listen serviio on multiple IP address
oleane
Post Mon Mar 26, 2012 6:41 pm
I have a computer with multiple network cards with different IP addresses:
192.168.0.1/255.255.255.0
172.17.0.1/255.255.0.0
10.42.100.1/255.255.255.0
Currently, serviio listening on a single address, how to listen on all?
Thank.
Post Mon Mar 26, 2012 7:04 pm
Re: listen serviio on multiple IP address
Only one is possible
oleane
Post Mon Mar 26, 2012 7:15 pm
okay, thank you!
there will be an evolution of serviio to manage multiple IP addresses?
Post Mon Mar 26, 2012 7:16 pm
Not in the scope atm
Strupniveral
Post Thu Mar 29, 2012 9:04 pm
you should be able to get what you are looking food forwarding the port serviio is listening on from the other two interfaces to the one where serviio is actually on.
e.g, i serviio is listening on 192.168.0.1:12345, you can set two rules like the following in your firewall:
172.17.0.1:12345 --> 192.168.0.1:12345
10.42.100.1:12345 --> 192.168.0.1:12345
IF they aren't static IPS but obtained via DHCP, you can try to use the interface name rather then the IP.
jabrown0604
Post Fri Mar 30, 2012 12:32 am
Strupniveral wrote:you should be able to get what you are looking food forwarding the port serviio is listening on from the other two interfaces to the one where serviio is actually on.
I don't believe this would work as is. As the server may listen but it also lets devices know that it is there by broadcasting and receiving information from devices on certain ports. If I am not mistaken that is UDP port 1900. Without port 1900 the server will stay hidden on the other network ports even though the listening port is available. I would say for it to work you would need to forward all ports that are associated with serviio using the method Strupniveral suggested.
“Those who have succeeded at anything and don’t mention luck are kidding themselves.”
Server-Mac Mini / OS-WHS 2011 SP1 / TV/HTS-Sharp Aquos/Samsung HT-C6600
Strupniveral
Post Fri Mar 30, 2012 8:41 am
Port 1900 is listening on all interfaces, at least in my case; just 1 port is bound to 1 ip address, the others are bound to *.
But yes, best approach is to get all the ports serviio is listening on and repeat above rules for all ports not listening on *
jabrown0604
Post Fri Mar 30, 2012 12:16 pm
Strupniveral wrote:Port 1900 is listening on all interfaces, at least in my case; just 1 port is bound to 1 ip address, the others are bound to *.
You realize I am going to have to set this up on my machine now to tinker. I hate being a chronic tinkerer sometimes.
airdrummingfool
Post Sun Apr 22, 2012 8:19 pm
jabrown et al,
Any progress on this? I'd love to set up forwarding between two interfaces. I have my standard network - which Serviio works GREAT on - and I just installed Hamachi to try and stream over the internet while I am away from home.
shurid
Post Sat Oct 12, 2013 9:11 am
I have made it work with Network bridging. I bridge between my internal LAN (Connected to TV) and WiFi LAN connected to Router, which connects to all other devices, such as Smart Phone, Tabs & other computers.
For me My TV also takes IP from router and in Serviio I Bound the PC IP. So, both connectivity is connected to Router and all devices from both interface can use this DNLA Server. I even able to play into TV from my android phone "HTC ONE", I browse serviio and as player I choose TV, which is also visible in my player.
My TV is Samsung C630, for Android I am using MediaHouse.
Spectre
Post Sat Nov 19, 2022 7:24 pm
Any news on this topic? 10 years have passed...
Post Sat Nov 19, 2022 7:28 pm
Nothing can be done from the Serviio side of things. The DLNA standard controls the way it works on the network, and Serviio operates per the standard. You have to get fancy with network routing when you want to span multiple networks.
Users browsing this forum: Baidu [Spider] and 97 guests
