serviio 0.6.0.1 on WHS with HP mediaconnect
serviio-buddy
Post Mon Mar 19, 2012 12:08 am
Re: serviio 0.6.0.1 on WHS with HP mediaconnect
I don't know if it's related to that microsoft upnp auth.
It looks like it's communicating properly with the MediaSmart Connect device from looking at the log file.
Do you have the MediaSmart Gateway software installed on the Serviio Server PC ? If so, try disabling it and see if that does anything.
serviio-buddy
SONY SMP-N100 Media Player, HP PC: Vista 32/Ubuntu 11.10, Serviio 0.6.2, XBMC, VLC, ASUS eeePC Netbook: Vista 32, XBMC, SHARP Aquos BD-HP25U DLNA Blu-Ray Player
HowTo: Provide supported formats of a device | Record a new ticket on Bitbucket | Provide details of a video file that doesn't play | Turn on detailed logging
pbbbum
Post Mon Mar 19, 2012 7:15 am
Why is there a service event subscription event in 0.6.0.2 for microsoft.com:serviceId:X_MS_MediaReceiverRegistrar for the HPMSC renderer? This event was not generated in 0.5.0.2, and the resulting flow allowed the renderer to successfully connect.
I could see trying all these things - uplevel Java, uninstall MediaSmart Gateway, etc., if I couldn't get any version of serviio to work properly. But the fact that the previous version of serviio is working with the renderer tells me that something was introduced in the new version that breaks the established authorization.
I remember reading somewhere that a compliant renderer device - which the HPMSC is - needs proper authorization from the server to connect. It might possibly be that the HPMSC auth flow that happens when the HPMSC Windows Media Extender connects to the Vista server (which happens before serviio is started) establishes the authorization, then the new uPnp registration event that serviio 0.6.0.2 executes breaks the authorization. Since the Registrar/authorization event isn't done in 0.5.0.2, the renderer effectively "rides on the coattails" of the already established authorization for the device.
I am by no means an expert in windows media streaming... :-) I work at Hewlett-Packard in software development, but not in this area. And unfortunately the HPMSC development team has long since disbanded. I know there are a lot of HPMSC owners out there that would LOVE to have serviio, it is lightyears ahead of the braindead built-in Windows support. I hope we can figure this out!
serviio-buddy
Post Mon Mar 19, 2012 7:33 am
I just thought that disabling the MediaSmart Gateway possibly had something to do with the pre-authorization if this microsoft auth event was just added in 0.6.2
I am also not an expert at this Serviio since I just have been using it for about 1 month or so.
It does make sense what you're saying about the MeidaSmart Connect gets an auth from the Vista server first, then the Serviio server reissues it and that's when it fails.
serviio-buddy
pbbbum
Post Mon Mar 19, 2012 4:07 pm
Ah! OK! (About MediaSmart Gateway). I plan to test the setup with a fresh Vista system, without the MediaSmart software. That will test my theory.
serviio-buddy
Post Mon Mar 19, 2012 4:48 pm
OK, will wait for your results.
serviio-buddy
J0hnb0y
Post Thu Oct 04, 2012 12:27 pm
I just deployed a two of these HP Media Connect systems in my setup. I recently moved to SERViiO as my primary media server. I am experiencing the same problem listed in this thread only with the 1.0.1 release level of SERViiO.
Has this issue been resolved? Is there a "workaround"?
Please note that TVersity is not experiencing this issue. I activated Media Smart Server (WHS) to test this.....
Thanks....
Post Thu Oct 04, 2012 1:40 pm
what problem is it?
Previous
Return to User experiences
Users browsing this forum: Bing [Bot] and 2 guests
