Samsung D550 Dont Playing Video Stream
cartucho
Post Tue May 01, 2012 2:19 am
Hi, I new in serviio and DNLA world in general, and I have a problem trying to play a stream in my Samsung D-Series TV.
I use serviio 0.6.2 and I added various Streams from this excellent post made by jhb50 (thanks!)
The streams what don't play are from HD_Channels rss and all are from tv.futubox.com.and the error what my TV display is: Video Coded Not Supported
The streams are ON, I checked with my WDTV Live (thru serviio) and work OK.
ffmpeg output is this:
C:\Program Files\Serviio\lib>ffmpeg -i rtsp://tv.futubox.com:1935/live/z050001.stream
nfig
  libavutil    51. 32. 0 / 51. 32. 0
  libavcodec   53. 42. 0 / 53. 42. 0
  libavformat  53. 24. 0 / 53. 24. 0
  libavfilter   2. 53. 0 /  2. 53. 0
[rtsp @ 003f81e0] UDP timeout, retrying with TCP
[rtsp @ 003f81e0] Estimating duration from bitrate, this may be inaccurate
Input #0, rtsp, from 'rtsp://tv.futubox.com:1935/live/z050001.stream':
    title           : rtmp://s2.futubox.com:1935/s2/_definst_/z050001.stream
  Duration: N/A, start: 0.022993, bitrate: N/A
    Stream #0:0: Audio: aac, 44100 Hz, stereo, s16
    Stream #0:1: Video: h264 (Constrained Baseline), yuv420p, 1280x720 [SAR 1:1
DAR 16:9], 25 fps, 25 tbr, 90k tbn, 50 tbc
apparently the video codec is h264 what my Samsung D supports, so what is the problem?
Thanks in advance!
iplem
Post Tue May 01, 2012 6:38 am
Re: Samsung D550 Dont Playing Video Stream
I'm facing the same problem since many HD links were changed to futubox. My TV is a D550 too.
I checked some profiles without success.
From the serviio DEBUG log:
2012-05-02 00:18:16,854 DEBUG [ResourceTransportRequestHandler] HEAD /resource/1000000000070001/MEDIA_ITEM/MPEG_PS_NTSC*0 HTTP/1.0, headers = [getcontentFeatures.dlna.org: 1,Host: 10.0.0.4:8895]]
2012-05-02 00:18:16,855 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 10.0.0.10
2012-05-02 00:18:16,855 DEBUG [ResourceTransportRequestHandler] Resource request accepted. Using client 'IPAddress=/10.0.0.10, Profile=Samsung TV / player (C/D-series)'
2012-05-02 00:18:16,855 DEBUG [ResourceTransportRequestHandler] Request for resource 1000000000070001 and type 'MEDIA_ITEM' received
2012-05-02 00:18:16,855 DEBUG [MediaResourceRetrievalStrategy] Getting information about media item 1000000000070001 (online)
2012-05-02 00:18:16,856 DEBUG [OnlineRepositoryDAOImpl] Reading an OnlineRepository (id = 7)
2012-05-02 00:18:16,857 DEBUG [VideoDeliveryEngine] Retrieving resource information for item 1000000000070001, format MPEG_PS_NTSC and profile Samsung TV / player (C/D-series)
2012-05-02 00:18:16,857 DEBUG [AbstractTranscodingDeliveryEngine] Getting media info for transcoded version of file rtsp://tv.futubox.com:1935/live/z050001.stream
2012-05-02 00:18:16,857 DEBUG [VideoDeliveryEngine] Found Format profile for transcoded file rtsp://tv.futubox.com:1935/live/z050001.stream: MPEG_PS_PAL
2012-05-02 00:18:16,857 DEBUG [VideoDeliveryEngine] Found Format profile for transcoded file rtsp://tv.futubox.com:1935/live/z050001.stream: MPEG_PS_NTSC
2012-05-02 00:18:16,857 DEBUG [ResourceTransportRequestHandler] Sending HEAD response back
2012-05-02 00:18:16,857 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 200 OK, headers = [[Content-Type: video/mpeg,Content-Length: 50000000000,Date: Tue, 01 May 2012 21:18:16 GMT,Server: Windows 7, UPnP/1.0 DLNADOC/1.50, Serviio/0.6.2,Cache-control: no-cache,contentFeatures.dlna.org: DLNA.ORG_PN=MPEG_PS_NTSC;DLNA.ORG_OP=00;DLNA.ORG_CI=1;DLNA.ORG_FLAGS=8D500000000000000000000000000000,transferMode.dlna.org: Streaming]]
