2 COMPUTERS 2 ROUTERS
ANTHONY VAN PYRE
Post Mon Apr 23, 2012 11:31 pm
I HAVE 2 COMPUTERS. EACH ON THEIR OWN CONNECTION WITH THEIR OWN ROUTER.
ALL MY STUFF (APPLE TV, INTERNET TV, SONY BLU RAY, XBOX360) RUN THOUGH THE 1 CONNECTION AND THATS ALL FINE I CAN USE ALL THAT.
BUT WHAT I WOULD LIKE TO BE ABLE TO DO IS TO ALSO STREAM STUFF FROM THE SECOND CONNECTION (WHICH NONE OF THE OTHER DEVICES ARE USING) ALSO. (SO STUFF FROM COMPUTER 2 STREAMS TO THE BLU RAY THE XBOX ETC THAT IS USING THE CONNECTION FROM COMPUTER 1)
ANYWAY SERVIIO CAN HELP ME ACCOMPLISH THIS?
Post Tue Apr 24, 2012 7:16 am
Re: 2 COMPUTERS 2 ROUTERS
If they are on two separate subnets then no as DLNA uses multicast for discovery.
Do you have two separate phone lines? The solution would be to turn the second router into just a switch, but would need more information on your network to see if that would work. Otherwise, putting a second network card in server 2, and plugging it into router 1 would work. A nice network diagram, or at least a list of components and IP addresses would help.
Please don't use caps, it's a pain to read.
Users browsing this forum: Baidu [Spider] and 20 guests
