TV cannot see the server
jme
Post Mon Mar 12, 2012 11:16 am
Hi everybody!
I am trying to use serviio for share media files between the computer and my new Samsung UE32D5000 :D , but I cannot see the server from TV.
After installing serviio on windows XP, I set a fix IP address for TV and I can see the TV by 'ping' from PC, but ... when I include the IP adress on serviio console and set the profile like "Samsung C-D Series", it appears with yellow dot and TV can't connect with server.
I don't know if I have to set the IP address of media server in TV options, I don't see any option to do this. By the moment I have TV IP fixed and computer IP given by router's DHCP.
Please, anybody can help me? :cry:
Special very thanks.
Post Mon Mar 12, 2012 1:25 pm
Re: TV cannot see the server
when you bind to the PC's IP address and it then get a different one from DHCP it won't work. Fix both, TV and the PC. Other than that there are lots or similar threads to get help from.
jme
Post Mon Mar 12, 2012 9:08 pm
Thanks for answering,
I did it (2 IP addresses fixed) and I have the same problem. In other way I installed Serviio on my netbook with Windows 7 (connected to LAN with same wireless router), and casually when I was going to open the Serviio Console ... I see the TV connected with green dot status ... what surprise!
I turned off the server in netbook and try again after reboot in PC, there isn't any change. I turned off Window's firewall and antivirus software, but I don't get anything. Has anybody a good idea/reason to explain the 'NO visibility' between TV and PC w/XP? If it serves to find a reason, I have the same problem with Samsung's AllShare software, the netbook works fine and PC can't see TV.
Thanks again.
P.D.: Sorry by my English, it isn't very good.
Post Mon Mar 12, 2012 11:08 pm
can you post the serviio.log file for the computer that cannot be seen?
jme
Post Tue Mar 13, 2012 11:49 am
moltra wrote:can you post the serviio.log file for the computer that cannot be seen?
Hi Mark,
I post the yesterday's log once I fixed IP address:
2012-03-12 21:28:58,218 INFO  [MediaServer] ------------------------------------------------------------------------
2012-03-12 21:28:58,281 INFO  [MediaServer] Serviio DLNA media streaming server v 0.6.2 (rev. aec3abd196d6+)
2012-03-12 21:28:58,281 INFO  [MediaServer] Petr Nejedly 2009-2011
2012-03-12 21:28:58,281 INFO  [MediaServer] http://www.serviio.org
2012-03-12 21:28:58,281 INFO  [MediaServer] Java 1.6.0_26-Sun Microsystems Inc.
2012-03-12 21:28:58,281 INFO  [MediaServer] OS Windows XP x86 5.1
2012-03-12 21:28:58,281 INFO  [MediaServer] File encoding: windows-1252
2012-03-12 21:28:58,281 INFO  [MediaServer] Headless mode enabled: true
2012-03-12 21:28:58,281 INFO  [MediaServer] User home dir: C:\
2012-03-12 21:28:58,281 INFO  [MediaServer] Temp dir: H:\WINDOWS\TEMP\
2012-03-12 21:28:58,281 INFO  [MediaServer] ------------------------------------------------------------------------
2012-03-12 21:29:00,218 INFO  [RestletServer] Starting Restlet server exposed on port 23423
2012-03-12 21:29:00,921 INFO  [DBSchemaUpdateExecutor] Checking if DB schema needs to be updated
2012-03-12 21:29:12,296 INFO  [ProfilesDefinitionParser] Parsing Profiles definition
2012-03-12 21:29:12,859 INFO  [ProfilesDefinitionParser] Added profile 'Generic DLNA profile' (id=1)
2012-03-12 21:29:13,140 INFO  [ProfilesDefinitionParser] Added profile 'Samsung TV (B-series)' (id=2)
2012-03-12 21:29:13,328 INFO  [ProfilesDefinitionParser] Added profile 'Xbox 360' (id=3)
2012-03-12 21:29:13,500 INFO  [ProfilesDefinitionParser] Added profile 'Playstation 3' (id=4)
2012-03-12 21:29:13,593 INFO  [ProfilesDefinitionParser] Added profile 'Samsung TV (A-series)' (id=5)
2012-03-12 21:29:13,656 INFO  [ProfilesDefinitionParser] Added profile 'DirecTV HD-DVR' (id=6)
2012-03-12 21:29:13,984 INFO  [ProfilesDefinitionParser] Added profile 'Samsung TV / player (C/D-series)' (id=7)
2012-03-12 21:29:14,000 INFO  [ProfilesDefinitionParser] Added profile 'LG TV / player' (id=8)
