Bravia 2011 Series LAtinoamerica
dssmex
Post Sat Apr 14, 2012 4:29 pm
The Bravia Series 2011 for Latinoamerica don't have support for AVI (divx) codec in dlna and usb.
DLNA specs for Latinoamerica
http://esupport.sony.com/LA/perl/support-info.pl?info_id=799&mdl=KDL32EX421
i have an KDL-32EX421
http://www.sony.com.mx/corporate/MX/productos/Televisores/Sony-Internet-Televisores/KDL-32EX421.html
Latest Firmware for LA
http://esupport.sony.com/LA/perl/swu-download.pl?mdl=KDL32EX421&upd_id=7462&os_group_id=18
anyone can modify the config for 2011 without avi codec (add transcoding for avi format).
thank's in advance.
Post Sat Apr 14, 2012 5:01 pm
Re: Bravia 2011 Series LAtinoamerica
dssmex wrote:anyone can modify the config for 2011 without avi codec (add transcoding for avi format).
Yes, select Sony 2010 profile on console. This will transcode avi files. (This is the only difference between 2010 & 2011 profiles)
