Serviio and Avast 7 IS = problem
Scoty
Post Mon Mar 19, 2012 4:29 pm
I have install the new Avast 7 IS and have troubles with Serviio. Serviio working fine with Videos on my HDD but whene i enter a Online Stream Serviio will not work. I see only "Load" on my Samsung D TV. Whene i remove the Online Stream this not solved the Problem. Whene i uninstall Serviio and make a new install Serviio working finde on my TV but only with Videos on my HDD. I have give Serviio all rights on the Firewall. What can i do?
jabrown0604
Post Mon Mar 19, 2012 5:09 pm
Re: Serviio and Avast 7 IS = problem
It looks like Avast has a firewall built in. I would check to see if you can disable the firewall. If this fixes the issue then you will need to set up an exception in the Avast firewall to allow serviio to contact the internet feeds.
This is assuming you gave serviio rights to the Windows Firewall not Avast.
“Those who have succeeded at anything and don’t mention luck are kidding themselves.”
Server-Mac Mini / OS-WHS 2011 SP1 / TV/HTS-Sharp Aquos/Samsung HT-C6600
Scoty
Post Mon Mar 19, 2012 5:22 pm
My Windows Firewall is disabled. Witch rules i need vor Avast?
Here a Screenshot. You can see Serviio have full right, in and out.
Post Mon Mar 19, 2012 5:33 pm
you might also give access to ffmpeg.exe in the Serviio install directory
Scoty
Post Mon Mar 19, 2012 5:39 pm
Ok but i dont see ffmpeg.exe.
Edit: I have manuell add this. I will test this morning.
jabrown0604
Post Mon Mar 19, 2012 9:26 pm
zip wrote:you might also give access to ffmpeg.exe in the Serviio install directory
Does ffmpeg traverse port 80, or is it setup on another port.
Post Tue Mar 20, 2012 9:21 am
depends on the port of the stream....it's only incoming traffic though
Return to General discussion
