Samsung D550 Dont Playing Video Stream
Post Thu May 03, 2012 11:16 pm
Re: Samsung D550 Dont Playing Video Stream
Thats because DISNEY CHANNEL is dark right now. I get the same messages
2012-05-03 19:06:39,013 DEBUG [VideoDeliveryEngine] Delivering file 'rtsp://tv.futubox.com:1935/live/z020101.stream' using transcoding
2012-05-03 19:06:39,014 DEBUG [AbstractTranscodingDeliveryEngine] No suitable transcoding job exists yet, start one for client 'IPAddress=/127.0.0.1, Profile=Flash player'
2012-05-03 19:06:39,014 DEBUG [FFMPEGWrapper] Invoking FFmpeg to transcode video file: rtsp://tv.futubox.com:1935/live/z020101.stream?tcp
2012-05-03 19:06:39,015 DEBUG [ProcessExecutor] Starting "C:\Program Files\Serviio\lib\ffmpeg.bat" -i rtsp://tv.futubox.com:1935/live/z020101.stream?tcp -y -async 1 -vcodec flv -b 1000k -maxrate 1000k -bufsize 1000k -vf scale=853:480 -r 25 -g 15 -copyts -acodec libmp3lame -ab 192k -ar 44100 -ac 2 -map 0:1 -map 0:0 -sn -f flv pipe:
2012-05-03 19:06:39,887 WARN  [ProcessExecutor] Process cmd has a return code of 1! This is a possible error.
2012-05-03 19:06:39,887 DEBUG [TranscodingJobListener] Transcoding finished; successful: false
You need to test a channel that is transmitting..heres my Animal Planet
012-05-03 19:13:32,827 DEBUG [ResourceDeliveryProcessor] Resource request accepted. Using client 'IPAddress=/192.168.1.64, Profile=Samsung TV / player (C/D-series)'
2012-05-03 19:13:32,827 DEBUG [ResourceDeliveryProcessor] Request for resource 1000000000270001 and type 'MEDIA_ITEM' received
2012-05-03 19:13:32,827 DEBUG [MediaResourceRetrievalStrategy] Getting information about media item 1000000000270001 (online)
2012-05-03 19:13:32,827 DEBUG [OnlineRepositoryDAOImpl] Reading an OnlineRepository (id = 27)
2012-05-03 19:13:32,828 DEBUG [OnlineRepositoryDAOImpl] Reading an OnlineRepository (id = 27)
2012-05-03 19:13:32,829 DEBUG [VideoDeliveryEngine] Delivering item '1000000000270001' for client 'IPAddress=/192.168.1.64, Profile=Samsung TV / player (C/D-series)'
2012-05-03 19:13:32,829 DEBUG [VideoDeliveryEngine] Delivering file 'rtsp://tv.futubox.com:1935/live/z050001.stream' using transcoding
2012-05-03 19:13:32,829 DEBUG [AbstractTranscodingDeliveryEngine] No suitable transcoding job exists yet, start one for client 'IPAddress=/192.168.1.64, Profile=Samsung TV / player (C/D-series)'
2012-05-03 19:13:32,829 DEBUG [FFMPEGWrapper] Invoking FFmpeg to transcode video file: rtsp://tv.futubox.com:1935/live/z050001.stream?tcp
2012-05-03 19:13:32,829 DEBUG [ProcessExecutor] Starting "C:\Program Files\Serviio\lib\ffmpeg.bat" -i rtsp://tv.futubox.com:1935/live/z050001.stream?tcp -y -threads 4 -async 1 -vcodec mpeg2video -sameq -r 25 -g 15 -copyts -acodec ac3 -ab 384k -ac 2 -map 0:1 -map 0:0 -sn -f vob pipe:
2012-05-03 19:13:36,830 DEBUG [VideoDeliveryEngine] Found Format profile for transcoded file rtsp://tv.futubox.com:1935/live/z050001.stream: MPEG_PS_PAL
2012-05-03 19:13:36,830 DEBUG [VideoDeliveryEngine] Found Format profile for transcoded file rtsp://tv.futubox.com:1935/live/z050001.stream: MPEG_PS_NTSC
2012-05-03 19:13:36,830 DEBUG [ResourceDeliveryProcessor] Stream entity has length: 50000000000
2012-05-03 19:13:36,830 DEBUG [ResourceDeliveryProcessor] Sending file back
iplem
Post Fri May 04, 2012 6:12 am
I was sure I tested with Animal Planet.
