Toshiba Regza 46WL743
geckland
Post Fri Oct 29, 2010 5:31 pm
my new Toshiba Regza 46WL743 runs fine with the following Profile:
   <Profile id="10" name="TOSHIBA 46WL743" extendsProfileId="1">
      <Detection>
         <X-AV-Client-Info>.*TOSHIBA.*</X-AV-Client-Info>
      </Detection>
      <MediaFormatProfiles>
         <!-- rename native mpeg2ts with h264/ac3 ac3 formats to those supported by the tv -->
         <MediaFormatProfile mime-type="video/vnd.dlna.mpeg-tts" name="AVC_TS_HD_50_AC3">AVC_TS_MP_HD_AC3</MediaFormatProfile>
         <MediaFormatProfile mime-type="video/vnd.dlna.mpeg-tts" name="AVC_TS_HD_50_AC3">AVC_TS_MP_SD_AC3</MediaFormatProfile>
         <MediaFormatProfile mime-type="video/vnd.dlna.mpeg-tts" name="AVC_TS_HD_50_AC3_T">AVC_TS_MP_HD_AC3_T</MediaFormatProfile>
         <MediaFormatProfile mime-type="video/vnd.dlna.mpeg-tts" name="AVC_TS_HD_50_AC3_T">AVC_TS_MP_SD_AC3_T</MediaFormatProfile>
         <!-- rename transcoded mpeg2ts with h264 to one of the TV's supported profiles -->
         <MediaFormatProfile mime-type="video/mpeg" name="AVC_TS_HD_50_AC3_ISO">AVC_TS_MP_HD_AC3_ISO</MediaFormatProfile>
         <MediaFormatProfile mime-type="video/mpeg" name="AVC_TS_HD_50_AC3_ISO">AVC_TS_MP_SD_AC3_ISO</MediaFormatProfile>
      </MediaFormatProfiles>
         <!-- First remux all h264 video on MPEG-TS stream with ac3 audio transcoding, expected profile AVC_TS_MP_HD_AC3_ISO or AVC_TS_MP_SD_AC3_ISO -->
            <!-- if audio different to ac3, must be transcoded -->
            <Matches container="mpegts" aCodec="aac" />
            <Matches container="mpegts" aCodec="mp3" />
            <Matches container="mpegts" aCodec="dca" />
         <!-- All Others video/audio codec will be transcoded into mpeg2ts, mpeg2video and ac3 audio (MPEG_TS_SD_EU). -->
            <Matches container="asf" />
            <Matches container="avi" />
            <Matches container="mp4" />
I slightly changed the Bravia TV Profile to view even.mkv-files.
Some .avi-files have problems - only sound is available - no video. Have to check this, but I think, the .avi's are not ok.
cu
geckland
Post Sat Oct 30, 2010 12:05 pm
Re: Toshiba Regza 46WL743
geckland wrote:Hi,
my new Toshiba Regza 46WL743 runs fine with the following Profile...
Great,
So you remove "<Matches container="matroska" vCodec="h264" />" because your Regza support mkv file in native (with generic profile)?
For confirmation, could you provide the GetInfoProtocol sink of your Regza model, see here.
geckland wrote:Some .avi-files have problems - only sound is available - no video. Have to check this, but I think, the .avi's are not ok...
Could you provide a "ffmpeg -i" result of your avi file with problem?
geckland
Post Sat Oct 30, 2010 5:14 pm
I moved some weeks ago, so my internet connection is very slow, my provider ...
and I've got plenty of work to do, so I haven't checked out all of serviio, but I think, it's the best streaming-service. It's easy and it runs with my toshiba via WLAN, even on server operation systems.
I'm also new to all that dlna stuff. I'm wondering about such a bad support of Toshiba-LCDs, even Toshiba provides only a poor software, not to talk about the manual.
