Web UI in PHP - support thread
spyrule
Post Mon Apr 30, 2012 12:35 am
Re: Web UI in PHP (revised)
npuser wrote:i believe curl and xml are required for this work properly. plz double check if the xml mod is install, the parsererror could be due to permission but the class DOMdocument error looks like it is due to missing xml module from your install.
NPuser
Thanks for the hint, however I did check those (I forgot to mention this).
PHP Version 5.3.3
Apache/2.2.15 (ClearOS Core)
I havn't made any changes to php nor apache configurations, and as for the serviio installation, I exactly followed the previous link, except for the older WebUI near the bottom, because I could not get the links to work from that version (older 0.5.x).
The only thing I did, was :
"chown -R apache:apache /var/www/html/serviio ", just to make sure it would have the necessary rights to act as a website.
Not sure if this has an effect, however :
I installed ffmpeg using :
http://www.clearfoundation.com/component/option,com_kunena/Itemid,232/catid,39/func,view/id,39198/#39463
I specifically used the ffmpeg-rhel.run script to get ffmpeg installed and compiled completely.
Again, thanks for the help,
Spyrule Image
npuser
Post Mon Apr 30, 2012 12:46 am
Try
yum install php-xml
Please check the serviio log to make sure your serviio is actually running. Default webui install looks at $pc5dczc_host = "127.0.0.1" for serviio host.
NPuser
spyrule
Post Mon Apr 30, 2012 12:57 am
npuser wrote:Try
yum install php-xml
That fixed one error (nice catch btw, It seems as though ClearOS 6.2 is missing a lot of the standard (previously included) apps... like wget, yum... :o ).
But now I get this error when I click save :
Spyrule
mpemberton5
Post Mon Apr 30, 2012 1:04 am
spyrule wrote:
npuser wrote:Try
yum install php-xml
Spyrule
Yep, that's a bug. Been there a while. Sounds like you have php errors displaying. Easiest thing to do is delete line 126 in the stated file. Will be fixed in the next revision.
npuser
Post Mon Apr 30, 2012 1:06 am
fh variable looks ok in my install. could you make sure if you have $ in front of fh?
NPuser
spyrule
Post Mon Apr 30, 2012 1:11 am
npuser wrote:fh variable looks ok in my install. could you make sure if you have $ in front of fh?
NPuser
Yup its there :
 protected function executePut ($ch)
                if (!is_string($this->requestBody))
                        $this->buildPostBody();
                $this->requestLength = strlen($this->requestBody);
                curl_setopt($ch, CURLOPT_HTTPHEADER, array('Content-Type: application/xml; charset=UTF-8'));
        curl_setopt($ch, CURLOPT_CUSTOMREQUEST, "PUT");
        curl_setopt($ch, CURLOPT_POSTFIELDS,$this->requestBody);
                $this->doExecute($ch);
                fclose($fh);
However, something that I just realized, it looks like it's saving my configuration changes, but this error is still generated on all windows.... odd.
npuser
Post Mon Apr 30, 2012 12:43 pm
Mark confirmed its a bug. Like he said, you can actually comment that line out.
thanks
NPuser
qoolbox
Post Tue May 01, 2012 10:30 am
Hi
Just made a module for Thecus NAS (based on busybox) just experience some bugs
in Library TAB :
Add locale : works but doesnt validate the path
Add localy works but each time I enter a path i have to save one by one, if i do in one shot it doesnt validate all directories submited
in Presentation TAB :
Doesnt validate any of my configuration and keep the default configuration
General bug :
Doesnt seems to index files and directory inside an UTF-8 named directory (if a directory has specials caracters éàè... directory is displayed but not scanned and files not display on DLNA TV)
Somes of This bugs were submited already with the Ajax Kairoh previous version and has been resolved... wish the PHP Webui version can work fine :?
thanks for your help,
Best regards,
Third Party Thecus NAS Develloper
http://forum.thecus.com
http://www.tsuga.fr
Xmantium
Post Wed May 02, 2012 7:13 am
qoolbox wrote:in Presentation TAB :
I thought only QNAP NAS users were only having this issue
Do you mean, when you press "Save", all the values reset to "Display Content"?
qoolbox
Post Wed May 02, 2012 11:27 am
Hi Xmantium
Yes, when i make a config, and save all is reset to default config...
I confirm also the issue with UTF-8 encoding name (i have well set the localedef of the NAS to en-Us-UTF8) the name are display on the my DLNA TV, but no indexing the files inside.
Before i had a directory called "Séries" and i rename it into "Series" and now file are indexed...
http://www.tsuga.fr
qoolbox
Post Wed May 02, 2012 5:49 pm
I resolved all the main problem, it was due to PHP version embedded in Thecus ...
