PROBLEM with RSS on NAS DLINK 320
jcollari
Post Wed Apr 11, 2012 7:37 pm
Hi I installed 0.6.1 on SERVIIO DLINK 320 NAS
I have a LCD TV Samsung C550.
I state that the DLNA works very well and I read all the files I have on my folders, I installed the plugins for YOU TUBE
The problem I have left on online sources, I put RSS as the examples you provide
http://gdata.youtube.com/feeds/api/stan ... /top_rated
But when I open the Media TV and I'm on the VIDEO section proposes the empty folder SOURCES ONLINE
What's wrong?
Can you tell me if the links are wrong, I was interested to see the music video of YOU-TUBE
Thank you for your. attention
Sorry for English .... I'm Italian and I do not speak English very well
Post Wed Apr 11, 2012 10:17 pm
Re: PROBLEM with RSS on NAS DLINK 320
jcollari
Post Thu Apr 12, 2012 8:54 pm
This is my file log ...
HELP MY PLEASE
(10 KiB) Downloaded 697 times
Post Fri Apr 13, 2012 12:25 pm
it's not the detailed log. see my signature on how to enable it.
jcollari
Post Mon Apr 16, 2012 9:33 pm
ok this is detailed log
help me please
thanks
(442.95 KiB) Downloaded 746 times
Post Tue Apr 17, 2012 11:22 am
is the feed resource enabled in the console? (checkbox on the left side of the feed table)
jcollari
Post Thu Apr 19, 2012 12:15 pm
Thanks for your reply
but now i have this log
[FeedUpdaterThread] An error occured while scanning for online item information, will continue
java.io.IOException: Server returned HTTP response code: 400 for URL: http://gdata.youtube.com/feeds/base/use ... ploads?alt
at sun.net.www.protocol.http.HttpURLConnection.getInputStream(HttpURLConnection.java:1403)
(21.13 KiB) Downloaded 668 times
Post Fri Apr 20, 2012 1:15 pm
The URLs that you use are not correct.
jcollari
Post Sat Apr 21, 2012 12:32 pm
OK THANKS !!!
and this error ?
2012-04-20 23:29:05,350 WARN [FeedUpdaterThread] An error occured while retrieving thumbnail, will remove it from the item the and will continue
org.serviio.library.online.CannotRetrieveThumbnailException: An error accured when resizing thumbnail http://nl.video.movieplayer.it/trailer/ ... -10493.mp4
at org.serviio.library.online.OnlineLibraryManager.findThumbnail(OnlineLibraryManager.java:260)
at org.serviio.library.online.metadata.FeedUpdaterThread.run(FeedUpdaterThread.java:106)
2012-04-20 23:30:32,808 WARN [CoverImageService] Cannot convert/resize art to JPG. Message:
2012-04-20 23:30:33,046 WARN [FeedUpdaterThread] An error occured while retrieving thumbnail, will remove it from the item the and will continue
org.serviio.library.online.CannotRetrieveThumbnailException: An error accured when resizing thumbnail http://nl.video.movieplayer.it/trailer/ ... -10492.mp4
2012-04-20 23:31:55,993 WARN [CoverImageService] Cannot convert/resize art to JPG. Message:
2012-04-20 23:31:56,129 WARN [FeedUpdaterThread] An error occured while retrieving thumbnail, will remove it from the item the and will continue
org.serviio.library.online.CannotRetrieveThumbnailException: An error accured when resizing thumbnail http://nl.video.movieplayer.it/trailer/ ... -10491.mp4
2012-04-20 23:34:59,067 WARN [CoverImageService] Cannot convert/resize art to JPG. Message:
2012-04-20 23:34:59,717 WARN [FeedUpdaterThread] An error occured while retrieving thumbnail, will remove it from the item the and will continue
org.serviio.library.online.CannotRetrieveThumbnailException: An error accured when resizing thumbnail http://nl.video.movieplayer.it/trailer/ ... -10490.mp4
2012-04-20 23:39:55,105 WARN [CoverImageService] Cannot convert/resize art to JPG. Message:
2012-04-20 23:39:56,844 WARN [FeedUpdaterThread] An error occured while retrieving thumbnail, will remove it from the item the and will continue
org.serviio.library.online.CannotRetrieveThumbnailException: An error accured when resizing thumbnail http://nl.video.movieplayer.it/trailer/ ... -10489.mp4
Post Sat Apr 21, 2012 11:07 pm
what feed is that? do you have a plugin?
jcollari
Post Sun Apr 22, 2012 7:52 pm
i have plugin for YOU TUBE but now i have this error
2012-04-22 21:49:42,138 WARN [FeedUpdaterThread] An error occured while scanning for online item information, will continue
java.net.UnknownHostException: gdata.youtube.com
at java.net.AbstractPlainSocketImpl.connect(AbstractPlainSocketImpl.java:175)
at java.net.Socket.connect(Socket.java:546)
at sun.net.NetworkClient.doConnect(NetworkClient.java:169)
at sun.net.www.http.HttpClient.openServer(HttpClient.java:409)
at sun.net.www.http.HttpClient.openServer(HttpClient.java:530)
at sun.net.www.http.HttpClient.<init>(HttpClient.java:240)
at sun.net.www.http.HttpClient.New(HttpClient.java:321)
at sun.net.www.http.HttpClient.New(HttpClient.java:338)
at sun.net.www.protocol.http.HttpURLConnection.getNewHttpClient(HttpURLConnection.java:935)
at sun.net.www.protocol.http.HttpURLConnection.plainConnect(HttpURLConnection.java:876)
at sun.net.www.protocol.http.HttpURLConnection.connect(HttpURLConnection.java:801)
at sun.net.www.protocol.http.HttpURLConnection.getInputStream(HttpURLConnection.java:1139)
at org.serviio.util.HttpClient.retrieveBinaryFileFromURL(HttpClient.java:73)
at org.serviio.library.online.feed.FeedParser.parseFeedStream(FeedParser.java:113)
at org.serviio.library.online.feed.FeedParser.parse(FeedParser.java:89)
at org.serviio.library.online.OnlineLibraryManager.findResource(OnlineLibraryManager.java:167)
at org.serviio.library.online.OnlineLibraryManager.findResourceInCacheOrParse(OnlineLibraryManager.java:184)
at org.serviio.library.online.metadata.FeedUpdaterThread.getOnlineItems(FeedUpdaterThread.java:158)
at org.serviio.library.online.metadata.FeedUpdaterThread.run(FeedUpdaterThread.java:95)
WHAT IS THIS ?
THANKS
Post Sun Apr 22, 2012 9:34 pm
what is the youtube url you're using?
Post Mon Apr 23, 2012 7:41 pm
can you open these URLs on the machine that runs Serviio?
jcollari
Post Sat Apr 28, 2012 7:16 am
Hi, I can say what I have to put RSS to view videos on this site?
http://www.youtube.com/user/ItalyOfficialChart/feed
and
http://www.mymovies.it/trailer/
thanks
Post Sun Apr 29, 2012 10:52 pm