Well, I only have exactly one .mkv-file and with the bravia-profile I wasn't able to view it. After the modification I was able to view it.
the ffmpeg -i result of my .mkv:
c:ffmpeg.exe -i cia-dldb-x264.mkv
FFmpeg version SVN-r23012, Copyright (c) 2000-2010 the FFmpeg developers
  built on May  3 2010 19:05:24 with gcc 3.4.5 (mingw-vista special r3)
erver --enable-memalign-hack --enable-libmp3lame --enable-w32threads --extra-ldf
lags=-L/static/lib --extra-cflags=-I/static/include
  libavutil     50.15. 0 / 50.15. 0
  libavcodec    52.66. 0 / 52.66. 0
  libavformat   52.62. 0 / 52.62. 0
  libavdevice   52. 2. 0 / 52. 2. 0
  libswscale     0.10. 0 /  0.10. 0
[matroska @ 003dd490]Estimating duration from bitrate, this may be inaccurate
Seems stream 0 codec frame rate differs from container frame rate: 50.00 (50/1)
-> 500.00 (500/1)
Input #0, matroska, from 'cia-dldb-x264.mkv':
  Duration: 01:29:53.00, start: 0.000000, bitrate: 192 kb/s
    Stream #0.0: Video: h264, yuv420p, 720x384, PAR 130:127 DAR 975:508, 25 fps,
 500 tbr, 1k tbn, 50 tbc
      title           : Video
    Stream #0.1(ger): Audio: ac3, 48000 Hz, stereo, s16, 192 kb/s
Here are two ffmpeg -i results, one I can view, and one I can't
This one I can view:
D:\Filme\Avatar>"C:\Program Files (x86)\Serviio\lib\ffmpeg.exe" -i pl-avatar_scr
-a.avi
Seems stream 0 codec frame rate differs from container frame rate: 23.98 (65535/
2733) -> 23.98 (2997/125)
Input #0, avi, from 'pl-avatar_scr-a.avi':
    ISFT            : VirtualDubMod 1.5.10.2 (build 2540/release)
  Duration: 01:23:55.99, start: 0.000000, bitrate: 1167 kb/s
    Stream #0.0: Video: mpeg4, yuv420p, 624x336 [PAR 1:1 DAR 13:7], 23.98 tbr, 2
3.98 tbn, 23.98 tbc
    Stream #0.1: Audio: mp3, 48000 Hz, 2 channels, s16, 160 kb/s
This one I can't view, audio is ok:
D:\Filme\Zweiohrkuecken>"C:\Program Files (x86)\Serviio\lib\ffmpeg.exe" -i "Zwei
ohrkuecken TS XViD CD1.avi"
Input #0, avi, from 'Zweiohrkuecken TS XViD CD1.avi':
  Duration: 01:03:01.32, start: 0.000000, bitrate: 1554 kb/s
    Stream #0.0: Video: mpeg4, yuv420p, 640x272 [PAR 1:1 DAR 40:17], PAR 17:30 D
AR 4:3, 25 tbr, 25 tbn, 25 tbc
    Stream #0.1: Audio: mp3, 48000 Hz, 2 channels, s16, 112 kb/s
the GetInfoProtocol sink of my Toshiba Regza 46WL743:
http-get:*:video/mpeg:DLNA.ORG_PN=MPEG_PS_NTSC,http-get:*:video/mpeg:DLNA.ORG_PN=MPEG_PS_PAL,http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=MPEG_TS_SD_NA,http-get:*:video/mpeg:DLNA.ORG_PN=MPEG_TS_SD_NA_ISO,http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=MPEG_TS_SD_NA_T,http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=MPEG_TS_HD_NA,http-get:*:video/mpeg:DLNA.ORG_PN=MPEG_TS_HD_NA_ISO,http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=MPEG_TS_HD_NA_T,http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=MPEG_TS_SD_EU,http-get:*:video/mpeg:DLNA.ORG_PN=MPEG_TS_SD_EU_ISO,http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=MPEG_TS_SD_EU_T,http-get:*:audio/L16;rate=44100;channels=1:DLNA.ORG_PN=LPCM,http-get:*:audio/L16;rate=44100;channels=2:DLNA.ORG_PN=LPCM,http-get:*:audio/L16;rate=48000;channels=1:DLNA.ORG_PN=LPCM,http-get:*:audio/L16;rate=48000;channels=2:DLNA.ORG_PN=LPCM,http-get:*:audio/mpeg:DLNA.ORG_PN=MP3,http-get:*:image/jpeg:DLNA.ORG_PN=JPEG_SM,http-get:*:image/jpeg:DLNA.ORG_PN=JPEG_MED
