32. 0 / 51. 32. 0
  libavcodec   53. 42. 0 / 53. 42. 0
  libavformat  53. 24. 0 / 53. 24. 0
  libavfilter   2. 53. 0 /  2. 53. 0
HandShake: client signature does not match!
  width                 640.00
  height                360.00
  framerate             25.00
  videocodecid          7.00
  videodatarate         800.00
  audiodatarate         64.00
[flv @ 01788420] Estimating duration from bitrate, this may be inaccurate
Input #0, flv, from 'rtmp://nrjlivefs.fplive.net/nrjlive-live/nrjparis live=1':
  Duration: N/A, start: 0.033000, bitrate: N/A
    Stream #0:0: Video: h264 (High), yuv420p, 640x360 [SAR 1:1 DAR 16:9], 25 tbr
, 1k tbn, 50 tbc
    Stream #0:1: Audio: aac, 44100 Hz, mono, s16
[buffer @ 02968de0] w:640 h:360 pixfmt:yuv420p tb:1/1000000 sar:1/1 sws_param:
Output #0, flv, to 'test.flv':
    encoder         : Lavf53.24.0
    Stream #0:0: Video: flv1 ([2][0][0][0] / 0x0002), yuv420p, 640x360 [SAR 1:1
DAR 16:9], q=2-31, 200 kb/s, 1k tbn, 25 tbc
    Stream #0:1: Audio: mp3 ([2][0][0][0] / 0x0002), 44100 Hz, mono, s16, 128 kb
/s
Stream mapping:
  Stream #0:0 -> #0:0 (h264 -> flv)
  Stream #0:1 -> #0:1 (aac -> libmp3lame)
[aac @ 0178d120] Parametric Stereo signaled to be not-present but was found in t
he bitstream.
    Last message repeated 39 times
frame=   49 fps=  0 q=9.2 size=     178kB time=00:00:01.80 bitrate= 809.6kbits/s
Parametric Stereo signaled to be not-present but was found in the bitstream.
he bitstream.
    Last message repeated 20 times
frame=   74 fps= 32 q=14.3 size=     241kB time=00:00:02.84 bitrate= 693.3kbits/
he bitstream.
    Last message repeated 11 times
frame=   89 fps= 30 q=14.2 size=     286kB time=00:00:03.44 bitrate= 679.6kbits/
he bitstream.
    Last message repeated 49 times
frame=  149 fps= 27 q=20.5 size=     423kB time=00:00:05.79 bitrate= 596.9kbits/
he bitstream.
    Last message repeated 24 times
frame=  180 fps= 29 q=30.0 size=     491kB time=00:00:07.02 bitrate= 572.7kbits/
he bitstream.
    Last message repeated 37 times
frame=  224 fps= 26 q=31.0 size=     598kB time=00:00:08.82 bitrate= 554.6kbits/
he bitstream.
frame=  269 fps= 29 q=31.0 size=     694kB time=00:00:10.63 bitrate= 535.1kbits/
he bitstream.
    Last message repeated 26 times
frame=  302 fps= 25 q=31.0 size=     763kB time=00:00:11.93 bitrate= 523.7kbits/
he bitstream.
    Last message repeated 60 times
frame=  374 fps= 25 q=31.0 size=     918kB time=00:00:14.81 bitrate= 507.7kbits/
he bitstream.
    Last message repeated 64 times
frame=  451 fps= 29 q=31.0 size=    1095kB time=00:00:17.89 bitrate= 501.1kbits/
he bitstream.
    Last message repeated 3 times
frame=  456 fps= 28 q=31.0 size=    1099kB time=00:00:18.10 bitrate= 497.4kbits/
he bitstream.
    Last message repeated 61 times
frame=  531 fps= 30 q=31.0 size=    1239kB time=00:00:21.02 bitrate= 482.8kbits/
he bitstream.
    Last message repeated 6 times
frame=  539 fps= 30 q=31.0 size=    1259kB time=00:00:21.42 bitrate= 481.3kbits/
he bitstream.
    Last message repeated 51 times
frame=  601 fps= 29 q=24.8 Lsize=    1447kB time=00:00:24.00 bitrate= 493.6kbits
/s dup=0 drop=92
video:1047kB audio:375kB global headers:0kB muxing overhead 1.691382%
Received signal 2: terminating.
I terminated with Ctrl+C.
My TV is listed in Serviio with the profile Samsung TV/Player (C-D series).
Has anybody any clue ?
Post Mon Mar 12, 2012 1:28 pm
Re: Streams my Samsung UE40D5700 won't play
