mp4 not supported on Samsung TV D6100
ciso
Post Thu Apr 26, 2012 4:18 pm
I installed ServiiO a couple of weeks ago and I think it's really great!
I have only one problem, I can't plya mp4 videos to my Samsung TV D6100 because I get the "Not Supported File Format" message.
This is my ffmpeg output:
ffmpeg version 0.8.1-4:0.8.1-0ubuntu1, Copyright (c) 2000-2011 the Libav developers
  built on Mar 22 2012 05:29:10 with gcc 4.6.3
This program is not developed anymore and is only provided for compatibility. Use avconv instead (see Changelog for the list of incompatible changes).
Input #0, mov,mp4,m4a,3gp,3g2,mj2, from 'south.park.s16e07.hdtv.x264-compulsion.mp4':
    major_brand     : isom
    minor_version   : 1
    compatible_brands: isomavc1
    creation_time   : 2012-04-26 02:33:23
  Duration: 00:21:41.37, start: 0.000000, bitrate: 472 kb/s
    Stream #0.0(und): Video: h264 (High), yuv420p, 720x404, 341 kb/s, 23.98 fps, 23.98 tbr, 96k tbn, 47.95 tbc
    Stream #0.1(und): Audio: aac, 48000 Hz, stereo, s16, 126 kb/s
      creation_time   : 2012-04-26 02:33:24
No problem if I use an Android phone with Twonky as a bridge (ServiiO as server but using the smartphone to play the mp4 to the TV).
Post Sun Apr 29, 2012 10:50 pm
Re: mp4 not supported on Samsung TV D6100
Did you try it without the phone? Otherwise assign the Samsung c/d profile to the IP of the phone in the console.
ciso
Post Mon Apr 30, 2012 6:14 am
zip wrote:Did you try it without the phone? Otherwise assign the Samsung c/d profile to the IP of the phone in the console.
Yes,
the prolem it's only if I use directly the Serviio service from the Samsung TV.
The Samsung C/D profile is automaticaly assigned from serviio.
