serviidb.com
Post Tue Apr 17, 2012 6:22 pm
Re: serviidb.com
ok I cannot test the put here at work, I can test the GET in Internet explorer.
What is the command you are using?
Post Tue Apr 17, 2012 6:25 pm
Re: serviidb.com
I added an echo to print out the sql statement. try it via push and post the sql statement.
Post Tue Apr 17, 2012 6:33 pm
Re: serviidb.com
I might have found the problem on my end, I copied the database connections information from the GET function to the PUT function.
I would bet that is the problem.
Post Tue Apr 17, 2012 7:12 pm
Re: serviidb.com
If someone knows how to test a restful web service PUT command please test the address below and if there is any error please post them here.
PUT http://serviidb.com/api/update?client=generic&nid=777
Post Tue Apr 17, 2012 7:15 pm
Re: serviidb.com
Post Tue Apr 17, 2012 7:17 pm
Re: serviidb.com
INSERT INTO api_install(`client`, `nid`) values ("will", "777")
Post Tue Apr 17, 2012 7:19 pm
Re: serviidb.com
I have been looking for a link like that for weeks.
Post Tue Apr 17, 2012 7:21 pm
Re: serviidb.com
Working now, also works from ServiiDroid now.
Time to clean that table :-)
Any reason the titleorplugin isn't working?
Post Tue Apr 17, 2012 7:22 pm
Re: serviidb.com
for what request?
Post Tue Apr 17, 2012 7:25 pm
Re: serviidb.com
I meant clean the install count table.
Using media.json?titleorplugin=the returns more than it should.
Same for video, haven't tried audio or image.
Post Tue Apr 17, 2012 7:30 pm
Re: serviidb.com
I tried
http://serviidb.com/api/media?client=moltraTEST&titleOrPlugin=the&num=0
and got back
    "resource": "media",
    "requestedSize": 8,
    "totalSize": 8,
    "items": [
            "name": "Italian tomorrow weather",
            "region": "Worldwide",
            "url": "http://media.ilmeteo.it/video/domani-tg.mp4",
            "mediaType": "Video",
            "resourceType": null,
            "plugin": "None",
            "language": "Italian",
            "nid": "124"
            "name": "The Big C",
            "region": "UK",
            "url": "http://www.channel4.com/programmes/the-big-c/4od",
            "resourceType": "Web Resource",
            "plugin": "4oD (UK)",
            "language": "English",
            "nid": "66"
            "name": "The Cleveland Show",
            "region": "UK",
            "url": "http://www.channel4.com/programmes/the-cleveland-show/4od",
            "nid": "52"
            "name": "The Good Wife",
            "region": "UK",
            "url": "http://www.channel4.com/programmes/the-good-wife/4od",
            "nid": "59"
            "name": "The Hotel",
            "region": "UK",
            "url": "http://www.channel4.com/programmes/the-hotel/4od",
            "nid": "60"
            "name": "The Inbetweeners",
            "region": "UK",
            "url": "http://www.channel4.com/programmes/the-inbetweeners/4od",
            "nid": "65"
            "name": "The IT Crowd",
            "region": "UK",
            "url": "http://www.channel4.com/programmes/the-it-crowd/4od",
            "nid": "84"
            "name": "The Joy of Teen Sex",
            "region": "UK",
            "url": "http://www.channel4.com/programmes/the-joy-of-teen-sex/4od",
            "nid": "87"
What is wrong with that response?
Post Tue Apr 17, 2012 7:34 pm
Re: serviidb.com
Ah you changed it, it was titleorplugin, now it is titleOrPlugin
I'll update the code.
Post Tue Apr 17, 2012 7:35 pm
Re: serviidb.com
will wrote:Ah you changed it, it was titleorplugin, now it is titleOrPlugin
Sorry I noticed that it was not following the variable naming we had decided on so I changed it.
Post Tue Apr 17, 2012 7:37 pm
Re: serviidb.com
do a search with client, format, title, region, language, and plugin in it, I want to make sure that the search terms are getting logged properly.
Post Tue Apr 17, 2012 7:41 pm
Re: serviidb.com
Format?
I'm on my phone so it will just be me typing it into the browser.
Post Tue Apr 17, 2012 7:42 pm
Re: serviidb.com
will wrote:Format?
that is ok then, I know how that is lol.
Post Tue Apr 17, 2012 7:47 pm
Re: serviidb.com
OK, I'll do a few final tests and hopefully release the update to the app tomorrow morning.
Post Tue Apr 17, 2012 7:49 pm
Re: serviidb.com
will wrote:OK, I'll do a few final tests and hopefully release the update to the app tomorrow morning.
sounds good to me, I hope that there is not to many bugs in the API.
Post Wed Apr 18, 2012 7:48 am
Re: serviidb.com
Well even if there are a few problems, most can be fixed behind the sences without changing any of the parts of the API. Worst case we will need to add things, but that won't break clients.
When submitting content what is Media ID for? Also the thumbnail is a bit strage
Files must be less than 32 MB.
Allowed file types: png gif jpg jpeg.
Images must be smaller than 160x120 pixels.
Maybe support either uploading to the site, or just providing a url.
I've uploaded the update, obviously what you work on is up to you, but my suggestion would be
1. add the missing parts to the Create Media Resource page (live stream, extra languages?) to help with getting content added
2. Work out how to do /api/regions and /api/languages so that I can fetch a list of available regions and languages
3. Add the remaining fields to the response
4. Templates
Post Wed Apr 18, 2012 11:10 am
Re: serviidb.com
Created a news article on serviio.org and Facebook page. Hopefully we will get some traction now. Good work everyone.
BTW, do you have an API for people to cast votes on the stream quality (in terms of if it's live)?
Users browsing this forum: Baidu [Spider] and 8 guests