2012-03-12 21:29:14,312 INFO  [ProfilesDefinitionParser] Added profile 'Sony Bravia TV (2011)' (id=9)
2012-03-12 21:29:14,781 INFO  [ProfilesDefinitionParser] Added profile 'Sony BD Player / SMP' (id=10)
2012-03-12 21:29:15,000 INFO  [ProfilesDefinitionParser] Added profile 'Panasonic Viera' (id=12)
2012-03-12 21:29:15,187 INFO  [ProfilesDefinitionParser] Added profile 'Toshiba REGZA' (id=13)
2012-03-12 21:29:15,296 INFO  [ProfilesDefinitionParser] Added profile 'WDTV Live' (id=14)
2012-03-12 21:29:15,328 INFO  [ProfilesDefinitionParser] Added profile 'LaCie LaCinema Media Player' (id=15)
2012-03-12 21:29:15,437 INFO  [ProfilesDefinitionParser] Added profile 'Manta WIFI Centre' (id=16)
2012-03-12 21:29:15,468 INFO  [ProfilesDefinitionParser] Added profile 'Pure Flow' (id=17)
2012-03-12 21:29:15,609 INFO  [ProfilesDefinitionParser] Added profile 'Sharp Aquos' (id=18)
2012-03-12 21:29:15,687 INFO  [ProfilesDefinitionParser] Added profile 'Sony Bravia TV (2010)' (id=19)
2012-03-12 21:29:15,859 INFO  [ProfilesDefinitionParser] Added profile 'Philips' (id=20)
2012-03-12 21:29:15,968 INFO  [ProfilesDefinitionParser] Added profile 'Sony Bravia TV (2009)' (id=21)
2012-03-12 21:29:18,609 INFO  [WebServer] Socket buffer set to 65535 bytes
2012-03-12 21:29:18,625 INFO  [Device] Created UPnP Device with UUID: 176bd2c1-d24a-315c-b1bf-dec8d968a41a, bound address: 192.168.1.252
2012-03-12 21:29:19,562 INFO  [PluginCompilerThread] Looking for plugins at K:\Serviio\bin\..\plugins
2012-03-12 21:29:19,609 INFO  [PluginCompilerThread] Started looking for plugins
2012-03-12 21:29:25,921 INFO  [AbstractTranscodingDeliveryEngine] Cleaning transcode engine and its data
2012-03-12 21:29:26,703 INFO  [WebServer] WebServer starting on port 8895
2012-03-12 21:29:26,953 INFO  [EventSubscriptionExpirationChecker] Starting EventSubscriptionExpirationChecker
2012-03-12 21:29:26,953 INFO  [EventDispatcher] Starting EventDispatcher
2012-03-12 21:29:26,953 INFO  [DiscoveryAdvertisementNotifier] Starting DiscoveryAdvertisementNotifier
2012-03-12 21:29:27,421 INFO  [RendererSearchSender] Searching for Renderer devices
2012-03-12 21:29:27,421 INFO  [RendererExpirationChecker] Starting RendererExpirationChecker
2012-03-12 21:29:28,875 INFO  [DiscoverySSDPMessageListener] Starting DiscoverySSDPMessageListener using interface eth1 (PLANET WL-8317 54M Wireless LAN PCI Adapter - SecuRemote Miniport) and address 192.168.1.252, timeout = 0
2012-03-12 21:30:36,828 INFO  [FeedUpdaterThread] Started looking for information about online resources
2012-03-12 21:30:36,843 INFO  [LibraryAdditionsCheckerThread] Started looking for newly added files
2012-03-12 21:30:37,296 INFO  [LibraryUpdatesCheckerThread] Started looking for updates to currently shared files
2012-03-12 21:34:21,906 INFO  [ServiioConsole] Starting Serviio Console
2012-03-12 21:34:30,562 INFO  [ServiioConsole] Connecting to Serviio REST on localhost:23423
2012-03-12 21:34:35,312 INFO  [Messages] Loaded console message bundle for locale: es
2012-03-12 21:34:35,328 INFO  [UpdateChecker] Checking if a new version is available
2012-03-12 21:34:40,062 WARN  [DiscoveryAdvertisementNotifier] Could not advertise the device on any available NIC, will try again
2012-03-12 21:34:45,218 WARN  [DiscoveryAdvertisementNotifier] Could not advertise the device on any available NIC, will try again
2012-03-12 21:34:50,343 WARN  [DiscoveryAdvertisementNotifier] Could not advertise the device on any available NIC, will try again
2012-03-12 21:34:55,484 WARN  [DiscoveryAdvertisementNotifier] Could not advertise the device on any available NIC, will try again
2012-03-12 21:34:57,953 INFO  [ContentDirectoryDefinitionParser] Parsing ContentDirectory definition
2012-03-12 21:34:58,328 INFO  [BrowsingCategoriesMessages] Loaded browsing categories message bundle for locale: es
2012-03-12 21:35:01,218 WARN  [DiscoveryAdvertisementNotifier] Could not advertise the device on any available NIC, will try again
