Unable to connect with my Regza VL863
TM2002
Post Wed Mar 28, 2012 10:07 am
I installed serviio on my computer, I can see the IP adress of my TV on serviio console.
I have a green spot on the left.
I shared a path containing my videos.
my TV is is connected to my rooter by cable. my computer is connected by wifi
my TV Is unable to detect the DMS (server) : in "setting the media player" menu the "setting the media server" is not active.
thank you in advance for your support
TM2002
Post Wed Mar 28, 2012 7:20 pm
Re: Unable to connect with my Regza VL863
I also tried VLC 2.0.1. When checking "universal plug n play", serviio does not appear.
also when I check network connections from the config panel (windows XP) I don't see serviio server.
I remind you that from my servioo console, I see my TV with the green point on the left
Please help !!!! :(
Post Fri Mar 30, 2012 12:51 pm
TM2002
Post Fri Mar 30, 2012 1:37 pm
Yes I red that and I solved the problem :D.
Thank you,
please if you know how optimizing transcoding please reply to me here :
viewtopic.php?f=26&t=5802
Return to Toshiba
