Subtitels hebrew fonts is seen Gibberish
uridavid
Post Sat Apr 28, 2012 2:06 pm
when i start a movie with Hebrew subtitles the fonts on the TV looks Gibberish
do i need to setup anything to see Hebrew?
Post Sat Apr 28, 2012 2:34 pm
Re: Subtitels hebrew fonts is seen Gibberish
How subtitles are displayed is completely up the the device, the server (serviio) just provides the device with the file containing them. There may be something on your tv that you could try, but your best bet would probably be from your devices support form etc... Is your tv and english one, or is the menu in hebrew, if it is in hebrew, I would have expected it to render the subtitles correctly.
Post Sun Apr 29, 2012 11:31 am
make sure the srt file is saved in UTF-8. Otherwise check with Samsung support on what encoding the file should be saved with.
Ronen
Post Fri May 04, 2012 12:56 pm
Try this:
On your TV remote (while watching something with Hebrew gibberish subtitles) click on the "Tools" button and choose "Subtitle Setting"
In the "Encoding" make sure Hebrew is selected.
