I am using this version of the WebUI and it loads with no issues, and all buttons seem like they work, however, if I click the SAVE button on ANY screen I get the following errors (one after the other):
- pc5dczc_WebUI_Error.png (32.09 KiB) Viewed 69156 times
I am running the following :
Linux :
ClearOS 6.2 Community Final Release (was just released this past week)
Serviio server 0.6.2
Serviio WebUI v1.0.1
I've installed Serviio using the following instructions :
http://www.clearfoundation.com/component/option,com_kunena/Itemid,232/catid,40/func,view/id,25951/ I've installed the WebUI into a sub-folder in my default web site (/var/www/html/serviio).
I did copy the files from the .zip into the serviio folder instead of the serviioweb default folder (I was getting the error either which way).
It seems as though Serviio is running with no errors from what I can tell (although I'm not really sure how to check without the webui fully working).
If I restart the Serviio service, I do see the "checking updates" and "Checking Additions" go green temporarily once the Serviio service restarts. So to me this makes it look like Serviio itself is working.
I instinct tells me this problem is a permissions issue, but I'm not sure based on that error if that's actually the case (since it's referring to the ./lib/serviio.php file line 608 which is looks like it cannot write(create) an xml file?)
ANY help on this would be hugely apreciated!
Spyrule.
P.s. - I've added a screenshot of my WebUI just in case it helps for whatever reason.