Anyway, I tested it again and I have the same problem. I also checked with VLC which was able to show (not smooth though)
2012-05-04 09:05:32,895 DEBUG [WebServer] Incoming connection from /10.0.0.11:36109
2012-05-04 09:05:32,895 DEBUG [ResourceTransportRequestHandler] HEAD /resource/1000000000910001/MEDIA_ITEM/MPEG_PS_NTSC*0 HTTP/1.0, headers = [getcontentFeatures.dlna.org: 1,Host: 10.0.0.4:8895]]
2012-05-04 09:05:32,896 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 10.0.0.11
2012-05-04 09:05:32,897 DEBUG [ResourceTransportRequestHandler] Resource request accepted. Using client 'IPAddress=/10.0.0.11, Profile=Samsung TV / player (C/D-series)'
2012-05-04 09:05:32,898 DEBUG [ResourceTransportRequestHandler] Request for resource 1000000000910001 and type 'MEDIA_ITEM' received
2012-05-04 09:05:32,898 DEBUG [MediaResourceRetrievalStrategy] Getting information about media item 1000000000910001 (online)
2012-05-04 09:05:32,898 DEBUG [OnlineRepositoryDAOImpl] Reading an OnlineRepository (id = 91)
2012-05-04 09:05:32,899 DEBUG [VideoDeliveryEngine] Retrieving resource information for item 1000000000910001, format MPEG_PS_NTSC and profile Samsung TV / player (C/D-series)
2012-05-04 09:05:32,899 DEBUG [AbstractTranscodingDeliveryEngine] Getting media info for transcoded version of file rtsp://tv.futubox.com:1935/live/z050001.stream
2012-05-04 09:05:32,899 DEBUG [VideoDeliveryEngine] Found Format profile for transcoded file rtsp://tv.futubox.com:1935/live/z050001.stream: MPEG_PS_PAL
2012-05-04 09:05:32,899 DEBUG [VideoDeliveryEngine] Found Format profile for transcoded file rtsp://tv.futubox.com:1935/live/z050001.stream: MPEG_PS_NTSC
2012-05-04 09:05:32,900 DEBUG [ResourceTransportRequestHandler] Sending HEAD response back
2012-05-04 09:05:32,900 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 200 OK, headers = [[Content-Type: video/mpeg,Content-Length: 50000000000,Date: Fri, 04 May 2012 06:05:32 GMT,Server: Windows 7, UPnP/1.0 DLNADOC/1.50, Serviio/0.6.2,Cache-control: no-cache,contentFeatures.dlna.org: DLNA.ORG_PN=MPEG_PS_NTSC;DLNA.ORG_OP=00;DLNA.ORG_CI=1;DLNA.ORG_FLAGS=8D500000000000000000000000000000,transferMode.dlna.org: Streaming]]
2012-05-04 09:05:32,910 DEBUG [WebServer] Incoming connection from /10.0.0.11:34390
2012-05-04 09:05:32,911 DEBUG [ResourceTransportRequestHandler] GET /resource/1000000000910001/MEDIA_ITEM/MPEG_PS_NTSC*0 HTTP/1.0, headers = [getcontentFeatures.dlna.org: 1,transferMode.dlna.org: Streaming,getMediaInfo.sec: 1,Host: 10.0.0.4:8895]]
2012-05-04 09:05:32,911 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 10.0.0.11
2012-05-04 09:05:32,912 DEBUG [ResourceTransportRequestHandler] Resource request accepted. Using client 'IPAddress=/10.0.0.11, Profile=Samsung TV / player (C/D-series)'
2012-05-04 09:05:32,913 DEBUG [ResourceTransportRequestHandler] Request for resource 1000000000910001 and type 'MEDIA_ITEM' received
2012-05-04 09:05:32,913 DEBUG [MediaResourceRetrievalStrategy] Getting information about media item 1000000000910001 (online)
2012-05-04 09:05:32,913 DEBUG [OnlineRepositoryDAOImpl] Reading an OnlineRepository (id = 91)
2012-05-04 09:05:32,914 DEBUG [VideoDeliveryEngine] Delivering item '1000000000910001' for client 'IPAddress=/10.0.0.11, Profile=Samsung TV / player (C/D-series)'