I upgrade to PHP 5.3.9 and use it as dependency .. and all run fine (not yet tested the UTF-8 problem)
Now Thecus has a new Serviio Module Avaiable :P
http://forum.thecus.com/viewtopic.php?f=36&t=3610
thanks for your work...
http://www.tsuga.fr
qoolbox
Post Thu May 10, 2012 5:42 pm
Bugs confirmed :
- UTF-8 FIles are not display on the DLNA Client (but WEBUI turned in french display well the éèà characters, and localdef is well set in the NAS Environnement)
- adding files by browsing in the Shared Folder TAB doesnt work because interface seems to add a "/" at the end of the Path removing it manually, make it works
http://www.tsuga.fr
Xmantium
Post Thu May 10, 2012 6:50 pm
I've got embedded PHP 5.2.14, how do you mean by dependency?
I've had the presentation save bug since the start on my QNAP NAS
qoolbox
Post Fri May 11, 2012 6:24 am
In Thecus embbeded PHP is also an old Release... a user made a PHP 5.3.9 module and i use it as dependency (i mean i force the Serviio module to use this PHP release instead of the embbeded one)
simply i use a .htaccess file to force it ...
have a look here for more info :
http://www.fajo.de/main/en/thecus/modules/php53
http://www.tsuga.fr
Xmantium
Post Fri May 11, 2012 10:27 am
My PHP version is not very old so dont think that is the issue, the QNAP admins are updating to PHP 5.3 in our next firmware that should be released end of this month. So I'll see what happens after the update.
lmd
Post Tue May 15, 2012 1:39 am
Hi all,
I am running an old laptop as my media server now, and am using the latest version of Ubuntu server, along with LAMP and Webmin. I've got the latest version of the web ui working, but I am unable to save any Online Resources. I can add items from the local machine just fine. Streaming to my Samsung D series TV works perfectly too.
Very happy - but if someone could point me in the right direction to get the online streams/feeds working I'd really appreciate it!
So far I have made sure that the read/write permissions to the folders are set, .htaccess shouldn't be necessary as it's been chucked in the /var/www/ folder (correct?) and I'm sure it's not a firewall issue from my computer.
Overall though - very happy with it as part of my home media solution! :)
Thanks,
Andy :)
lmd
Post Sat May 19, 2012 12:05 pm
lmd wrote:Hi all,
Thanks,
Andy :)
Anybody else have this problem? I'm running Ubuntu 12.04, LAMP, PHP cURL, PHP-XML etc. but can't seem to see what's going wrong.
Is there an email address I can send details of this issue to? I've looked at the Wiki but can only see very simple installation instructions.
Could it possibly be a permissions problem for the directory where the RSS/Atom feeds are stored on my server?
Cheers,
Andy
mpemberton5
Post Sat May 19, 2012 4:39 pm
lmd wrote:
lmd wrote:Hi all,
Thanks,
Andy :)
Cheers,
Andy
Hey Andy, sorry about not getting back to you. So is it just the Online Sources that you can't save? You can turn on debugging in the config.php file. There are two options that you turn on as "true". Once you do that, you'll see a panel at the bottom of the screen that will show additional information. Turn on the debug options, try to add an Online Source, hit save and see what shows up at the bottom. Do some screenshots and attach them to a post along with any other details that you might have. Hopefully this will get us started in the right direction.
Thanks!
lmd
Post Sun May 20, 2012 9:05 am
mpemberton5 wrote:
lmd wrote:
lmd wrote:Hi all,
Thanks,
Andy :)
Cheers,
Andy
Thanks!
Hey Mark,
My apologies for appearing impatient, but I'm very close to having my 'dream' setup working, this is just the last hurdle to get over. So, I've switched debugging to 'debug' and debug location to 'screen' in the config.php (thanks for the handy comments in there!). So, now I see a text box with 'POST' data and another with 'Response' data.
When I try to add an Online Source (in this case, one of my playlists from YouTube - yes I have the YouTube groovy installed), I get the result of... nothing in the error boxes.
Is there something I've missed in the config.php?
Thanks!
Andy
P.S. I've checked and I have JavaScript enabled, as well as tested in Firefox, Google Chrome and Safari with the same result.
lmd
Post Sun May 20, 2012 3:02 pm
OK - I'm a wally!
I've got the error message showing up now - parser error.
Error: Error: Invalid XML:
Notice: Undefined variable: fh in /var/www/serviioweb/lib/RestRequest.inc.php on line 126
Warning: fclose() expects parameter 1 to be resource, null given in /var/www/serviioweb/lib/RestRequest.inc.php on line 126
<?xml version="1.0" encoding="UTF-8" ?>
<result>
  <errorCode>0</errorCode>
  <httpCode>200</httpCode>
</result>
Is this a setting problem my side or a bug?
Thanks for your help!
Cheers,
Andy
