Zenfolio images
repeters
Post Fri Mar 16, 2012 1:27 pm
Zenfolio images
I have quite a few images stored on Zenfolio.com that I would like to render on my Panasonic TC-P50ST50.
Everything I have stored locally works fine but when I enter the url for my galleries in the "Online Sources" section of the "Library"I don't see anything. I'm obviously missing something.
How do I access my galleries?
Thanks,
Bob
Post Fri Mar 16, 2012 3:38 pm
Re: Zenfolio images
do they publish rss feeds with your galleries?
repeters
Post Fri Mar 16, 2012 4:05 pm
Re: Zenfolio images
I believe they do but I haven't been able to make sense of the instructions. I've posted a comment on the Zenfolio forum to see what can be done.
Do you have any suggestions?
Thanks,
Bob
Post Fri Mar 16, 2012 5:15 pm
Re: Zenfolio images
I don't know that service, but you need the rss feed URL so that you can enter that in the console as an image feed url.
repeters
Post Fri Mar 16, 2012 8:36 pm
Re: Zenfolio images
Thanks, Petr.
I was on the right track (thanks to you) but Zenfolio appears to be creating the wrong url or serviio is expecting an incorrect url. Smart money says the problem is most likely Zenfolio. Here is what happened.
When I requested an RSS feed, Zenfolio created the url "feed://repeters.zenfolio.com/p307724844/recent.atom". When I entered that url and chose "Save" serviio said the url was invalid. So, making a guess, I changed 'feed' to 'http' and everything worked as expected.
Is Zenfolio creating an incorrect url?
And thank you for creating serviio. This program is very easy to use and works as expected. :D :D :D
Bob
Post Sat Mar 17, 2012 11:05 am
Re: Zenfolio images
yes, feed:// is not supported, if it works with http:// you're all set.
Return to User experiences