2012-05-02 00:18:16,867 DEBUG [WebServer] Incoming connection from /10.0.0.10:57892
2012-05-02 00:18:16,867 DEBUG [ResourceTransportRequestHandler] GET /resource/1000000000070001/MEDIA_ITEM/MPEG_PS_NTSC*0 HTTP/1.0, headers = [getcontentFeatures.dlna.org: 1,transferMode.dlna.org: Streaming,getMediaInfo.sec: 1,Host: 10.0.0.4:8895]]
2012-05-02 00:18:16,867 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 10.0.0.10
2012-05-02 00:18:16,867 DEBUG [ResourceTransportRequestHandler] Resource request accepted. Using client 'IPAddress=/10.0.0.10, Profile=Samsung TV / player (C/D-series)'
2012-05-02 00:18:16,867 DEBUG [ResourceTransportRequestHandler] Request for resource 1000000000070001 and type 'MEDIA_ITEM' received
2012-05-02 00:18:16,868 DEBUG [MediaResourceRetrievalStrategy] Getting information about media item 1000000000070001 (online)
2012-05-02 00:18:16,868 DEBUG [OnlineRepositoryDAOImpl] Reading an OnlineRepository (id = 7)
2012-05-02 00:18:16,869 DEBUG [VideoDeliveryEngine] Delivering item '1000000000070001' for client 'IPAddress=/10.0.0.10, Profile=Samsung TV / player (C/D-series)'
2012-05-02 00:18:16,869 DEBUG [VideoDeliveryEngine] Delivering file 'rtsp://tv.futubox.com:1935/live/z050001.stream' using transcoding
2012-05-02 00:18:16,869 DEBUG [AbstractTranscodingDeliveryEngine] No suitable transcoding job exists yet, start one for client 'IPAddress=/10.0.0.10, Profile=Samsung TV / player (C/D-series)'
2012-05-02 00:18:16,869 DEBUG [FFMPEGWrapper] Invoking FFmpeg to transcode video file: rtsp://tv.futubox.com:1935/live/z050001.stream?tcp
2012-05-02 00:18:16,869 DEBUG [ProcessExecutor] Starting C:\Program Files\Serviio\bin\\..\lib/ffmpeg.exe -i rtsp://tv.futubox.com:1935/live/z050001.stream?tcp -y -threads 4 -async 1 -vcodec mpeg2video -sameq -r 25 -g 15 -copyts -acodec ac3 -ab 384k -ac 2 -map 0:1 -map 0:0 -sn -f vob pipe:
2012-05-02 00:18:20,870 DEBUG [VideoDeliveryEngine] Found Format profile for transcoded file rtsp://tv.futubox.com:1935/live/z050001.stream: MPEG_PS_PAL
2012-05-02 00:18:20,870 DEBUG [VideoDeliveryEngine] Found Format profile for transcoded file rtsp://tv.futubox.com:1935/live/z050001.stream: MPEG_PS_NTSC
2012-05-02 00:18:20,870 DEBUG [ResourceTransportRequestHandler] Creating stream entity with length: 50000000000
From the ffmpeg log:
>"C:\Program Files\Serviio\bin\\..\lib/ffmpeg.exe" -i rtsp://tv.futubox.com:1935/live/z050001.stream?tcp -y -threads 2 -async 1 -vcodec mpeg2video -sameq -r 25 -g 15 -copyts -acodec ac3
-ab 384k -ac 2 -sn -f mpegts pipe
ffmpeg version N-38622-g1eabd71 Copyright (c) 2000-2012 the FFmpeg developers
  built on Mar  7 2012 00:21:47 with gcc 4.6.2
  configuration: --enable-gpl --enable-version3 --disable-w32threads --enable-runtime-cpudetect --enable-avisynth --enable-bzlib --enable-frei0r --enable-libopencore-amrnb --enable-libopencore-amrwb -
-enable-libfreetype --enable-libgsm --enable-libmp3lame --enable-libopenjpeg --enable-librtmp --enable-libschroedinger --enable-libspeex --enable-libtheora --enable-libvo-aacenc --enable-libvo-amrwben
c --enable-libvorbis --enable-libvpx --enable-libx264 --enable-libxavs --enable-libxvid --enable-zlib
  libavutil      51. 42.100 / 51. 42.100
  libavcodec     54. 10.100 / 54. 10.100
  libavformat    54.  2.100 / 54.  2.100
  libavdevice    53.  4.100 / 53.  4.100
  libavfilter     2. 63.100 /  2. 63.100
