Online streams categories
scrissti
Post Sun Mar 25, 2012 6:51 pm
i have loads(hundreds) of online movies and i would like to make them all available on the TV.
By default it seems that using an online plugin puts each WebResourceItem in the /Online.
I would like to make some kind of folders, per genre for example.
If this is not possible in the online folder, would be possible to put them in the "Folders" folder?
Post Sun Mar 25, 2012 6:55 pm
Re: Online streams categories
Not at this moment, online folders will come at some point in future
Post Sun Mar 25, 2012 8:58 pm
Simple to do. http://wiki.serviio.org/doku.php?id=live_stream_folders
Just alter the Live_Feeds.groovy to Local_Feeds.groovy by removing the forced "live" return. I've tested this with my local php server but obviously you would not do it for files that you can access directly over the network eg: smb.
Return to Plugin development