2012-03-12 21:35:06,437 WARN  [DiscoveryAdvertisementNotifier] Could not advertise the device on any available NIC, will try again
2012-03-12 21:35:11,734 WARN  [DiscoveryAdvertisementNotifier] Could not advertise the device on any available NIC, will try again
2012-03-12 21:35:17,015 WARN  [DiscoveryAdvertisementNotifier] Could not advertise the device on any available NIC, will try again
2012-03-12 21:35:22,265 WARN  [DiscoveryAdvertisementNotifier] Could not advertise the device on any available NIC, will try again
2012-03-12 21:35:27,515 WARN  [DiscoveryAdvertisementNotifier] Could not advertise the device on any available NIC, will try again
2012-03-12 21:35:32,765 WARN  [DiscoveryAdvertisementNotifier] Could not advertise the device on any available NIC, will try again
2012-03-12 21:35:38,000 WARN  [DiscoveryAdvertisementNotifier] Could not advertise the device on any available NIC, will try again
2012-03-12 21:35:43,125 WARN  [DiscoveryAdvertisementNotifier] Could not advertise the device on any available NIC, will try again
2012-03-12 21:35:48,250 WARN  [DiscoveryAdvertisementNotifier] Could not advertise the device on any available NIC, will try again
2012-03-12 21:35:53,781 WARN  [DiscoveryAdvertisementNotifier] Could not advertise the device on any available NIC, will try again
2012-03-12 21:35:59,000 WARN  [DiscoveryAdvertisementNotifier] Could not advertise the device on any available NIC, will try again
2012-03-12 21:36:04,234 WARN  [DiscoveryAdvertisementNotifier] Could not advertise the device on any available NIC, will try again
2012-03-12 21:36:09,468 WARN  [DiscoveryAdvertisementNotifier] Could not advertise the device on any available NIC, will try again
2012-03-12 21:36:14,671 WARN  [DiscoveryAdvertisementNotifier] Could not advertise the device on any available NIC, will try again
2012-03-12 21:36:19,921 WARN  [DiscoveryAdvertisementNotifier] Could not advertise the device on any available NIC, will try again
2012-03-12 21:36:25,140 WARN  [DiscoveryAdvertisementNotifier] Could not advertise the device on any available NIC, will try again
2012-03-12 21:36:30,359 WARN  [DiscoveryAdvertisementNotifier] Could not advertise the device on any available NIC, will try again
2012-03-12 21:36:35,625 WARN  [DiscoveryAdvertisementNotifier] Could not advertise the device on any available NIC, will try again
2012-03-12 21:36:40,750 WARN  [DiscoveryAdvertisementNotifier] Could not advertise the device on any available NIC, will try again
2012-03-12 21:36:46,140 WARN  [DiscoveryAdvertisementNotifier] Could not advertise the device on any available NIC, will try again
2012-03-12 21:36:51,390 WARN  [DiscoveryAdvertisementNotifier] Could not advertise the device on any available NIC, will try again
2012-03-12 21:36:56,656 WARN  [DiscoveryAdvertisementNotifier] Could not advertise the device on any available NIC, will try again
2012-03-12 21:37:01,953 WARN  [DiscoveryAdvertisementNotifier] Could not advertise the device on any available NIC, will try again
2012-03-12 21:37:07,234 WARN  [DiscoveryAdvertisementNotifier] Could not advertise the device on any available NIC, will try again
2012-03-12 21:37:12,515 WARN  [DiscoveryAdvertisementNotifier] Could not advertise the device on any available NIC, will try again
2012-03-12 21:37:17,921 WARN  [DiscoveryAdvertisementNotifier] Could not advertise the device on any available NIC, will try again
2012-03-12 21:37:23,218 WARN  [DiscoveryAdvertisementNotifier] Could not advertise the device on any available NIC, will try again
2012-03-12 21:37:28,343 WARN  [DiscoveryAdvertisementNotifier] Could not advertise the device on any available NIC, will try again
2012-03-12 21:37:33,593 WARN  [DiscoveryAdvertisementNotifier] Could not advertise the device on any available NIC, will try again
2012-03-12 21:37:38,890 WARN  [DiscoveryAdvertisementNotifier] Could not advertise the device on any available NIC, will try again
