Connection to Serviio fails
Dros
Post Thu Apr 05, 2012 4:18 pm
since a few weeks (I had no time to go after this), my Pana says Connections to Server failed. The TV and the server are connected with a LAN cable, and pings show that the physical connection is ok.
I can see the several serviio username: entries in the Media-Server list, but when I try to connect I get the above menttioned error.
The Server ist running and I didn't change something, it suddenly stopped working.
Any ideas what could be wrong?
Dros
Post Thu Apr 05, 2012 4:26 pm
SOLVED: Re: Connection to Serviio fails
I had to bind Serviio to my main IP address. The default was a blank field, but Serviio.log told me, he bound to localhost. Now it works.
Strange, why did the behauviour of the software changed?
I'am using Win7 Home 64 Bit.
Return to Panasonic
