[SOLVED]The data type is not supported
johnsr11
Post Fri Mar 30, 2012 6:06 pm
I have serviio 0.6.2 running on headless ubuntu server 11.10. I have had no issues with anything playing, and I just recently went back to start watching some movies and I keep getting the error "The data type is not supported". This makes no sense to me since I could watch it with no problems last week, any suggestions?
Post Sun Apr 01, 2012 6:04 pm
Re: The data type is not supported
check the right profile is still selected for the device.
johnsr11
Post Tue Apr 03, 2012 2:25 pm
Thank you zip,
The IP address had changed and it did not have the right profile associated. Also, I discovered that after restoring a backup of my videos they did not completely copied back, so the files were not complete. Thanks again
Users browsing this forum: No registered users and 66 guests
