Serviio not finding all files
mbailey
Post Fri Apr 06, 2012 8:30 am
Any suggestsions why Serviio is not finding all my files? They are just JPG files.
My setup is as follows:
Under shared folders I have 4 folders:
c:\Users\Roger\Pictures\User1
c:\Users\Roger\Pictures\User2
c:\Users\Roger\Pictures\User3
c:\Users\Roger\Pictures\User4
All 4 users are setup the same, with photos and refresh options ticked.
Under each of the sub folders I split the photos up into years and then sub folders for each album.
For User2 I have recently added a new 2012 subfolder and additional folders below. These are all visible on Serviio after a library refresh.
For User4 I have tried the same but for some reason it won't find my new sub folder 2012.
I tried deleting User4 and later re-adding User4 but again it finds all the previous years upto 2011 but then appears to stop.
I checked the log file and there are no error messages in there.
Other that uninstalling Serviio and removing all databases and starting again any suggestions of things I can try please?
Windows 7 SP1
Serviio 0.6.2
Post Fri Apr 06, 2012 11:21 am
Re: Serviio not finding all files
Add photos in the folder a couple at a time. There is a problem where serviio will hang when it finds certain picture information. Usually it is a landscape photo.
http://forum.serviio.org/viewtopic.php?f=5&t=5072&hilit=image+metadata
Also make sure that the permissions are correct for the folder.
Post Tue Apr 10, 2012 11:52 am
and if you find the image that causes that, can you send me one to try to reproduce this?
mbailey
Post Thu Apr 12, 2012 1:45 pm
zip wrote:and if you find the image that causes that, can you send me one to try to reproduce this?
Ok, I have found a file that does not load.
I have created a directory with just 5 files. Serviio finds the first 2 files, but then seems to get stuck on the 3rd file and never finds the 4th and 5th files.
2012-04-12 14:27:04,021 DEBUG [LibraryAdditionsCheckerThread] Found file 'Abs school Dec 2011001.jpg', checking if it's already in the Library
2012-04-12 14:27:04,022 DEBUG [MediaItemDAOImpl] Checking if DB already contains media item Abs school Dec 2011001.jpg
2012-04-12 14:27:04,035 DEBUG [RepositoryDAOImpl] Reading all Repositories
2012-04-12 14:27:04,070 DEBUG [OnlineRepositoryDAOImpl] Reading all OnlineRepositories
2012-04-12 14:27:04,139 DEBUG [RepositoryDAOImpl] Reading all Repositories
2012-04-12 14:27:04,140 DEBUG [OnlineRepositoryDAOImpl] Reading all OnlineRepositories
2012-04-12 14:27:04,300 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:schemas-upnp-org:device:InternetGatewayDevice:1 from address /192.168.1.70:58320
2012-04-12 14:27:04,313 DEBUG [MediaItemDAOImpl] Media item Abs school Dec 2011001.jpg doesn't exist in DB yet
2012-04-12 14:27:04,313 DEBUG [LibraryAdditionsCheckerThread] File not in Library, will add it
2012-04-12 14:27:04,325 DEBUG [MetadataExtractorConfigDAOImpl] Reading a list of Extractor configuration for type AUDIO
2012-04-12 14:27:04,328 DEBUG [MetadataExtractorConfigDAOImpl] Reading a list of Extractor configuration for type VIDEO
2012-04-12 14:27:04,329 DEBUG [MetadataExtractorConfigDAOImpl] Reading a list of Extractor configuration for type IMAGE
2012-04-12 14:27:04,365 DEBUG [MediaItemDAOImpl] Reading dirty MediaItems for Repository (id = 15)
2012-04-12 14:27:04,366 DEBUG [ImageExtractionStrategy] Extracting metadata of image file: D:\matthew\My Documents\My Pictures\2011\Misc\School Photos (Nov 2011)\Abs school Dec 2011001.jpg
2012-04-12 14:27:04,479 DEBUG [LibraryManager] Metadata found via extractor EMBEDDED: ImageMetadata [title=Abs school Dec 2011001, date=Tue Dec 13 18:13:02 GMT 2011, filePath=D:\matthew\My Documents\My Pictures\2011\Misc\School Photos (Nov 2011)\Abs school Dec 2011001.jpg, fileSize=3585622, container=JPEG, width=2400, height=2992, colorDepth=24]
2012-04-12 14:27:04,480 DEBUG [ImageService] Adding image into database: Abs school Dec 2011001
2012-04-12 14:27:04,559 DEBUG [RepositoryDAOImpl] Marking Repository 15 as scanned with current timestamp
2012-04-12 14:27:04,583 DEBUG [ImageService] Resizing and storing thumbnail image
2012-04-12 14:27:04,612 DEBUG [ImageUtils] Starting image resize, size = 3585622 bytes
2012-04-12 14:27:05,982 DEBUG [ImageUtils] Returning resized image, size = 4055 bytes
2012-04-12 14:27:05,983 DEBUG [CoverImageDAOImpl] Creating a new ImageCover (length = 4055)
2012-04-12 14:27:06,008 DEBUG [ImageDAOImpl] Creating a new Image (name = Abs school Dec 2011001)
2012-04-12 14:27:06,158 DEBUG [MetadataDescriptorDAOImpl] Creating a new MetadataDescriptor (type = EMBEDDED, mediaItemId = 26446)
