Cant see Files
kaisersoze
Post Wed Apr 18, 2012 4:35 pm
Re: Cant see Files
Hello
I'm using ubuntu server 10.4 and Sharp Aquos 924 TV.
My problem is that I cannot see music(mp3) and video files (avi).
Log is in attachment no error at all, some music files are added without problems (it can be seen in log), folder structures are created but files are missing.
Message from TV "No data available".
Pictures are working fine.
File permissions are the same for pictures, music and movies.
Any help?
More information on request
Thank You in advance
Sharp.log
(130.23 KiB) Downloaded 612 times
Post Fri Apr 20, 2012 1:17 pm
Re: Cant see Files
are you going throught the right category on your TV? I mean you have to select audio on your TV first and then again Audio folder that serviio presents.
kaisersoze
Post Mon Apr 23, 2012 8:22 am
Re: Cant see Files
Yep
Music -> Audio
Or Video->Video
"No content available"
Like i said Images working fine
kaisersoze
Post Sun Oct 14, 2012 1:59 pm
Re: Cant see Files
Updated to Serviio 1.0.1 still the same problem - images are ok but can't see music or movie files.
ffmpeg is compiled without any errors.
TV is upgraded with newest firmware.
Another issue: when starting serviio-console on Ubuntu server 10.04 i got this error:
No X11 DISPLAY variable was set, but this program performed an operation which requires it.
Tried with export DISPLAY:0.0 no progress.
Console is now started from Windows (because of this X11 error)
Kind regards
Post Mon Oct 15, 2012 1:56 pm
Re: Cant see Files
did you check the log if any music/video files have been added?
kaisersoze
Post Tue Oct 16, 2012 10:43 am
Re: Cant see Files
Files have been added succesfully according to log file and like I said before folder structure is created too.
Finally I got some progress.
Mkv files are shown and playing without any problems even HD.
Avi or mp3 files could not be seen - all that folders are empty ("No content available").
ffmpeg -i for all video files is ok.
Same avi content on USB directly connected to Sharp Aquos TV is working well.
Maybe different profile could help?
Do you need any additional info?
Kind regards
kaisersoze
Post Wed Oct 31, 2012 5:07 pm
Re: Cant see Files
Finally got some time to test.
Tested serviio server with WD Live client - everything working fine.
Playing a bit with profiles, found that Sony Bravia 2012 US profile does work with avi, divx etc files - but not with mkv.
So i created new Sharp aquos profile (merging Sharp original and Sony Bravia 2012 US profiles) and now videos working fine - mkv, avi, divx...
It is not great since dual audio and subtitles dont work with DLNA (working well with usb directly connected to TV) - but this is a TV issue.
Audio (mp3) doesnt work with either profiles but actually I dont need that.
So if anyone has Sharp Aquos LE824/924 TV - try to mix above mentioned profiles.
Kind regards
Previous
Users browsing this forum: Google [Bot] and 62 guests
