Video playing from near the end
PeterT
Post Tue Apr 03, 2012 3:22 am
I'm using Serviio on a WHS; running 0.6.2.
Testing to a VLC 2.01 client and using it's DLNA mode I am seeing weirdness with one set of videos; rather than playing from the start, they appear to start about 44 minutes into a 45 minute video. Playing the exact same video via a share and opening the file via VLC's Open File option, the file plays correctly.
MediaInfo
Complete name                            : \\SERVER\Torrents\Cleaned-Up\Lord Peter Wimsey\Season 1\Clouds Part 1.avi
Format                                   : AVI
Format/Info                              : Audio Video Interleave
File size                                : 525 MiB
Duration                                 : 44mn 54s
Overall bit rate                         : 1 635 Kbps
Format                                   : MPEG-4 Visual
Format profile                           : Simple@L3
Format settings, BVOP                    : No
Format settings, QPel                    : No
Format settings, GMC                     : No warppoints
Format settings, Matrix                  : Default (H.263)
Codec ID                                 : XVID
Codec ID/Hint                            : XviD
Duration                                 : 44mn 54s
Bit rate                                 : 1 489 Kbps
Width                                    : 512 pixels
Height                                   : 384 pixels
Display aspect ratio                     : 4:3
Frame rate                               : 29.970 fps
Bits/(Pixel*Frame)                       : 0.253
Stream size                              : 478 MiB (91%)
Writing library                          : ZJMedia MPEG Encoder
Format                                   : MPEG Audio
Format version                           : Version 1
Format profile                           : Layer 3
Mode                                     : Joint stereo
Mode extension                           : MS Stereo
Codec ID                                 : 55
Codec ID/Hint                            : MP3
Duration                                 : 44mn 54s
Bit rate                                 : 128 Kbps
Sampling rate                            : 44.1 KHz
Stream size                              : 41.1 MiB (8%)
Alignment                                : Aligned on interleaves
Interleave, duration                     : 26 ms (0.78 video frame)
ffmpeg output:
  configuration: --enable-static --disable-shared --disable-ffplay --disable-ffserver --enable-memalign-hack --enable-libmp3lame --enable-librtmp --extra-libs='-lrtmp -lpolarssl -lws2_32 -lwinmm' --arch=x86 --enable-runtime-cpudetect --enable-pthreads --target-os=mingw32 --cross-prefix=i686-mingw32- --pkg-config=pkg-config
  libavutil    51. 32. 0 / 51. 32. 0
  libavcodec   53. 42. 0 / 53. 42. 0
  libavformat  53. 24. 0 / 53. 24. 0
  libavfilter   2. 53. 0 /  2. 53. 0
Input #0, avi, from 'Clouds Part 1.avi':
  Duration: 00:44:54.72, start: 0.000000, bitrate: 1634 kb/s
    Stream #0:0: Video: mpeg4 (Simple Profile) (XVID / 0x44495658), yuv420p, 512x384 [SAR 1:1 DAR 4:3], 29.97 tbr, 29.97 tbn, 29.97 tbc
    Stream #0:1: Audio: mp3 (U[0][0][0] / 0x0055), 44100 Hz, stereo, s16, 128 kb/s
PeterT
Post Tue Apr 03, 2012 6:37 pm
Re: Video playing from near the end
Weird... playback to a Patriot Box Office via serviio works perfectly
Post Tue Apr 10, 2012 11:49 am
can you post the detailed log of when playing via VLC? Might be it's asking for byte range at the end of the file for some reason.
Users browsing this forum: Baidu [Spider], Google [Bot] and 63 guests
