Service Topfield .REC files
I understand that the files are TS and possibly mpeg2.
VLC can play these directly without issue.
I am currently only watching on PCs/Laptops on my network as I don't have a fanct telly yet!
buttons wrote:No, and as you can see no replies here either..
C:\Program Files\Serviio\lib>ffmpeg.exe -i "C:\Users\Manning\Videos\The Office.mpg"
nfig
libavutil 51. 32. 0 / 51. 32. 0
libavcodec 53. 42. 0 / 53. 42. 0
libavformat 53. 24. 0 / 53. 24. 0
libavdevice 53. 4. 0 / 53. 4. 0
libavfilter 2. 53. 0 / 2. 53. 0
libswscale 2. 1. 0 / 2. 1. 0
[mp3 @ 0315bb60] Header missing
[mpegts @ 014181a0] max_analyze_duration 5000000 reached at 5016000
[NULL @ 03167cc0] start time is not set in estimate_timings_from_pts
[mpegts @ 014181a0] PES packet size mismatch
Input #0, mpegts, from 'C:\Users\Manning\Videos\The Office.mpg':
Duration: 00:29:55.36, start: 58229.206522, bitrate: 4381 kb/s
Program 1569
service_name : ONE
service_provider: Ten Sydney
Program 1573
service_name : TEN Digital
Program 1575
service_name : ONE
service_provider: TEN Sydney
Program 1576
service_name : ELEVEN
Stream #0:0[0x204]: Video: mpeg2video (Main) ([2][0][0][0] / 0x0002), yuv420
p, 720x576 [SAR 64:45 DAR 16:9], 9000 kb/s, 25 fps, 25 tbr, 90k tbn, 50 tbc
Stream #0:1[0x2a9](eng): Audio: mp2 ([4][0][0][0] / 0x0004), 48000 Hz, stere
o, s16, 256 kb/s (clean effects)
Stream #0:2[0x242](eng): Subtitle: dvb_teletext ([6][0][0][0] / 0x0006)
Stream #0:3[0x1fd2]: Unknown: none ([11][0][0][0] / 0x000B)
Complete name : C:\Users\Manning\Videos\The Office.mpg
Format : MPEG-TS
File size : 938 MiB
Duration : 29mn 55s
Overall bit rate : 4 382 Kbps
Menu ID : 1576 (0x628)
Format : MPEG Video
Format version : Version 2
Format profile : Main@Main
Format settings, BVOP : Yes
Format settings, Matrix : Custom
Format settings, GOP : M=3, N=12
Codec ID : 2
Duration : 29mn 55s
Bit rate mode : Variable
Bit rate : 3 907 Kbps
Maximum bit rate : 9 000 Kbps
Width : 720 pixels
Height : 576 pixels
Display aspect ratio : 16:9
Frame rate : 25.000 fps
Standard : PAL
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Interlaced
Scan order : Top Field First
Compression mode : Lossy
Bits/(Pixel*Frame) : 0.377
Stream size : 836 MiB (89%)
Format : MPEG Audio
Format version : Version 1
Format profile : Layer 2
Codec ID : 4
Duration : 29mn 55s
Bit rate mode : Constant
Bit rate : 256 Kbps
Channel(s) : 2 channels
Sampling rate : 48.0 KHz
Delay relative to video : -477ms
Stream size : 54.8 MiB (6%)
Language : English
Language, more info : Clean effects
Text
ID : 578 (0x242)-801
Format : Teletext Subtitle
Language : English
Menu
List : 516 (0x204) (MPEG Video) / 578 (0x242) () / 681 (0x2A9) (MPEG Audio, English)
Language : / / English
Service name : ELEVEN
Service provider : Ten Sydney
Service type : digital television
<Profile id="12" name="Panasonic Viera" extendsProfileId="1">
<MediaFormatProfiles>
</MediaFormatProfiles>
<!-- Topfield .REC files transcpdong -->
<Video targetContainer="mpegts" targetACodec="ac3" forceVTranscoding="true" >
<Matches container="mpegts" vCodec="mpeg2video" aCodec="mp2"/>
<!-- remux DTS/FLAC/LPCM in MKV/MP4 to AC3 -->
<Matches container="matroska" vCodec="h264" aCodec="dca" />
<Matches container="mp4" vCodec="h264" aCodec="lpcm"/>
<!-- Remux all h264 video to MPEG-TS stream -->
<Matches container="matroska" vCodec="mpeg2video"/>
<!-- unsupported codecs will be transcoded into mpeg-ts, mpeg2 video and ac3 audio -->
<Matches container="asf" />
<Matches container="flv" />
<Matches container="ogg" />
<Matches container="3gp" />
<Audio targetContainer="mp3">
<Matches container="mp4" />
<Matches container="flac" />
<Matches container="adts" />
</Audio>
</Profile>Return to Serviio Support & Help
Users browsing this forum: No registered users and 61 guests