2012-03-12 21:37:44,140 WARN  [DiscoveryAdvertisementNotifier] Could not advertise the device on any available NIC, will try again
2012-03-12 21:37:49,375 WARN  [DiscoveryAdvertisementNotifier] Could not advertise the device on any available NIC, will try again
2012-03-12 21:37:54,640 WARN  [DiscoveryAdvertisementNotifier] Could not advertise the device on any available NIC, will try again
2012-03-12 21:37:59,875 WARN  [DiscoveryAdvertisementNotifier] Could not advertise the device on any available NIC, will try again
2012-03-12 21:38:05,125 WARN  [DiscoveryAdvertisementNotifier] Could not advertise the device on any available NIC, will try again
2012-03-12 21:38:10,375 WARN  [DiscoveryAdvertisementNotifier] Could not advertise the device on any available NIC, will try again
2012-03-12 21:38:15,656 WARN  [DiscoveryAdvertisementNotifier] Could not advertise the device on any available NIC, will try again
2012-03-12 21:38:20,921 WARN  [DiscoveryAdvertisementNotifier] Could not advertise the device on any available NIC, will try again
2012-03-12 21:38:26,171 WARN  [DiscoveryAdvertisementNotifier] Could not advertise the device on any available NIC, will try again
2012-03-12 21:38:31,390 WARN  [DiscoveryAdvertisementNotifier] Could not advertise the device on any available NIC, will try again
2012-03-12 21:38:36,640 WARN  [DiscoveryAdvertisementNotifier] Could not advertise the device on any available NIC, will try again
2012-03-12 21:38:41,906 WARN  [DiscoveryAdvertisementNotifier] Could not advertise the device on any available NIC, will try again
2012-03-12 21:38:47,171 WARN  [DiscoveryAdvertisementNotifier] Could not advertise the device on any available NIC, will try again
2012-03-12 21:38:52,296 WARN  [DiscoveryAdvertisementNotifier] Could not advertise the device on any available NIC, will try again
2012-03-12 21:38:57,828 WARN  [DiscoveryAdvertisementNotifier] Could not advertise the device on any available NIC, will try again
2012-03-12 21:39:03,109 WARN  [DiscoveryAdvertisementNotifier] Could not advertise the device on any available NIC, will try again
2012-03-12 21:39:08,359 WARN  [DiscoveryAdvertisementNotifier] Could not advertise the device on any available NIC, will try again
2012-03-12 21:39:13,593 WARN  [DiscoveryAdvertisementNotifier] Could not advertise the device on any available NIC, will try again
2012-03-12 21:39:18,843 WARN  [DiscoveryAdvertisementNotifier] Could not advertise the device on any available NIC, will try again
2012-03-12 21:39:24,093 WARN  [DiscoveryAdvertisementNotifier] Could not advertise the device on any available NIC, will try again
2012-03-12 21:39:29,328 WARN  [DiscoveryAdvertisementNotifier] Could not advertise the device on any available NIC, will try again
2012-03-12 21:39:34,562 WARN  [DiscoveryAdvertisementNotifier] Could not advertise the device on any available NIC, will try again
2012-03-12 21:39:39,859 WARN  [DiscoveryAdvertisementNotifier] Could not advertise the device on any available NIC, will try again
2012-03-12 21:39:45,093 WARN  [DiscoveryAdvertisementNotifier] Could not advertise the device on any available NIC, will try again
2012-03-12 21:39:50,218 WARN  [DiscoveryAdvertisementNotifier] Could not advertise the device on any available NIC, will try again
2012-03-12 21:39:55,625 WARN  [DiscoveryAdvertisementNotifier] Could not advertise the device on any available NIC, will try again
2012-03-12 21:50:55,890 INFO  [WebServer] WebServer shutting down
2012-03-12 21:50:55,890 INFO  [DiscoveryAdvertisementNotifier] Leaving DiscoveryAdvertisementNotifier
2012-03-12 21:50:55,890 INFO  [EventSubscriptionExpirationChecker] Leaving EventSubscriptionExpirationChecker, removing all event subscriptions
2012-03-12 21:50:55,890 INFO  [EventDispatcher] Leaving EventDispatcher
2012-03-12 21:50:56,171 INFO  [Device] Updated bound IP address of Device with UUID: 176bd2c1-d24a-315c-b1bf-dec8d968a41a, bound address: 192.168.1.252
2012-03-12 21:50:56,187 INFO  [WebServer] WebServer starting on port 8895