  libswresample   0.  7.100 /  0.  7.100
[h264 @ 0000000001D38F00] out of range intra chroma pred mode at 75 1
[h264 @ 0000000001D38F00] error while decoding MB 75 1
[h264 @ 0000000001D38F00] concealing 3494 DC, 3494 AC, 3494 MV errors
[h264 @ 0000000001D38F00] corrupted macroblock 39 3 (total_coeff=-1)
[h264 @ 0000000001D38F00] error while decoding MB 39 3
[h264 @ 0000000001D38F00] concealing 3370 DC, 3370 AC, 3370 MV errors
[h264 @ 0000000001D38F00] mb_type 50 in P slice too large at 43 13
[h264 @ 0000000001D38F00] error while decoding MB 43 13
[h264 @ 0000000001D38F00] concealing 2566 DC, 2566 AC, 2566 MV errors
[h264 @ 0000000001D38F00] concealing 3264 DC, 3264 AC, 3264 MV errors
[h264 @ 0000000001D38F00] negative number of zero coeffs at 63 11
[h264 @ 0000000001D38F00] error while decoding MB 63 11
[h264 @ 0000000001D38F00] concealing 2706 DC, 2706 AC, 2706 MV errors
[h264 @ 0000000001D38F00] cbp too large (4294967295) at 56 37
[h264 @ 0000000001D38F00] error while decoding MB 56 37
[h264 @ 0000000001D38F00] concealing 633 DC, 633 AC, 633 MV errors
[h264 @ 0000000001D38F00] concealing 3126 DC, 3126 AC, 3126 MV errors
[h264 @ 0000000001D38F00] cbp too large (70) at 47 6
[h264 @ 0000000001D38F00] error while decoding MB 47 6
[h264 @ 0000000001D38F00] concealing 3122 DC, 3122 AC, 3122 MV errors
[h264 @ 0000000001D38F00] concealing 3186 DC, 3186 AC, 3186 MV errors
[rtsp @ 0000000001D27FD0] Estimating duration from bitrate, this may be inaccurate
Input #0, rtsp, from 'rtsp://tv.futubox.com:1935/live/z050001.stream?tcp':
  Duration: N/A, start: 0.139002, bitrate: N/A
    Stream #0:1: Video: h264 (Constrained Baseline), yuv420p, 1280x720 [SAR 1:1 DAR 16:9], 25 fps, 25 tbr, 90k tbn, 50 tbc
[buffer @ 0000000001D8CE00] w:1280 h:720 pixfmt:yuv420p tb:1/1000000 sar:1/1 sws_param:
Incompatible sample format 's16' for codec 'ac3', auto-selecting format 'flt'
[ac3 @ 0000000004680690] channel_layout not specified
[ac3 @ 0000000004680690] No channel layout specified. The encoder will guess the layout, but it might be incorrect.
[mpegts @ 0000000001D89130] muxrate VBR, pcr every 2 pkts, sdt every 200, pat/pmt every 40 pkts
Output #0, mpegts, to 'pipe':
    encoder         : Lavf54.2.100
    Stream #0:0: Video: mpeg2video, yuv420p, 1280x720 [SAR 1:1 DAR 16:9], q=2-31, 200 kb/s, 90k tbn, 25 tbc
    Stream #0:1: Audio: ac3, 44100 Hz, stereo, flt, 384 kb/s
Stream mapping:
  Stream #0:1 -> #0:0 (h264 -> mpeg2video)
  Stream #0:0 -> #0:1 (aac -> ac3)
Multiple frames in a packet from stream 0
[h264 @ 0000000004AE85A0] out of range intra chroma pred mode at 75 1
[h264 @ 0000000004AE85A0] error while decoding MB 75 1
[h264 @ 0000000004AE85A0] concealing 3494 DC, 3494 AC, 3494 MV errors
[h264 @ 0000000004AE9340] corrupted macroblock 39 3 (total_coeff=-1)
[h264 @ 0000000004AE9340] error while decoding MB 39 3
[h264 @ 0000000004AE9340] concealing 3370 DC, 3370 AC, 3370 MV errors
[h264 @ 000000000493AA10] mb_type 50 in P slice too large at 43 13
[h264 @ 000000000493AA10] error while decoding MB 43 13
[h264 @ 000000000493AA10] concealing 2566 DC, 2566 AC, 2566 MV errors
[h264 @ 000000000499AA10] Invalid level prefix
[h264 @ 000000000499AA10] error while decoding MB 64 4
[h264 @ 000000000499AA10] concealing 3265 DC, 3265 AC, 3265 MV errors
[h264 @ 00000000049FAA10] out of range intra chroma pred mode at 63 11
[h264 @ 00000000049FAA10] error while decoding MB 63 11
[h264 @ 00000000049FAA10] concealing 2706 DC, 2706 AC, 2706 MV errors
