can`t run serviio
drunkez
Post Thu Apr 12, 2012 11:01 pm
can`t run serviio
Hi i have this problem during first run of serviio.sh
root@phernet:/opt/serviio-0.6.2/bin# ./serviio.sh
Exception in thread "main" java.lang.NoClassDefFoundError: Could not initialize class org.serviio.config.Configuration
at org.serviio.upnp.addressing.LocalAddressResolverStrategy.getHostIpAddress(LocalAddressResolverStrategy.java:59)
at org.serviio.upnp.Device.<init>(Device.java:99)
at org.serviio.upnp.Device.getInstance(Device.java:117)
at org.serviio.library.metadata.AbstractCDSLibraryIndexingListener.<init>(AbstractCDSLibraryIndexingListener.java:45)
at org.serviio.library.online.metadata.OnlineCDSLibraryIndexingListener.<init>(OnlineCDSLibraryIndexingListener.java:17)
at org.serviio.library.online.OnlineLibraryManager.<init>(OnlineLibraryManager.java:94)
at org.serviio.library.online.OnlineLibraryManager.getInstance(OnlineLibraryManager.java:78)
at org.serviio.MediaServer.main(MediaServer.java:108)
^C
then i stopped it as it`s not doing nothing for a long time...
system specifications:
root@phernet:/opt/serviio-0.6.2/bin# cat /etc/issue
Debian GNU/Linux 6.0 \n \l
root@phernet:/opt/serviio-0.6.2/bin# uname -a
Linux phernet 2.6.32-5-686 #1 SMP Mon Mar 26 05:20:33 UTC 2012 i686 GNU/Linux
root@phernet:/opt/serviio-0.6.2/bin# java -version
java version "1.6.0_26"
Java(TM) SE Runtime Environment (build 1.6.0_26-b03)
Java HotSpot(TM) Client VM (build 20.1-b02, mixed mode, sharing)
i`ll be very happy about any help
Thank you
Post Fri Apr 13, 2012 12:24 pm
Re: can`t run serviio
it can't fing the libraries on classpath, they are stored in the lib folder (.jar files). Make sure they are readable by the user.
Users browsing this forum: Baidu [Spider] and 32 guests
