Sony Bravia 2010 series
mcine
Post Wed Oct 20, 2010 2:55 pm
Re: [Profile] Sony Bravia 2010 series (EX4, EX5, EX6, EX7, HX7)
Hey
I got bravia 40ex700 and I installed servioo to mythbuntu (ubuntu with mythtv).
I have this problem that I can see the server and the shares, but not any files or subdirectories. I have tried couple of profiles from this thread but same situation.
I cannot see pictures, video or music. ..
Any ideat what could be wrong here ?
tombert
Post Wed Oct 20, 2010 6:16 pm
Same problem ... added a folder, forced refresh, profile is Sony Bravia ... but can't see no files ...
Post Thu Oct 21, 2010 7:07 am
Vedo
Post Sun Oct 24, 2010 10:28 pm
I had the same problem: Serviio server recognized by Bravia EX710, folders shown but allegedly empty. I took a wild shot and entered the notebook IP address into the console settings, and everything worked like charm (including video!).
I still have 2 problems, though.
    My provider uses DHCP so I cannot be sure that the IP address I entered will be the same next time around. I would like to find a way to leave the IP box blank
    I cannot use Serviio over WiFi: the Bravia doesn't see the Serviio server
Thanks in advance
Post Sun Oct 24, 2010 10:49 pm
What is your provider? I have a router and setup my DHCP table to always give ny PC the same IP. Your wireless adapter has got a different IP address, you'll have to change it in the console.
Vedo
Post Mon Oct 25, 2010 6:08 am
Thank you. I'm in Italy and my provider is Fastweb: they assign 4 IP addresses to my household, and each PC gets their IP on a first come first served basis. If I understand you, should I provide the relevant IP to Serviio each time? That can be done; however, at my first attempt, I still couldn't go wireless.
The Fastweb modem serves as a WiFi access point as well, and it's not programmable.
Post Mon Oct 25, 2010 8:06 am
Vedo wrote:Thank you. I'm in Italy and my provider is Fastweb: they assign 4 IP addresses to my household, and each PC gets their IP on a first come first served basis. ...The Fastweb modem serves as a WiFi access point as well, and it's not programmable.
I don't understand...4 IP adresses to your household ? Do you have an admin access to manage your Fastweb box? Does your box is also a router?
For me, with my french Orange provider, I use an ADSL-&-Router Box with only one IP address on WWW size (this size is not programmable).
On home local network size (manageable), I have an IP range from 192.168.1.1 to 192.168.1.20 without DHCP server, and a DHCP range starting from 192.168.1.21 to 192.168.1.255
My box have 192.168.1.1 fix address, and all my devices have a fix address, Printer(192.168.1.2), TV(192.168.1.3), BlueRayPlayer(192.168.1.4)....PCWire with Serviio (192.168.1.12).
If your PC use Wire-Lan and Wifi-Lan with two different IP address, on Serviio Console set the Bound IP address field with PC WireLan IP address (best bandwidth).
Vedo
Post Mon Oct 25, 2010 8:25 am
Thank you.
In the past, Fastweb gave me a non WiFi modem. I had a WiFi router that worked exactly as you describe in your post. Eventually, they replaced the modem with a modem/WiFi access point combo (not a router, and it's not ADSL but fiberglass). They assign me 4 IP addresses, and each PC has a unique IP address which is projected to the company's NAT(the 4 addresses are in the form *.*.*.186 to *.*.*.189). This is the best I can come up with (sorry I'm not very technical).
I've tried what Zip suggested, and entered the WiFi IP in the box, but this doesn't change things (still the Bravia doesn't see Serviio). While wired, everything is OK: it looks like the wired and wireless part of the modem work differently. I can only change password for the WiFi settings: other options are not accessible. I could, however, disable WiFi in the modem and revive my old WiFi router, and see what happens.
Post Mon Oct 25, 2010 8:42 am
can you execute the following command and post the contents of file c:\ipconfig.txt here?
ipconfig /all > c:\ipconfig.txt
Vedo
Post Mon Oct 25, 2010 12:18 pm
While going wireless, wired or both?
BTW: thank you for you longstanding support.
Post Mon Oct 25, 2010 12:29 pm
If you leave the Bound IP field empty on Serviio Console, the server take the first eth device found (that could be the Wireless Eth controller, could check on detailed serviio log file).
For HD video streaming (30Mbps max) the Wire is preferred, so set the IP of the Wire Eth Controller on console to force Serviio using it (Check in detailed log file).
Post Mon Oct 25, 2010 1:19 pm
Vedo wrote:While going wireless, wired or both?
doesn't matter. it'll just give details of your IP addresses and adaptors
Vedo
Post Mon Oct 25, 2010 10:46 pm
zip wrote:can you execute the following command and post the contents of file c:\ipconfig.txt here?
I don't know what file format is accepted (neither *.txt nor *.pdf, nor *.doc). So I'm pasting the results.
Microsoft Windows XP [Versione 5.1.2600]
(C) Copyright 1985-2001 Microsoft Corp.