[h264 @ 00000000046E0A40] cbp too large (4294967295) at 56 37
[h264 @ 00000000046E0A40] error while decoding MB 56 37
[h264 @ 00000000046E0A40] concealing 633 DC, 633 AC, 633 MV errors
[h264 @ 00000000047405E0] cbp too large (4294967295) at 42 6
[h264 @ 00000000047A0460] cbp too large (70) at 47 6
[h264 @ 00000000047405E0] error while decoding MB 42 6
[h264 @ 00000000047A0460] error while decoding MB 47 6
[h264 @ 00000000047405E0] concealing 3127 DC, 3127 AC, 3127 MV errors
[h264 @ 00000000047A0460] concealing 3122 DC, 3122 AC, 3122 MV errors
[h264 @ 000000000466BAE0] negative number of zero coeffs at 62 5
[h264 @ 000000000466BAE0] error while decoding MB 62 5
[h264 @ 000000000466BAE0] concealing 3187 DC, 3187 AC, 3187 MV errors
[h264 @ 0000000004AE85A0] out of range intra chroma pred mode at 15 14
[h264 @ 0000000004AE85A0] error while decoding MB 15 14
[h264 @ 0000000004AE85A0] concealing 2514 DC, 2514 AC, 2514 MV errors
[h264 @ 0000000004AE9340] concealing 3328 DC, 3328 AC, 3328 MV errors
aig01
Post Wed May 02, 2012 2:47 am
I too am in a similar dilema, I had all of the feeds from the first post working perfectly 10 days ago and as of a few days ago all I get is the "codec" issue, D5500 as well.
As I am new to the forum I will watch to see what remedies there may be but it is a frustrating issue, great product I have plenty of information to soak up and will try to determine what the issue is.
iplem wrote:I'm facing the same problem since many HD links were changed to futubox. My TV is a D550 too.
Stream mapping:
Samsung D5500 - Server: MB Pro - Lion - 8GB Ram - 2.2 GHz i7
pommybloke
Post Wed May 02, 2012 6:56 am
Add me to the list!!
Same TV and same problem.
ppadypopa
Post Wed May 02, 2012 12:12 pm
me to
Post Wed May 02, 2012 1:40 pm
All the folders were updated on Apr 29/30 to use rtsp because the rtmp links no longer worked. It appears that they work again, but I think the rtsp links should still work on all TV's.
There must be a problem with the profile for your TV. I note that the generic profile does transcode rtsp to mpeg2 in an mpeg container but my Samsung C-D Profile has its own online transcoding section and does not. Perhaps your TV is using the generic profile, or a profile without its own online transcoding section which will cause the generic online transcoding section rules to be used.
iplem
Post Wed May 02, 2012 1:49 pm
I tried with both generic and c/d profiles (restarting the serviio service each time to be sure) without success.
I double checked it was actually using the right profile by looking in the log file as below.
jorge_sz1982
Post Wed May 02, 2012 3:01 pm
I also I have this problem
aig01
Post Wed May 02, 2012 3:04 pm
This is obviously an issue with the feed that changed a few days ago, it cannot be the tv as we are all experiencing the same problem at the same time.
Hopefully we can have the feeds restored to where they were as the change has probably crippled all users with this Samsung TV.
iplem
Post Wed May 02, 2012 3:24 pm
I believe that with the help of serviio experts we might be able to have the right online_transcoding under the samsung c/d profile. We probably are going to have more rtsp with MPEG_PS_NTSC / MPEG_PS_PAL in the future and I would like to have it fixed in the profile rather than avoiding such links.
Post Wed May 02, 2012 4:27 pm
All the folders have had their rtsp links reverted to the original rtmp, so it should fix the problem for everyone.
