Internet Radio Stations...
Christopher_Povey
Post Sun Apr 03, 2011 2:07 pm
Would it be possible to add support to stream online radio stations, like for example, from RadioPlayer. Or less mainstream sources?
Chris
Running Serviio on Intel Q6700 Windows 7 Ultimate x64 PC feeding a Sony BDP-S570, Pansonic TX-L37G20B, and a XBox 360.
Managed with Serviidroid via HTC One X
Post Sun Apr 03, 2011 2:19 pm
Re: Internet Radio Stations...
Christopher_Povey wrote:Would it be possible to add support to stream online radio stations, like for example, from RadioPlayer. Or less mainstream sources?
shoutcast and icecast support should not be to hard to add once ZIP starts intergrating online video sources :) but that would be for a future release. :)
Wingsgb
Post Fri Mar 16, 2012 6:43 pm
Old post to bring up but is this possible now "online sources" is available.
There are quite Afew radio feed Il'd like to listen to which a through Radioplayer, talksport being the main station along with local stations. Is a plugin needed for this? I can manage to snoop the urls I want.
Post Fri Mar 16, 2012 9:51 pm
Add your snooped URL's as audio livestreams or use the shoutcast plugin for 10 top stations.
Post Sat Mar 17, 2012 11:06 am
check this one out : viewtopic.php?f=20&t=5096
Christopher_Povey
Post Mon Mar 26, 2012 1:35 pm
Cool! I'll give that a go... :)
Chris
Return to Feature requests
