kanal9play (Sweden only)
• Page 1 of 1
Is there a chance that someone can make a plugin for the excellent swedish kanal 9. On my wanting list you can also find a new groovy file for Swedish TV8. The existing on does not work very well.
Re: kanal9play (Sweden only)
I'll look into it when I have the time. I want to make one for Kanal 5 as well.
FoH wrote:I'll look into it when I have the time. I want to make one for Kanal 5 as well.
It seems that Kanal 5 and Kanal 9 uses the same solution. I've only managed to get the rtmp link required by packet sniffing, and as far as I know that's not an option for developing a plugin. I need to find another solution.
Panasonic Viera D25
Thanks FoH, I'm also checking the possibilities.
The data I'm having are: (let's see an example), these might help:
RSS: http://www.kanal9play.se/rss?type=PROGRAM
Link: http://www.kanal9play.se/program/play/4 ... dag-s01e38
def linkUrl : http://www.kanal9play.se/program/play/1244025896001 (this number is the Prog ID)
example of match:
rtmpe://fl1.c10549.cdn.qbrick.com/10549 ... 5277-1.mp4
swfUrl=http://admin.brightcove.com/viewer/us1.25.04.01.2011-05-24182704/connection/ExternalConnection_2.swf
thumbnail: http://kanal5images.appspot.com/image/q ... /image.jpg
"def url" that stores the program link? No idea for this one! Viasat playkanals are having this but what can it be for 5an or 9an?
example of match:
Panasonic Viera D25
That's pretty much what I found out with packet sniffing. The problem as I see it is the rtmpe url. You've got the programID in there, but I don't know (yet) what the other numbers are so I can't generate that url. I'm gonna poke around in the page source code and see if I can find those numbers somewhere else, maybe a player ID or something.
I don't know of any other methods for aquiring it anyway. Do you?
No I don't, either.
But I've checked several Kanal5 and 9 shows and found out that the number 22710239001 is the same in every rtmpe links.
Panasonic Viera D25
muszaj wrote:No I don't, either.![]()
Yeah, I think that's some sort of client ID that BrightCove keeps track of. Both the Program ID and client ID exists in the page source, so those can be parsed for. It's only the last number that's a problem...
Edit: I haven't checked if that's the same as well thought!
• Page 1 of 1
Users browsing this forum: No registered users and 198 guests