Just to note, my Samsung D with the C-D profile plays RTSP correctly. For those who want to test or fix their profile for rtsp, the PBS station under TV Neworks is an rtsp link.
aig01
Post Wed May 02, 2012 5:40 pm
:D All is well again, thanks for the assistance, great product
iplem
Post Wed May 02, 2012 6:05 pm
Thanks a lot. :D
Can you also post the c/d profile section so I can compare with mine and try to fix it with PBS?
GingerPrince
Post Wed May 02, 2012 10:21 pm
So I've got a D6530 and I find that both the rtsp and rtmp streams are getting transcoded. it pushes my CPU to it's limits, I'm running on a mid 2010 macbook pro so not ancient.
should it be transcoding these types of streams? ffmpeg is detecting them as
Input #0, flv, from 'rtmp://s7.webport.tv/live/z050226.stream':
  Duration: N/A, start: 0.000000, bitrate: N/A
    Stream #0:0: Video: h264 (Constrained Baseline), yuv420p, 1280x720 [SAR 1:1 DAR 16:9], 25 tbr, 1k tbn, 50 tbc
    Stream #0:1: Audio: aac, 44100 Hz, stereo, s16
I thought my TV would play h264 straight off?
also, I find that the sky sports HD in the Sports HD RSS folder is almost unplayable but this one is nearly fine - rtsp://tv.futubox.com:1935/live/z050226.stream
My speed tests show I'm capable of streaming 15mbps. I've tried having my laptop connected to my router via a wired gigabit connection and the tv connected to one of the 100mb connections, again, wired. I still get glitches in the video even at it's very best on the rtsp://tv.futubox.com:1935/live/z050226.stream stream but as I say, the stream in the folder is unwatchable. any ideas why? any pointers? I've switched on detailed debugging in serviio and I can't see anything in there that would suggest a problem.
cheers for all the efforts you've made to put this together, feel like I'm almost there!
Matt
Post Wed May 02, 2012 10:25 pm
Iplem:
Just realized that I have a 550 as well (Samsung PN64D550) and my rtsp folders played without problems..Most confusing since I believe my profile is the stock version.
My profile for 0.6.2 is attached, so you can compare with yours and I have setup a LiveFeeds_HD_ChannelsRTSP.rss containing the rtsp links that do not work for you so you can test it.
It would be nice to find out why yours do not work and fix it. Let me know if I can help.
PS: I have also updated this profile as shown in the post below to better address flv files. Both play the rtsp.
profiles.xml.zip
(6.86 KiB) Downloaded 650 times
Post Wed May 02, 2012 10:50 pm
Ginger Prince:
This is not really the thread with info for you, but I'll point out as in other threads, all online streams must be remuxed to mpeg-ts, and there is another thread where I suggested a profile change so H264.flv will not get transcoded to mpeg2video. If your cpu is one core it won't hack it, 2 cores marginally depending on the video. The rtsp you quote is the same stream that has been in the folder since Apr 29 but the folder was reverted to rtmp today. I don't know what folder version you were using but you can run ffmpeg on the rtmp stream and you will see it is identical to the rtsp stream
GingerPrince
Post Wed May 02, 2012 11:15 pm
jhb50:
Thanks for that. when you mention 'add vCodec="vp6" parameters to the following flv transcoding', which do you mean? something like :
<Matches container="mp4" aCodec="lpcm" />
<!-- Matches container="flv" vCodec="h264" looks like some (D?) devices play FLV@H264 natively so this could be removed -->
then where do I add the vCodec bit?
are you saying the transcoding needs a min of 2CPUs? it's a dual core i5.
the rtsp url is
and the rtmp url is
rtmp://s7.webport.tv/live/z050226.stream pageUrl=http://www.tvsector.com/ swfVfy=0 live=1
as I say, the rtsp url is pretty smooth but the rtmp was less so earlier on. both seem a bit smoother since I've commented out that line but my laptop is still screaming and ffmpeg is taking around 250% cpu.
Post Wed May 02, 2012 11:47 pm
Best answer is to show you my latest samsung c-d profile now.
1) local h264.flv is played natively because the rule for it was removed
2) local and online vp6,flv and h263.flv are transcoded to mpeg2video per the rules I moded/added
3) online h264.flv is remuxed to mpeg-ts per the rule I added.