2012-05-04 09:05:32,914 DEBUG [VideoDeliveryEngine] Delivering file 'rtsp://tv.futubox.com:1935/live/z050001.stream' using transcoding
2012-05-04 09:05:32,914 DEBUG [AbstractTranscodingDeliveryEngine] No suitable transcoding job exists yet, start one for client 'IPAddress=/10.0.0.11, Profile=Samsung TV / player (C/D-series)'
2012-05-04 09:05:32,915 DEBUG [FFMPEGWrapper] Invoking FFmpeg to transcode video file: rtsp://tv.futubox.com:1935/live/z050001.stream?tcp
2012-05-04 09:05:32,916 DEBUG [ProcessExecutor] Starting C:\Program Files\Serviio\bin\\..\lib/ffmpeg.exe -i rtsp://tv.futubox.com:1935/live/z050001.stream?tcp -y -threads 2 -async 1 -vcodec mpeg2video -sameq -r 25 -g 15 -copyts -acodec ac3 -ab 384k -ac 2 -map 0:1 -map 0:0 -sn -f vob pipe:
2012-05-04 09:05:37,417 DEBUG [VideoDeliveryEngine] Found Format profile for transcoded file rtsp://tv.futubox.com:1935/live/z050001.stream: MPEG_PS_PAL
2012-05-04 09:05:37,417 DEBUG [VideoDeliveryEngine] Found Format profile for transcoded file rtsp://tv.futubox.com:1935/live/z050001.stream: MPEG_PS_NTSC
2012-05-04 09:05:37,418 DEBUG [ResourceTransportRequestHandler] Creating stream entity with length: 50000000000
2012-05-04 09:05:37,418 DEBUG [ResourceTransportRequestHandler] Sending file back
2012-05-04 09:05:37,418 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 200 OK, headers = [[Content-Type: video/mpeg,Content-Length: 50000000000,Date: Fri, 04 May 2012 06:05:37 GMT,Server: Windows 7, UPnP/1.0 DLNADOC/1.50, Serviio/0.6.2,Cache-control: no-cache,contentFeatures.dlna.org: DLNA.ORG_PN=MPEG_PS_NTSC;DLNA.ORG_OP=00;DLNA.ORG_CI=1;DLNA.ORG_FLAGS=8D500000000000000000000000000000,transferMode.dlna.org: Streaming,MediaInfo.sec: SEC_Duration=18000000;]]
2012-05-04 09:05:42,243 DEBUG [WebServer] Incoming connection from /10.0.0.11:42064
2012-05-04 09:05:42,310 DEBUG [ResourceTransportRequestHandler] HEAD /resource/1000000000910001/MEDIA_ITEM/MPEG_PS_NTSC*0 HTTP/1.0, headers = [getCaptionInfo.sec: 1]]
2012-05-04 09:05:42,310 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 10.0.0.11
2012-05-04 09:05:42,311 DEBUG [ResourceTransportRequestHandler] Resource request accepted. Using client 'IPAddress=/10.0.0.11, Profile=Samsung TV / player (C/D-series)'
2012-05-04 09:05:42,312 DEBUG [ResourceTransportRequestHandler] Request for resource 1000000000910001 and type 'MEDIA_ITEM' received
2012-05-04 09:05:42,312 DEBUG [MediaResourceRetrievalStrategy] Getting information about media item 1000000000910001 (online)
2012-05-04 09:05:42,313 DEBUG [OnlineRepositoryDAOImpl] Reading an OnlineRepository (id = 91)
2012-05-04 09:05:42,314 DEBUG [VideoDeliveryEngine] Retrieving resource information for item 1000000000910001, format MPEG_PS_NTSC and profile Samsung TV / player (C/D-series)
2012-05-04 09:05:42,314 DEBUG [AbstractTranscodingDeliveryEngine] Getting media info for transcoded version of file rtsp://tv.futubox.com:1935/live/z050001.stream
2012-05-04 09:05:42,314 DEBUG [VideoDeliveryEngine] Found Format profile for transcoded file rtsp://tv.futubox.com:1935/live/z050001.stream: MPEG_PS_PAL
2012-05-04 09:05:42,314 DEBUG [VideoDeliveryEngine] Found Format profile for transcoded file rtsp://tv.futubox.com:1935/live/z050001.stream: MPEG_PS_NTSC