2012-04-12 14:27:06,189 INFO [LibraryAdditionsCheckerThread] Added file 'Abs school Dec 2011001.jpg' (title: Abs school Dec 2011001) to Library
2012-04-12 14:27:06,210 DEBUG [LibraryAdditionsCheckerThread] Found file 'Abs school Dec 2011002.jpg', checking if it's already in the Library
2012-04-12 14:27:06,211 DEBUG [MediaItemDAOImpl] Checking if DB already contains media item Abs school Dec 2011002.jpg
2012-04-12 14:27:06,211 DEBUG [MediaItemDAOImpl] Media item Abs school Dec 2011002.jpg doesn't exist in DB yet
2012-04-12 14:27:06,211 DEBUG [LibraryAdditionsCheckerThread] File not in Library, will add it
2012-04-12 14:27:06,217 DEBUG [ImageExtractionStrategy] Extracting metadata of image file: D:\matthew\My Documents\My Pictures\2011\Misc\School Photos (Nov 2011)\Abs school Dec 2011002.jpg
2012-04-12 14:27:06,286 DEBUG [LibraryManager] Metadata found via extractor EMBEDDED: ImageMetadata [title=Abs school Dec 2011002, date=Tue Dec 13 18:11:30 GMT 2011, filePath=D:\matthew\My Documents\My Pictures\2011\Misc\School Photos (Nov 2011)\Abs school Dec 2011002.jpg, fileSize=1851287, container=JPEG, width=1624, height=2161, colorDepth=24]
2012-04-12 14:27:06,286 DEBUG [ImageService] Adding image into database: Abs school Dec 2011002
2012-04-12 14:27:06,287 DEBUG [ImageService] Resizing and storing thumbnail image
2012-04-12 14:27:06,293 DEBUG [ImageUtils] Starting image resize, size = 1851287 bytes
2012-04-12 14:27:06,908 DEBUG [ImageUtils] Returning resized image, size = 4042 bytes
2012-04-12 14:27:06,908 DEBUG [CoverImageDAOImpl] Creating a new ImageCover (length = 4042)
2012-04-12 14:27:06,910 DEBUG [ImageDAOImpl] Creating a new Image (name = Abs school Dec 2011002)
2012-04-12 14:27:06,913 DEBUG [MetadataDescriptorDAOImpl] Creating a new MetadataDescriptor (type = EMBEDDED, mediaItemId = 26447)
2012-04-12 14:27:06,916 INFO [LibraryAdditionsCheckerThread] Added file 'Abs school Dec 2011002.jpg' (title: Abs school Dec 2011002) to Library
2012-04-12 14:27:06,936 DEBUG [LibraryAdditionsCheckerThread] Found file 'Char school Nov 2011002.jpg', checking if it's already in the Library
2012-04-12 14:27:06,936 DEBUG [MediaItemDAOImpl] Checking if DB already contains media item Char school Nov 2011002.jpg
2012-04-12 14:27:06,936 DEBUG [MediaItemDAOImpl] Media item Char school Nov 2011002.jpg doesn't exist in DB yet
2012-04-12 14:27:06,937 DEBUG [LibraryAdditionsCheckerThread] File not in Library, will add it
2012-04-12 14:27:06,938 DEBUG [ImageExtractionStrategy] Extracting metadata of image file: D:\matthew\My Documents\My Pictures\2011\Misc\School Photos (Nov 2011)\Char school Nov 2011002.jpg
2012-04-12 14:27:06,940 DEBUG [LibraryManager] Metadata found via extractor EMBEDDED: ImageMetadata [title=Char school Nov 2011002, date=Mon Dec 12 18:40:23 GMT 2011, filePath=D:\matthew\My Documents\My Pictures\2011\Misc\School Photos (Nov 2011)\Char school Nov 2011002.jpg, fileSize=2750013, container=JPEG, width=9600, height=12000, colorDepth=24]
2012-04-12 14:27:06,940 DEBUG [ImageService] Adding image into database: Char school Nov 2011002
2012-04-12 14:27:06,941 DEBUG [ImageService] Resizing and storing thumbnail image
2012-04-12 14:27:06,949 DEBUG [ImageUtils] Starting image resize, size = 2750013 bytes
It then doesn't return the "DEBUG [ImageUtils] Returning resized image" which is expected next.
Have sent you a PM with the attached files.
mbailey
Post Thu Apr 12, 2012 2:12 pm
I have raised a Bitbucket report #527.
Many thanks.
Post Fri Apr 13, 2012 5:55 pm
I have increased memory to 512m in ServiioService.exe.vmoptions and the files you sent me worked (you will have to restart the service or PC for the change to take effect)
mbailey
Post Sat Apr 14, 2012 5:19 pm
zip wrote:I have increased memory to 512m in ServiioService.exe.vmoptions and the files you sent me worked (you will have to restart the service or PC for the change to take effect)
This is strange. I tried the change 2 days ago and it didn't work, but I tried it again yesterday after you posted with the file in a separate folder and it worked ok.
I have now put the file back into the folder with the other files and it has failed again. I have uninstalled Serviio and installed again and left it running over night to build the library up, but it stopped on the same file again.
I have since done a force refresh and again it has stopped on the same file again.
The ServiioService.exe.vmoptions file is set to "-Xmx512m".
Post Sat Apr 14, 2012 8:13 pm
Try increasing it even more, to let's say 1024m
Users browsing this forum: No registered users and 86 guests