   <Profile id="7" name="Samsung TV / player (C/D-series)" extendsProfileId="1">
      <ContentDirectoryMessageBuilder>org.serviio.upnp.service.contentdirectory.SamsungDLNAMessageBuilder</ContentDirectoryMessageBuilder>
        <ResourceTransportProtocolHandler>org.serviio.upnp.protocol.http.transport.SamsungWiseLinkProtocolHandler</ResourceTransportProtocolHandler>
        <Detection>
         <UPnPSearch>
            <FriendlyName>(^TV-\d{2}C\d{3}.*)|(^\[TV\][A-Z]{2}\d{2}D\d{3}.*)</FriendlyName>
            <ModelNumber>(1\.0)|(AllShare1\.0)</ModelNumber>
         </UPnPSearch>
         <HttpHeaders>
            <!-- for BD players -->
            <User-Agent>(.*SEC_HHP_BD-[CD].*)|(.*SEC_HHP_\[(HT|BD)\][CD].*)</User-Agent>
         </HttpHeaders>
      </Detection>
   <!--<DeviceDescription>   Removed by JHB to stop serviio tv screen popup
           <ExtraElements>
              &lt;sec:ProductCap&gt;smi,DCM10,getMediaInfo.sec,getCaptionInfo.sec&lt;/sec:ProductCap&gt;
            &lt;sec:X_ProductCap&gt;smi,DCM10,getMediaInfo.sec,getCaptionInfo.sec&lt;/sec:X_ProductCap&gt;
           </ExtraElements>
       </DeviceDescription>   -->
        <MediaFormatProfiles>
            <MediaFormatProfile mime-type="video/x-mkv">MATROSKA</MediaFormatProfile>
            <MediaFormatProfile mime-type="video/x-msvideo" name="">AVI</MediaFormatProfile>
        </MediaFormatProfiles>
      <ContentDirectoryDefinitionFilter>org.serviio.upnp.service.contentdirectory.definition.SamsungContentDirectoryDefinitionFilter</ContentDirectoryDefinitionFilter>
         <!-- Transcode all h264 video with HIGH/MAIN > Level 4.1 on MPEG-TS stream with MPEG2VIDEO and ac3 audio transcoding -->
         <Video targetContainer="mpegts" targetVCodec="mpeg2video" targetACodec="ac3" aBitrate="192" maxVBitrate="20000">
            <Matches container="avi" vCodec="h264" profile="high" levelGreaterThan="4.2" />
            <Matches container="avi" vCodec="h264" profile="main" levelGreaterThan="4.2" />
            <Matches container="matroska" vCodec="h264" profile="high" levelGreaterThan="4.2" />
            <Matches container="matroska" vCodec="h264" profile="main" levelGreaterThan="4.2" />
            <Matches container="mpegts" vCodec="h264" profile="high" levelGreaterThan="4.2" />
               <Matches container="mpegts" vCodec="h264" profile="main" levelGreaterThan="4.2" />
         <!-- transcode H264 MP4 files with LPCM audio -->
            <Matches container="mpegts" aCodec="mp2" />
         <!--   <Matches container="flv" vCodec="h264" />  looks like some (D?) devices play FLV@H264 natively so this could be removed -->
            <Matches container="matroska" vCodec="vc1" />
            <Matches container="ogg" vCodec="mpeg4" />
            <Matches container="3gp" aCodec="amrnb" />
         <!-- transcode MKV with MPEG2 video, remux into mpeg2ts -->
         <!-- transcode AVI with AVC video -->
         <Video targetContainer="mpegts" targetACodec="ac3" targetVCodec="mpeg2video" maxVBitrate="20000">
            <Matches container="flv" vCodec="vp6" />
            <Matches container="flv" vCodec="h263" />
            <Matches container="ogg" />
         <!-- For dvr-ms files force mpeg2video transcoding to fix monotone timestamps problems-->
         <Video targetContainer="mpegts" targetACodec="ac3" forceVTranscoding="true" maxVBitrate="20000">
            <Matches container="asf" vCodec="mpeg2video" />
            <Matches container="wtv" />
         <!-- transcode audio only for wmv with wmapro -->
         <Video targetContainer="asf" targetACodec="ac3" aBitrate="256">
            <Matches container="asf" aCodec="wmapro" />
            <Matches container="mp4" />
            <Matches container="flac" />
            <Matches container="adts" />
         </Audio>
      <OnlineTranscoding>
            <Matches container="flv" vCodec="h264" /> <!-- added by jhb50 to remux online flv -->
                <Matches container="applehttp" vCodec="h264"/>
         <Video targetContainer="mpegts" targetVCodec="mpeg2video" targetACodec="ac3" aBitrate="384" maxVBitrate="20000">
            <Matches container="asf" /> <!-- mms -->
      </OnlineTranscoding>
        <SubtitlesMimeType>smi/caption</SubtitlesMimeType>
I5 processors have 4 cpus(cores) so you have plenty of power but be sure to turn them on in the serviio console under transcoding.
