Any way to remove the Serviio icon from the system tray?
rampage
Post Mon Apr 30, 2012 11:45 am
Hi, I was wondering if there is anyway to remove the Serviio icon from the bottom right system tray but still have it running. I seem to think I was able to do this in previous versions but I do not see an option to do it now.
Thanks!
Post Mon Apr 30, 2012 12:40 pm
Re: Any way to remove the Serviio icon from the system tray
in Windows you can go to the properties of the task bar and mark the icon to be always hidden, if I'm not mistaken
rampage
Post Tue May 01, 2012 12:54 pm
Yes but then it gives me that stupid arrow next to it instead.... I don't remember the last version of Serviio having an icon though. Any other thoughts?
Post Wed May 02, 2012 11:51 am
It always used to have an icon.
But you don't really need to start the console automatically on Windows start (if you are fully configured). In that case just remove it from the Startup folder in the Start menu. The service is enough for streaming.
rampage
Post Thu May 03, 2012 9:42 pm
Great, thanks for the tip!
Users browsing this forum: Google [Bot] and 37 guests