I hope this helps, optimizations are wellcome
Post Sun Oct 31, 2010 9:52 am
OK, so according to the GetInfoProtocol sink, your Regza TV only support:
MPEG2 Program stream
MPEG2 Transport Stream SD & HD
LPCM audio
MP3 audio
and JPEG (max 1024 x 768 pixels)
AVC/h264 not supported, so must be transcoded to mpeg2video:
   <Profile id="11" name="TOSHIBA REGZA" extendsProfileId="1">
      <Detection>
      </Detection>
         <!-- Transcode all video on MPEG-TS stream with ac3 audio and mpeg2 video codec, expected profile MPEG_TS_SD_EU or MPEG_TS_HD_EU -->
         <Matches container="mpegts" vCodec="h264" />
globo
Post Sat Nov 06, 2010 11:23 am
thnx for profile for regza, now i can play all my .mkv video
if U could resolve "no video" in .avi i'l be thankful
some .avi plays fine but most play only sound, no video
thnx for help
Xardas
Post Wed Nov 24, 2010 4:44 pm
Hi there,
I got some problems streaming mkv to my T Regza 40XV733G. The first program I used was Wild Media Server 1.05. The result was, that I could watch nearly every type of video from my pc. There were some issues with ff and rewind and I was not able to pause the video I was watching. If I tried to resume the video continued at a different (earlier) position. To sum up it was not worth paying 40 $ for it, so I found serviio was a good alternative.
I started with the configuration for Samsung TVs, and the mkv files were stuttering quite often. I like to watch the CSI series and especially for the flashbacks they are using some sort of high film grain amount which always causes stuttering and also asynchronous picture and sound, but the stuttering appears to be random as well. Another example is the intro of "The Big Bang Theory" series where there are a lot of pictures changing in very short time. (http://www.youtube.com/watch?v=IFy5FN06_zU) which also causes the video to stutter. The most aggravating problem is that the media server stops transcoding after 25 - 30 minutes. I never had this problem with WMS.
To use the Toshiba profile from above doesnt change a thing. Is there any way to fix the problem via changing the profile?
Thx for your help in advance
Greetings
Octalus
Post Fri Nov 26, 2010 10:45 am
with the problem "no video but audio" - i also have this and maybe its a problem of aspect ratio? is there an option in profile to force a specific ratio?
Post Fri Nov 26, 2010 11:33 am
Octalus wrote:with the problem "no video but audio" - i also have this and maybe its a problem of aspect ratio? is there an option in profile to force a specific ratio?
No option on profile for aspect ratio.
But Serviio is based on ffmpeg.exe core, so you could make localy test by changing ffmpeg option : http://www.ffmpeg.org/ffmpeg-doc.html#SEC6
-s size
-aspect aspect
etc...
The ffmpeg base command for avi transcoding is:
ffmpeg -i <movie_path.avi> -y -vcodec mpeg2video -sameq -r 23.98 -g 15 -copyts -acodec ac3 -ab 192k -sn -f mpegts <transcoded_path.ts>
Change frame rate 23.98 according to the avi source frame rate...
