CBS.com (US Only)
mike_metro
Post Sun Feb 19, 2012 7:03 pm
CBS.com (US Only)
CBS.com plugin. Only available in the US.
Must be configure as a Web Resource.
Sample URLs:
http://www.cbs.com/shows/csi/video/
http://www.cbs.com/shows/hawaii_five_0/video/
Update(s):
Version 2.0 - Updated by xs2inattar
Version 7.0 - Updated by leo1981
CBS.groovy
(8.55 KiB) Downloaded 4244 times
kappclark
Post Tue Feb 21, 2012 12:12 pm
Re: CBS.com (US Only)
Thanks for this - works like a charm..
pulse732
Post Thu Feb 23, 2012 7:59 pm
Why doesn't this one work? I
Its the same site
http://www.cbs.com/shows/60_minutes/video/
Does it work for you?
serviio-buddy
Post Thu Feb 23, 2012 9:10 pm
60 Minutes plays ok here in USA on Sony SMP-N100 using the following Source URL:
serviio-buddy
SONY SMP-N100 Media Player, HP PC: Vista 32/Ubuntu 11.10, Serviio 0.6.2, XBMC, VLC, ASUS eeePC Netbook: Vista 32, XBMC, SHARP Aquos BD-HP25U DLNA Blu-Ray Player
HowTo: Provide supported formats of a device | Record a new ticket on Bitbucket | Provide details of a video file that doesn't play | Turn on detailed logging
imbibed
Post Wed Apr 18, 2012 6:39 am
CBS.com allows some shows to stream outside of the US. Examples include 60 minutes and (most) 48 Hours Mystery episodes. I review them regularly here in the Netherlands.
There is an issue with the plugin, however... I have noticed that CBS doesn't seem to be updating http://www.cbs.com/shows/48_hours/video/
For 48 Hours Mystery, CBS seems to be focusing their attention on http://www.cbsnews.com/video/48hours/ when posting new episodes.
I can't seem to get serviio to get the new shows from the updated URL
Any tips anyone?
glenb07
Post Tue Apr 24, 2012 1:05 am
Is there any way to make the plugin so that it plays the classic shows from the cbs website; they are under a subfolder named 'classics'. they fail with the naming convention for the plugin.
thanks.
mike_metro
Post Wed Apr 25, 2012 2:21 am
imbibed wrote:CBS.com allows some shows to stream outside of the US. Examples include 60 minutes and (most) 48 Hours Mystery episodes. I review them regularly here in the Netherlands.
Any tips anyone?
Unfortunately this plugin doesn't work on cbsnews.com. They use a different method of loading up videos on their site. Looks like someones else has requested cbsnews.com as well.
mike_metro
Post Wed Apr 25, 2012 2:22 am
glenb07 wrote:Is there any way to make the plugin so that it plays the classic shows from the cbs website; they are under a subfolder named 'classics'. they fail with the naming convention for the plugin.
thanks.
Nice catch. Looks like I need to add classics, originals, and specials to the plugin. I'll try to get it updated this week.
mike_metro
Post Sun Apr 29, 2012 7:28 pm
thanks.
Sorry, these use a different method of loading up videos. This will be a much bigger fix. Not sure when I will be able to get to it.
CigDangle
Post Thu Aug 16, 2012 5:16 pm
I have been having issues with this plug-in lately: it displays NO content. It recently worked and the only thing I have done is upgrade to Serviio 1.0.1.
Anyone else seeing this?
Xbox 360 - PlayStation 3 - Sony BDP-S370 - HTC Evo V & HP TouchPad running CM9 (Android) - serviio 1.0.1 - Windows 2003 Server Standard x64 Edition
iplem
Post Thu Aug 16, 2012 8:11 pm
Yes, I have being seen the same issue since the upgrade to 1.0
datajan
Post Fri Aug 17, 2012 4:40 pm
Same problem here, I upgrade to 1.0.1 and now I don't see any content, only the folders I used to have in the previous version. In video as well as photo. Not a single content file.
I now have double choices in the security settings (so 4 in total), neither works.
I was about to go PRO when I discovered that the security works only on a device basis, not folder or file based. That is useless for me. I want to secure certain types of movies, on our main TV.
sagan
Post Sat Aug 18, 2012 7:06 pm
I have not upgraded.
CBS worked last time I checked, probably about 1 month back.
Format was WebResource=http://www.cbs.com/shows/how_i_met_your_mother/video/
But as of yesterday, with no change to software or config, I am not getting any shows to appear.
When I played with the groovy file a bit, it seems to be correctly fetching the "loadUpCarousel" part.
-becomes-
http://www.cbs.com/carousels/44/video/0 ... f9a/0/100/
But that's as far as I made it, after that I think we need a real groovy expert.
This is a WebResource, so maybe the groovy file is not compatible a (potentially new) CBS json format?
I have other Atom Feeds that work, no other Web Resources to try.
If I did have other WebResources, and they worked, I would suspect it was CBS has a new json format.
CigDangle
Post Sat Aug 25, 2012 1:09 pm
Is anyone working on updating this?
Really wish I had a stronger coding background/new groovy... Fall season starts soon!
xs2inattar
Post Sun Aug 26, 2012 1:08 am
The feed url was changed.
I have made the changes to the plugin.
Please test this and let me know.
if everything is working fine, mike_metro please update the first post of this thread with this.
CBS.groovy
(5.26 KiB) Downloaded 2814 times
mike_metro
Post Sun Aug 26, 2012 5:11 am
Tested. Thanks xs2inattar. Appreciate the assistance.
xs2inattar wrote:The feed url was changed.
misterbkh
Post Wed Aug 29, 2012 4:58 pm
thanks.
I tried adding some perry mason and i love lucy from classics but doesn't show up, has classics been implemented yet? or maybe i am adding it wrong?
mike_metro
Post Thu Aug 30, 2012 12:26 am
misterbkh wrote:
thanks.
Sorry I haven't implemented the classics yet, they use a totally different method.
mikeyboyuk
Post Thu Sep 20, 2012 5:08 pm
Hi Mike,
Thanks very much for this plugin. I was using it on a daily basis to watch The CBS Evening News but, unfrotunately, CBS have recently started to upload this programme via their http://www.cbsnews.com/ website instead.
I saw earlier in this post that you've already mentioned how http://www.cbsnews.com/ use a different method for uploading their videos. I was just wondering if there might be any chance of creating a plugin to work for this too?
I'm currently able to get the programme via an RSS feed (http://feeds.cbsnews.com/podcast_eveningnews_video_1), but the quality is rather poor.
Many thanks,
(another) Mike
josiok
Post Tue Oct 09, 2012 7:27 pm
I've been using CBS plugin for some time without a problem. Now I'm not seeing any shows. Using Serviio Pro 1.0.1. I've updated to cbs.groovy version 2.0 (5,390 bytes) and rebooted.
URLs are: http://www.cbs.com/shows/the_good_wife/video/
and http://www.cbs.com/shows/60_minutes/video/
Source Type is set to 'Web Resource'
Neither show works. All other feeds seem fine. Any help is appreciated!
Return to Available plugins
