[Solved] Not able to see live Streams
daspixl
Post Tue Apr 03, 2012 3:59 pm
You may have to modify the profile you use or use a different one. Initially I had roughly the same success rate, only a handful of streams that worked, but when I tested the streams with ffmpeg they were fine. Turns out that my Samsung BD-6500 apparently doesn't support the same formats as a D-series TV, so I modified the profile to enable transcoding. This isn't an ideal solution, my server and/or network sometimes struggles to keep up, but now most of the streams work.
When I get the time I will investigate this further to see if there maybe is a better way to fix this.
So how would I go about modifying my profile. Is there a WIKI that you can point me towards or some instructions on how to do it.
Is there anyone else that has experienced this and can offer some help or point me to where I can find the information needed.
Post Tue Apr 03, 2012 6:24 pm
Re: Not able to see live Streams
Without an example of the problem stream and the corresponding log and ffmpeg/mediainfo output, there is not any defined prbem that anyone can help you to solve. The problem solving steps are well documented in various posts/the wiki/singatures and the serviio dovumentation(click on the big SERVIIO above.
alfista
Post Thu Apr 05, 2012 4:19 pm
There is some info in this thread http://forum.serviio.org/viewtopic.php?f=4&t=5569 regarding the profile issue that affected my BD-player (BD-6500).
I had to reverse the change made recently in the profile for Samsung C/D-series to get things working. Before I was unable to watch anything coming from tvsector.com for instance.
I haven't had time to do a proper investigation to isolate what kind of streams work or not with the default setting of the profile, I would love to figure out some way that I could watch these channels without transcoding since it seems to make things a bit unstable.
daspixl
Post Thu Apr 05, 2012 4:58 pm
Re: [Solved] Not able to see live Streams
I finally got the live steams (RSS) feeds to work. I uninstalled Serviio and then reinstalled Java then Serviio. Followed the steps in the RSS Feeds thread, put in the plugins and the 2 test feeds and they worked.
Added the RSS feeds from the list of 19 maintained feeds and they worked. Great system.
Thank you
James
Post Thu Apr 05, 2012 5:21 pm
Glad its all straightened out. Enjoy.
Return to User experiences