And try to stream the .ts output file
Octalus
Post Fri Nov 26, 2010 12:48 pm
ok, i tried with size of hd1080 and aspect of 16:9 - the ts file on my pc is ok, i can play and it has the mpeg options you posted
when i play this file with my tv... black screan and sound is running :-(
so it has nothing to do with aspect or size
any other solutions possible?
i recognize an other difference between running and not running movies :
i used the tool "gspot" to read out properties.
The working ones have set "DivX Style "packed bitstream" AVI" in container properties
the not working movies doesnt have this options - maybe a thing we should set to ffmpeg?
Post Fri Nov 26, 2010 1:31 pm
Could you post the log of the ffmpeg command you use for transcoding?
Octalus
Post Fri Nov 26, 2010 4:04 pm
i reentered the command but didnt finish transcoding (thats why termination at the end)
i use the newest ffmpeg (hoped that it fixes the problem...)
C:\Program Files (x86)\Serviio\lib>ffmpeg.exe -i H:\Filme\anschaun!\TSN.avi -y -
vcodec mpeg2video -sameq -r 25.0 -s hd1080 -aspect 16:9 -g 15 -copyts -acodec ac
3 -ab 192k -sn -f mpegts test.ts
FFmpeg version SVN-r25456-Sherpya, Copyright (c) 2000-2010 the FFmpeg developers
  built on Oct 14 2010 16:46:15 with gcc 4.2.5 20090330 (prerelease) [Sherpya]
  libavutil     50.32. 3 / 50.32. 3
  libavcore      0. 9. 1 /  0. 9. 1
  libavcodec    52.92. 0 / 52.92. 0
  libavformat   52.81. 0 / 52.81. 0
  libavdevice   52. 2. 2 / 52. 2. 2
  libavfilter    1.51. 1 /  1.51. 1
  libswscale     0.12. 0 /  0.12. 0
  libpostproc   51. 2. 0 / 51. 2. 0
Input #0, avi, from 'H:\Filme\anschaun!\TSN.avi':
    ISFT            : VirtualDubMod 1.5.10.2 (build 2542/release)
  Duration: 01:55:38.08, start: 0.000000, bitrate: 1374 kb/s
    Stream #0.0: Video: mpeg4, yuv420p, 640x272 [PAR 1:1 DAR 40:17], PAR 17:32 D
AR 5:4, 25 tbr, 25 tbn, 25 tbc
    Stream #0.1: Audio: mp3, 48000 Hz, 2 channels, s16, 134 kb/s
[buffer @ 03671530] w:640 h:272 pixfmt:yuv420p
[scale @ 03e40db0] w:640 h:272 fmt:yuv420p -> w:1920 h:1080 fmt:yuv420p flags:0x
4
[ac3 @ 03670f50] No channel layout specified. The encoder will guess the layout,
 but it might be incorrect.
[mpegts @ 03664090] muxrate VBR, pcr every 2 pkts, sdt every 200, pat/pmt every
40 pkts
Output #0, mpegts, to 'test.ts':
    encoder         : Lavf52.81.0
    Stream #0.0: Video: mpeg2video, yuv420p, 1920x1080 [PAR 1:1 DAR 16:9], q=2-3
1, 200 kb/s, 90k tbn, 25 tbc
    Stream #0.1: Audio: ac3, 48000 Hz, stereo, s16, 192 kb/s
Stream mapping:
  Stream #0.0 -> #0.0
  Stream #0.1 -> #0.1
Press [q] to stop encoding
frame=   65 fps= 21 q=0.0 Lsize=    1530kB time=2.56 bitrate=4895.6kbits/s
yule
Post Fri Dec 31, 2010 12:09 pm
In a somewhat related manner, I have a Toshiba 37VX733G which also only supports MPEG2 video, so I wrote about the profile I'm using here: http://forum.serviio.org/viewtopic.php?f=6&t=1242. I only tried it on some .avi and .mp4 files - still have to see if mkv works. Please reply here if you find it useful or find any flaws to it.