2012-05-04 09:05:42,314 DEBUG [ResourceTransportRequestHandler] Sending HEAD response back
2012-05-04 09:05:42,314 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 200 OK, headers = [[Content-Type: video/mpeg,Content-Length: 50000000000,Date: Fri, 04 May 2012 06:05:42 GMT,Server: Windows 7, UPnP/1.0 DLNADOC/1.50, Serviio/0.6.2,Cache-control: no-cache,transferMode.dlna.org: Streaming]]
2012-05-04 09:05:42,526 DEBUG [WebServer] Incoming connection from /10.0.0.11:42968
2012-05-04 09:05:42,526 DEBUG [ResourceTransportRequestHandler] HEAD /resource/1000000000910001/MEDIA_ITEM/MPEG_PS_NTSC*0 HTTP/1.0, headers = [getCaptionInfo.sec: 1]]
2012-05-04 09:05:42,526 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 10.0.0.11
2012-05-04 09:05:42,527 DEBUG [ResourceTransportRequestHandler] Resource request accepted. Using client 'IPAddress=/10.0.0.11, Profile=Samsung TV / player (C/D-series)'
2012-05-04 09:05:42,528 DEBUG [ResourceTransportRequestHandler] Request for resource 1000000000910001 and type 'MEDIA_ITEM' received
2012-05-04 09:05:42,528 DEBUG [MediaResourceRetrievalStrategy] Getting information about media item 1000000000910001 (online)
2012-05-04 09:05:42,528 DEBUG [OnlineRepositoryDAOImpl] Reading an OnlineRepository (id = 91)
2012-05-04 09:05:42,529 DEBUG [VideoDeliveryEngine] Retrieving resource information for item 1000000000910001, format MPEG_PS_NTSC and profile Samsung TV / player (C/D-series)
2012-05-04 09:05:42,529 DEBUG [AbstractTranscodingDeliveryEngine] Getting media info for transcoded version of file rtsp://tv.futubox.com:1935/live/z050001.stream
2012-05-04 09:05:42,530 DEBUG [VideoDeliveryEngine] Found Format profile for transcoded file rtsp://tv.futubox.com:1935/live/z050001.stream: MPEG_PS_PAL
2012-05-04 09:05:42,530 DEBUG [VideoDeliveryEngine] Found Format profile for transcoded file rtsp://tv.futubox.com:1935/live/z050001.stream: MPEG_PS_NTSC
2012-05-04 09:05:42,530 DEBUG [ResourceTransportRequestHandler] Sending HEAD response back
2012-05-04 09:05:42,530 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 200 OK, headers = [[Content-Type: video/mpeg,Content-Length: 50000000000,Date: Fri, 04 May 2012 06:05:42 GMT,Server: Windows 7, UPnP/1.0 DLNADOC/1.50, Serviio/0.6.2,Cache-control: no-cache,transferMode.dlna.org: Streaming]]
2012-05-04 09:05:43,016 DEBUG [WebServer] I/O error: Software caused connection abort: socket write error
2012-05-04 09:05:45,601 DEBUG [WebServer] Incoming connection from /10.0.0.11:43760
2012-05-04 09:05:45,601 DEBUG [ResourceTransportRequestHandler] HEAD /resource/1000000000910001/MEDIA_ITEM/MPEG_PS_NTSC*0 HTTP/1.0, headers = [getCaptionInfo.sec: 1]]
2012-05-04 09:05:45,601 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 10.0.0.11
2012-05-04 09:05:45,602 DEBUG [ResourceTransportRequestHandler] Resource request accepted. Using client 'IPAddress=/10.0.0.11, Profile=Samsung TV / player (C/D-series)'
2012-05-04 09:05:45,602 DEBUG [ResourceTransportRequestHandler] Request for resource 1000000000910001 and type 'MEDIA_ITEM' received
2012-05-04 09:05:45,602 DEBUG [MediaResourceRetrievalStrategy] Getting information about media item 1000000000910001 (online)