GingerPrince
Post Thu May 03, 2012 12:13 pm
Thanks, i'll give it a go next week when I get home.
should have said - it's a macbook pro with an i5-m so it's only dual core with hyperthreading. i noticed that serviio transcodes the online streams whether I've enabled transcoding or not.
Also, it runs super hot and noisy as all cores are running at about 80%.
iplem
Post Thu May 03, 2012 8:43 pm
I copied the profile and restarted the serviio service but still no luck. Maybe not all D550 are the same after all. Mine is LA37D550.
Maybe the following debug section can help.
Can you also tell me which ffmpeg version do you use?
Thanks!
2012-05-03 23:29:23,704 DEBUG [ResourceTransportRequestHandler] Resource request accepted. Using client 'IPAddress=/10.0.0.11, Profile=Samsung TV / player (C/D-series)'
2012-05-03 23:29:23,704 DEBUG [ResourceTransportRequestHandler] Request for resource 1000000000070005 and type 'MEDIA_ITEM' received
2012-05-03 23:29:23,704 DEBUG [MediaResourceRetrievalStrategy] Getting information about media item 1000000000070005 (online)
2012-05-03 23:29:23,704 DEBUG [OnlineRepositoryDAOImpl] Reading an OnlineRepository (id = 7)
2012-05-03 23:29:23,705 DEBUG [OnlineRepositoryDAOImpl] Reading an OnlineRepository (id = 7)
2012-05-03 23:29:23,706 DEBUG [VideoDeliveryEngine] Delivering item '1000000000070005' for client 'IPAddress=/10.0.0.11, Profile=Samsung TV / player (C/D-series)'
2012-05-03 23:29:23,706 DEBUG [VideoDeliveryEngine] Delivering file 'rtsp://tv.futubox.com:1935/live/z020101.stream' using transcoding
2012-05-03 23:29:23,706 DEBUG [AbstractTranscodingDeliveryEngine] Stopping previous transcoding job of file 'transcoding-temp-1000000000070003-MPEG2PS.stf'
2012-05-03 23:29:23,706 DEBUG [ProcessExecutor] Stopping external process: Thread[Thread-167,5,ServioThreads]
2012-05-03 23:29:23,706 DEBUG [ProcessUtils] Killing the Windows process: 9608
2012-05-03 23:29:23,715 DEBUG [TranscodingJobListener] Transcoding finished; successful: true
2012-05-03 23:29:23,717 DEBUG [AbstractTranscodingDeliveryEngine] No suitable transcoding job exists yet, start one for client 'IPAddress=/10.0.0.11, Profile=Samsung TV / player (C/D-series)'
2012-05-03 23:29:23,718 DEBUG [FFMPEGWrapper] Invoking FFmpeg to transcode video file: rtsp://tv.futubox.com:1935/live/z020101.stream?tcp
2012-05-03 23:29:23,718 DEBUG [ProcessExecutor] Starting C:\Program Files\Serviio\bin\\..\lib/ffmpeg.exe -i rtsp://tv.futubox.com:1935/live/z020101.stream?tcp -y -threads 4 -async 1 -vcodec mpeg2video -sameq -r 25 -g 15 -copyts -acodec ac3 -ab 384k -ac 2 -map 0:1 -map 0:0 -sn -f vob pipe:
2012-05-03 23:29:24,841 WARN  [ProcessExecutor] Process cmd has a return code of 1! This is a possible error.
2012-05-03 23:29:24,841 DEBUG [TranscodingJobListener] Transcoding finished; successful: false
2012-05-03 23:29:30,745 DEBUG [NonClosingPipedInputStream] Closing piped input stream and closing related feeder process
2012-05-03 23:29:40,645 DEBUG [NonClosingPipedInputStream] Closing piped input stream and closing related feeder process
2012-05-03 23:29:50,219 DEBUG [StreamBasedTranscodingDeliveryStrategy] Transcoded stream is empty, connection may have been lost
Users browsing this forum: Google [Bot] and 6 guests
