Serviio with Windows Media Player
adambeef
Post Sat Apr 28, 2012 2:21 pm
Hi Guys
I have serviio working great with my PS3 and android tabs and phones
Any ideas how i can get it working with Windows Media Player in windows 7?
Serviio media centre shows up in there but none of the media appears?
Post Sat Apr 28, 2012 2:30 pm
Re: Serviio with Windows Media Player
WMP isn't supported as it isn't DLNA compliant. I think it may work if you try using the XBOX 360 profile. Otherwise, VLC 2.0 or XBMC are good software players that work.
Return to User experiences
