iPhone 4 videos stutter
mattbrowne
Post Wed Oct 27, 2010 8:29 pm
I've just stumbled across serviio and it looks great so far, its the best working DLNA server that I've found to work with my Sony BDP-S370 (and I've tried a few!).
My question is why do videos that I've shot on my iPhone 4 really stutter on play back on my blue ray player?
I'm new to this world of video formats and from what I can figure out the server isn't transcoding as the video kind of plays with it on or off.
I've downloaded a hd divx trailer and this streams perfectly so I don't think this is down to the server resources (also the CPU usage is low).
Does anyone have any ideas as it would help me out greatly!
Matt
Post Thu Oct 28, 2010 7:21 am
Re: iPhone 4 videos stutter
mattbrowne wrote:...
What is your video format? Could you please make a "ffpmeg -i" of it.
See this
PS: my BDP-S373 works well to ;)
mattbrowne
Post Thu Oct 28, 2010 7:30 am
Thanks for the reply, here's the output:
ffmpeg -i IMG_0117.MOV
FFmpeg version SVN-r0.5.1-4:0.5.1-1ubuntu1, Copyright (c) 2000-2009 Fabrice Bellard, et al.
configuration: --extra-version=4:0.5.1-1ubuntu1 --prefix=/usr --enable-avfilter --enable-avfilter-lavf --enable-vdpau --enable-bzlib --enable-libgsm --enable-libschroedinger --enable-libspeex --enable-libtheora --enable-libvorbis --enable-pthreads --enable-zlib --disable-stripping --disable-vhook --enable-runtime-cpudetect --enable-gpl --enable-postproc --enable-swscale --enable-x11grab --enable-libdc1394 --enable-shared --disable-static
libavutil 49.15. 0 / 49.15. 0
libavcodec 52.20. 1 / 52.20. 1
libavformat 52.31. 0 / 52.31. 0
libavdevice 52. 1. 0 / 52. 1. 0
libavfilter 0. 4. 0 / 0. 4. 0
libswscale 0. 7. 1 / 0. 7. 1
built on Mar 4 2010 12:35:30, gcc: 4.4.3
Seems stream 0 codec frame rate differs from container frame rate: 1200.00 (1200/1) -> 24.00 (24/1)
Input #0, mov,mp4,m4a,3gp,3g2,mj2, from 'IMG_0117.MOV':
Duration: 00:02:28.07, start: 0.000000, bitrate: 10485 kb/s
Stream #0.0(und): Video: h264, yuv420p, 1280x720, 24 tbr, 600 tbn, 1200 tbc
Stream #0.1(und): Audio: aac, 44100 Hz, mono, s16
Post Thu Oct 28, 2010 7:55 am
Which version of ffmpeg did you used?
I'm not a linux user, but I think you may try to compile source code of ffmpeg given in this link
"This release includes FFmpeg (rev. 23013, incl. a patch)"
mattbrowne
Post Thu Oct 28, 2010 9:41 pm
HI,
I'm using this version:
I'm not sure how to compile the version on this site, are there any instructions anywhere?
Matt
Post Thu Oct 28, 2010 9:50 pm
in the readme.txt distributed with the sw
mattbrowne
Post Thu Oct 28, 2010 10:07 pm
ta - really should have looked inside ;)
Post Thu Oct 28, 2010 10:10 pm
anyway, FFmpeg will not be the cause of the stuttering in your case, as the video is not transcoded. It might be that the player doesn't like the encoding... I guess the bitrate is no too much for the network to cope
mattbrowne
Post Thu Oct 28, 2010 10:15 pm
cool - didn't relish having to compile it!
The network shouldn't be a problem as the server and player are wired into the same router.
Is it worth transcoding it into something else?
Post Thu Oct 28, 2010 10:19 pm
maybe..
looking at the ffmpeg output again, it's a HD video, 10MBit/sec ... are you sure the player can play this king of bitrate? It should be ok, just checking.
mattbrowne
Post Thu Oct 28, 2010 10:24 pm
not sure what it can handle, I'm trying to find out.
I managed to place a HD divx trailer (ffmpeg doesn't show a bit rate) without issues.
patters
Post Sat Oct 30, 2010 2:00 pm
You can see the bitrate displayed on the TV when you play a clip if you press the i+ button on the remote. It ought to be ok with 10Mbps because I have a test clip in 720p@60fps that hits around 15Mbps with no stutter.
Actually, I just remembered that although MOV files (very similar to MP4) are recognised by the player I found that they stuttered unless transcoded to M2TS. This has the added advantage of supporting FFWD/REW which is not permitted by the player for MP4.
viewtopic.php?f=5&t=326&start=100#p3664
My most up to date BDP-S370 profiles:-
Euro
viewtopic.php?f=5&t=326&p=3684#p3684
US (incorporating lostinserviio's mod)
viewtopic.php?f=5&t=664#p3682
Canada (no one has confirmed it yet)
viewtopic.php?f=5&t=727
mattbrowne
Post Sat Oct 30, 2010 2:13 pm
Thanks, I did that and its around 10mbps (I forget exactly) but in the top right there is another bit rate and this is about 70kbps which doesn't seem a lot...
patters
Post Sat Oct 30, 2010 2:20 pm
I edited my post above - are you playing the mov natively, or is it transcoding to m2ts? And what happens if you try to play it from the USB port directly?
mattbrowne
Post Sat Oct 30, 2010 4:50 pm
Sorry, just saw the edit. Tried it and it fixed it! Genius, many thanks!
:D
patters
Post Sat Oct 30, 2010 7:49 pm
Cool. If I recall, MOV playback was dodgy from USB too so I think it's an issue with the player rather than Serviio.
Return to User experiences
