Many entries of the same movies are displaying
rednyle
Post Fri Apr 27, 2012 6:36 pm
I just installed Serviio onto a Windows 7 machine and all is running great so far except for one small problem. For certain movies, I'm getting multiple displays. For example, I have an MKV file of Avatar and it's showing up like 4 or 5 times; some movies are coming up 10 or more times. I noticed that this is mostly for MKV file as I have a mixture of AVI & MP4. Does anybody know how to fix this?
Thanks!
Post Fri Apr 27, 2012 11:38 pm
Re: Many entries of the same movies are displaying
so when you go via Folders category, does it show 5 Avatar movies where there should be just one? And when you play then are they all really Avatar movies?
Mlorb
Post Tue Jan 07, 2014 4:15 pm
Sry don't have a solution for this problem, but working on it just wanted to reup the thread to see if anyone else still having these problems, and if anyone has come up with a solution yet. I'm having the same problem with some movies, the worst one seems to be not even a movie really "Family Guy 9x18 It's a Trap" shows up in the movie folder like 60 times as 175 mb files, when the file itself is 563 mb.
Post Wed Jan 08, 2014 12:35 am
Does it appear in Folders once only? When you play the file is it really Family Guy 9x18 It's a Trap or is it some other movie?
What are your metadata settings in Serviio Console (Descriptive Metadata - what is the source).
Check the folder for any .nfo files.
ps. Isn't Family Guy 9x18 It's a Trap a series episode - doesn't it appear under the Series category?
Iveky
Post Wed Jan 08, 2014 6:19 am
what is your dlna client?
i noticed same problem on new version vlc (2.1.2), on old was without problems.
