Google Music
• Page 1 of 1
any body else want google music?
Re: Google Music
I would love to be able to listen to my music from my Google Music (Google Play) through Serviio. I would give this idea a huge thumbs up...
Does Google have an API for this yet?
Re: Google Music
yes yes yes!
Re: Google Music
I've built an unofficial api, and it currently supports everything needed to build a plugin: https://github.com/simon-weber/Unoffici ... -Music-API.
I don't know anything about serviio; I'd imagine you'd need a java port? That wouldn't be too tough for someone with some java chops.
Re: Google Music
Seems to be not much progress since the post half a year ago.
Beeing able to stream my Music from Google Music directly through Serviio to my A/V Receiver would be outstanding.
Re: Google Music
As a heads up, Java ports do exist now. Check under the "Ports" section of: https://github.com/simon-weber/Unofficial-Google-Music-API.
Re: Google Music
A google music plugin would be definately awesome ! I'll look if I can make one.
Cheers.
Cheers.
Re: Google Music
I just subscribed to GMAA streaming works fine with bubbleupnp but it would be awesome to use serviio for syncing to google!
@pna: is your plugin ready for beta-testing?
Thx in advance
Thx in advance
Re: Google Music
i want ask if there is any news about this plugin. It will be great when i can listening music from google music cloud. Or if there is another option how i can listen music from cloud on receiver.
thx
thx
Re: Google Music
something new on this issue?
I agree, having Gmusic support included into Serviio would be great!!!
olili
olili
• Page 1 of 1