C:\>ipconfig/all
Configurazione IP di Windows
Nome host . . . . . . . . . . . . . . : NoteBetocchi
Suffisso DNS primario . . . . . . . :
Tipo nodo . . . . . . . . . . . . : Misto
Routing IP abilitato. . . . . . . . . : No
Proxy WINS abilitato . . . . . . . . : No
Elenco di ricerca suffissi DNS. . . . : fastwebnet.it
Scheda Ethernet Ethernet:
Stato supporto . . . . . . . . . . . : Supporto disconnesso
Descrizione . . . . . . . . . . . . . : Broadcom NetXtreme 57xx Gigabit
Controller
Indirizzo fisico. . . . . . . . . . . : 00-15-C5-C0-4E-9C
Scheda Ethernet Connessione rete senza fili:
Suffisso DNS specifico per connessione: fastwebnet.it
Descrizione . . . . . . . . . . . . . : Intel(R) PRO/Wireless 3945ABG Ne
twork Connection
Indirizzo fisico. . . . . . . . . . . : 00-18-DE-B2-9F-17
DHCP abilitato. . . . . . . . . . . . : Sì
Configurazione automatica abilitata : Sì
Indirizzo IP. . . . . . . . . . . . . : 39.7.234.186
Subnet mask . . . . . . . . . . . . . : 255.255.255.0
Gateway predefinito . . . . . . . . . : 39.7.234.1
Server DHCP . . . . . . . . . . . . . : 39.7.234.184
Server DNS . . . . . . . . . . . . . : 62.101.93.101
83.103.25.250
Lease ottenuto. . . . . . . . . . . . : martedì 26 ottobre 2010 0:27:14
Scadenza lease . . . . . . . . . . . : martedì 26 ottobre 2010 0:57:14
Scheda Ethernet Bluetooth:
Descrizione . . . . . . . . . . . . . : Bluetooth Personal Area Network
from TOSHIBA
Indirizzo fisico. . . . . . . . . . . : 00-16-41-A2-F1-1C
C:\>
Post Mon Oct 25, 2010 11:26 pm
hmm, so it really looks like your provided gives you IP address.... can you check what IP is Serviio binding to? (see beginning of the log after you restart the service)
Vedo
Post Fri Oct 29, 2010 1:37 am
I finally succeeded. I was trying (hopelessly) to connect my wired TV to my notebook over WiFi.Then I bought an overpriced Sony WiFi USB dongle and, voila, everything works. Illogical as it may seem, it looks like the wired and wireless parts of my net work differently DLNA-wise, but wired and wireless PCs see each other and can exchange files. I didn't even need to specify a bound IP address, and left the box blank.
I had a small problem that I could easily fix: when starting to play a movie, ffmpeg would crash: I downloaded the latest version into the \lib folder and all is fine.
I'm reporting this in hope it may help someone with a similar problem.
Serviio is a great software
patters
Post Sat Oct 30, 2010 1:54 pm
I run my DLNA Bravia and its bluray player on wired connections but my Serviio machine is in another room on wifi and it's ok. There must have been some other issue in your case (personal firewall in antivirus or something, or your router treating them as different zones perhaps?).
Vedo
Post Sat Oct 30, 2010 6:21 pm
I'm sure you're correct. Unfortunately there's no way for me to find out, as my WiFi access point/modem (supplied by my provider) cannot be programmed. I can, in fact, change channels, protection (WEP or WPA) and password: that's it. It's illogical that one wired device can't communicate to a wireless one, and this is not the case between 2 PCs. Anyhow, all's well that ends well. Thanks for your reply.
Post Tue Nov 16, 2010 10:04 pm
For information, Qriocity the Video On Demand Service by Sony is now available for french country: www.qriocity.com
Post Fri Nov 26, 2010 1:11 pm
New Firmware version for 2010 Bravia TV, PKG4.085EUL-0108 (25/11/2010) :
- IPTV new service support.
- Picasa access on photos section
- Qriocity VoD access on video section
- M6Replay CatchUpTV access on video section, also Daylimotion, Youtube...
Post Mon Dec 06, 2010 10:00 pm
I've done some test, specificaly on maximum video bitrate estimation that my EX500 can reached.
I used following samples files:
MPEGTS with MPEG2 video
http://www.nextcomwireless.com/R5000/samples.htm
hbo_trailer_6k_MPEGTS-MPEG2-1920x1080-29.97fps-AC3-384Kbps-48KHz-Stereo.ts
hbo_trailer_dtc_MPEGTS-MPEG2-1280x1088-29.97fps-AC3-384Kbps-48KHz-Stereo.ts
Some MKV with AVC video
Sintel_DivXPlusHD_2Titles_6500kbps.mkv
M2TS
hd_thx_amazing_life_[AVC_HL4.1_AC3].m2ts
It seems that the maximum video bitrate supported by EX500 Bravia TV is around 15Mbps or 20Mbps
When video bitrate reached 20Mbps and beyond, some stuttering issues appears due to sony decoder firmware.
Users browsing this forum: No registered users and 109 guests
