Serviio not starting
Louise87
Post Wed Mar 14, 2012 7:00 pm
Hello
Kinda new at this
Serviio is installed and has been working before.
However, it stopped working, så I tried to remove it and re-install it.
This lead to:
Clicking on Serviio Console gives a short period "hourglass" time. Nothing else happens.
Serviio is set to open when windows starts, but doesn't.
Serviio is under "exceptions" in windows firewall.
Serviio isn't seen when "Ctrl+alt+delete" to check job-list.
I don't know what to do. Windows updated itself recently and it might be a coincidence... Or it might not...
Anyone has any ideas?
serviio-buddy
Post Wed Mar 14, 2012 8:37 pm
Re: Serviio not starting
You can try to start serviio manually.
From Windows Vista and other similar Windows systems:
1. Click Start (bottom left)
2. Click on "All Programs", find Serviio folder and click it.
3. Find "Start Serviio service" and right click on it choosing "Run as administrator"
4. Wait a few seconds for Serviio service to start, then start the "Serviio Console" the way you usually do.
serviio-buddy
SONY SMP-N100 Media Player, HP PC: Vista 32/Ubuntu 11.10, Serviio 0.6.2, XBMC, VLC, ASUS eeePC Netbook: Vista 32, XBMC, SHARP Aquos BD-HP25U DLNA Blu-Ray Player
HowTo: Provide supported formats of a device | Record a new ticket on Bitbucket | Provide details of a video file that doesn't play | Turn on detailed logging
Louise87
Post Thu Mar 15, 2012 8:48 am
I'm using windows XP
I tried to do as asked, "Run as administrator", but it says for it to work there needs to be a password, as the password-column cannot be blank. I have no password.
Post Thu Mar 15, 2012 9:08 am
Can you post the serviio.log file?
Louise87
Post Thu Mar 15, 2012 10:05 am
How do I do that?
I've checked the Serviio installation folder and the folder called "log" is empty, if that was what you meant...
serviio-buddy
Post Sun Mar 18, 2012 4:35 am
If it is asking for a password when you "Run as administrator", enter your Windows login password and see if that works.
The Serviio log is located usually on a Windows system at: C:\Program Files\Serviio\log and is called serviio.log, but if you can't start the Serviio service, there might not be a log there as you have said.
serviio-buddy
Jimmi
Post Sun Apr 22, 2012 7:20 pm
Hi there
I am having the same trouble and have tried all of the above. So frustrating!
I have Windows 7 64 Bit. I haven't managed to get it to open at all, it is connecting to my TV fine but can't open the console to setup properly. When I click on the console, it l like it thinks about it then does nothing!
My log is attached. Please help!
Jimmi
(22.67 KiB) Downloaded 881 times
Post Sun Apr 22, 2012 11:13 pm
try to update your Java.
