siriusblack
Post Sun Apr 29, 2012 3:20 pm
I've been post in the wrong place
Sorry bout that
I'm new to this I'm using windows7 with atom 2gb
Im using wiziwig with sopcast Everything I stream it freezes or stutters or even if
I use the rss feeds they also stutter or freeze
Can you plz tell me why that happens
I'm streaming to a Samsung ue46 c8000 led 3D tv & ps3's they all freeze
Can you plz help me
Thank you
Beta Tester
WildRushSykes
Post Mon Apr 30, 2012 8:09 am
Re: General
could be either an underpowered machine or a bottleneck in your home network are you using wireless or wired internet on your ps3 and laptop? also one other thing to check is if it stutters on a file that plays natively on the ps3. try chucking a 720p xvid with mp3 or ac3 audio file at it and see if it still stutters if so its a network issue.
siriusblack
Post Mon Apr 30, 2012 8:23 am
Re: General
ok will try that l8r thanks 4 getting back apprieciate ur help
Beta Tester
siriusblack
Post Mon Apr 30, 2012 9:29 am
Re: General
SORRY forgoto tell you im using wireless on laptop & ps3s im using bt infinity can you plz send me a link to try out 720p xvid with mp3 or ac3 audio file
thanks
Beta Tester
Return to General discussion