2012-03-12 21:50:56,187 INFO  [RendererSearchSender] Searching for Renderer devices
2012-03-12 21:50:56,187 INFO  [EventDispatcher] Starting EventDispatcher
2012-03-12 21:50:56,187 INFO  [DiscoverySSDPMessageListener] Starting DiscoverySSDPMessageListener using interface eth1 (PLANET WL-8317 54M Wireless LAN PCI Adapter - SecuRemote Miniport) and address 192.168.1.252, timeout = 0
2012-03-12 21:50:56,187 INFO  [DiscoveryAdvertisementNotifier] Starting DiscoveryAdvertisementNotifier
2012-03-12 21:50:56,187 INFO  [EventSubscriptionExpirationChecker] Starting EventSubscriptionExpirationChecker
2012-03-12 21:50:57,421 INFO  [RendererExpirationChecker] Leaving RendererExpirationChecker
2012-03-12 21:50:59,968 INFO  [WebServer] WebServer shutting down
2012-03-12 21:50:59,968 INFO  [DiscoveryAdvertisementNotifier] Leaving DiscoveryAdvertisementNotifier
2012-03-12 21:50:59,968 INFO  [EventSubscriptionExpirationChecker] Leaving EventSubscriptionExpirationChecker, removing all event subscriptions
2012-03-12 21:50:59,968 INFO  [EventDispatcher] Leaving EventDispatcher
2012-03-12 21:51:01,406 INFO  [WebServer] WebServer starting on port 8895
2012-03-12 21:51:01,406 INFO  [EventSubscriptionExpirationChecker] Starting EventSubscriptionExpirationChecker
2012-03-12 21:51:01,406 INFO  [EventDispatcher] Starting EventDispatcher
2012-03-12 21:51:01,406 INFO  [RendererSearchSender] Searching for Renderer devices
2012-03-12 21:51:01,406 INFO  [DiscoveryAdvertisementNotifier] Starting DiscoveryAdvertisementNotifier
2012-03-12 21:51:01,406 INFO  [DiscoverySSDPMessageListener] Starting DiscoverySSDPMessageListener using interface eth1 (PLANET WL-8317 54M Wireless LAN PCI Adapter - SecuRemote Miniport) and address 192.168.1.252, timeout = 0
2012-03-12 23:04:50,968 WARN  [IndexedDiskCache] Region [thumbnails] Disk cache not shutdown properly, shutting down now.
2012-03-12 23:04:50,968 WARN  [IndexedDiskCache] Region [online_technical_metadata] Disk cache not shutdown properly, shutting down now.
2012-03-12 23:04:50,984 INFO  [LibraryAdditionsCheckerThread] Finished looking for newly added files
2012-03-12 23:04:51,078 INFO  [LibraryUpdatesCheckerThread] Finished looking for updates to currently shared files
2012-03-12 23:04:51,171 INFO  [FeedUpdaterThread] Finished looking for online resources information
2012-03-12 23:04:51,281 INFO  [PluginCompilerThread] Finished looking for plugins
2012-03-12 23:04:51,375 INFO  [WebServer] WebServer shutting down
2012-03-12 23:04:51,375 INFO  [DiscoveryAdvertisementNotifier] Leaving DiscoveryAdvertisementNotifier
2012-03-12 23:04:51,375 INFO  [EventDispatcher] Leaving EventDispatcher
2012-03-12 23:04:51,375 INFO  [EventSubscriptionExpirationChecker] Leaving EventSubscriptionExpirationChecker, removing all event subscriptions
2012-03-12 23:04:51,531 INFO  [DatabaseManager] Shutting down database
2012-03-12 23:04:51,968 INFO  [AbstractTranscodingDeliveryEngine] Cleaning transcode engine and its data
2012-03-12 23:04:53,375 INFO  [ServiioConsole] Leaving Serviio Console
Thank you very much.
Post Tue Mar 13, 2012 1:31 pm
Is 192.168.1.252 the fixed IP of the PC?
also there is an error message about it not being able to advertise itself. Possibly multicast is not enabled on your NIC or network (router)?
jme
Post Tue Mar 13, 2012 2:37 pm
zip wrote:Is 192.168.1.252 the fixed IP of the PC?
Hi again,
Yes, the fixed PC IP is 192.168.1.252.
Over multicast, I will check router options and change this if it proceeds, but I don't believe it causes the problem because in that case it doesn't work anyway with my netbook. Netbook and PC are connected to LAN with same wireless router, then I think the problem it's on PC.
Thank you again.
jme
Post Wed Mar 14, 2012 8:18 am
One more question ... the multicast can depend on the OS in use? In that case, where's the option/s to enable/disable this in Windows XP?
EDIT: I have checked router options and I have multicast enabled ... I'm lost :(, the only one thing I can do it's format PC and come to begin ...
Thank you all.