2012-05-04 09:05:45,602 DEBUG [OnlineRepositoryDAOImpl] Reading an OnlineRepository (id = 91)
2012-05-04 09:05:45,603 DEBUG [VideoDeliveryEngine] Retrieving resource information for item 1000000000910001, format MPEG_PS_NTSC and profile Samsung TV / player (C/D-series)
2012-05-04 09:05:45,603 DEBUG [AbstractTranscodingDeliveryEngine] Getting media info for transcoded version of file rtsp://tv.futubox.com:1935/live/z050001.stream
2012-05-04 09:05:45,603 DEBUG [VideoDeliveryEngine] Found Format profile for transcoded file rtsp://tv.futubox.com:1935/live/z050001.stream: MPEG_PS_PAL
2012-05-04 09:05:45,603 DEBUG [VideoDeliveryEngine] Found Format profile for transcoded file rtsp://tv.futubox.com:1935/live/z050001.stream: MPEG_PS_NTSC
2012-05-04 09:05:45,603 DEBUG [ResourceTransportRequestHandler] Sending HEAD response back
2012-05-04 09:05:45,603 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 200 OK, headers = [[Content-Type: video/mpeg,Content-Length: 50000000000,Date: Fri, 04 May 2012 06:05:45 GMT,Server: Windows 7, UPnP/1.0 DLNADOC/1.50, Serviio/0.6.2,Cache-control: no-cache,transferMode.dlna.org: Streaming]]
2012-05-04 09:05:45,610 DEBUG [WebServer] Incoming connection from /10.0.0.11:40054
2012-05-04 09:05:45,610 DEBUG [ResourceTransportRequestHandler] HEAD /resource/1000000000910001/MEDIA_ITEM/MPEG_PS_NTSC*0 HTTP/1.0, headers = [getCaptionInfo.sec: 1]]
2012-05-04 09:05:45,610 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 10.0.0.11
2012-05-04 09:05:45,611 DEBUG [ResourceTransportRequestHandler] Resource request accepted. Using client 'IPAddress=/10.0.0.11, Profile=Samsung TV / player (C/D-series)'
2012-05-04 09:05:45,611 DEBUG [ResourceTransportRequestHandler] Request for resource 1000000000910001 and type 'MEDIA_ITEM' received
2012-05-04 09:05:45,611 DEBUG [MediaResourceRetrievalStrategy] Getting information about media item 1000000000910001 (online)
2012-05-04 09:05:45,611 DEBUG [OnlineRepositoryDAOImpl] Reading an OnlineRepository (id = 91)
2012-05-04 09:05:45,612 DEBUG [VideoDeliveryEngine] Retrieving resource information for item 1000000000910001, format MPEG_PS_NTSC and profile Samsung TV / player (C/D-series)
2012-05-04 09:05:45,612 DEBUG [AbstractTranscodingDeliveryEngine] Getting media info for transcoded version of file rtsp://tv.futubox.com:1935/live/z050001.stream
2012-05-04 09:05:45,612 DEBUG [VideoDeliveryEngine] Found Format profile for transcoded file rtsp://tv.futubox.com:1935/live/z050001.stream: MPEG_PS_PAL
2012-05-04 09:05:45,612 DEBUG [VideoDeliveryEngine] Found Format profile for transcoded file rtsp://tv.futubox.com:1935/live/z050001.stream: MPEG_PS_NTSC
2012-05-04 09:05:45,612 DEBUG [ResourceTransportRequestHandler] Sending HEAD response back
2012-05-04 09:05:45,612 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 200 OK, headers = [[Content-Type: video/mpeg,Content-Length: 50000000000,Date: Fri, 04 May 2012 06:05:45 GMT,Server: Windows 7, UPnP/1.0 DLNADOC/1.50, Serviio/0.6.2,Cache-control: no-cache,transferMode.dlna.org: Streaming]]
2012-05-04 09:05:45,620 DEBUG [WebServer] Incoming connection from /10.0.0.11:40203
2012-05-04 09:05:45,620 DEBUG [ResourceTransportRequestHandler] HEAD /resource/1000000000910001/MEDIA_ITEM/MPEG_PS_NTSC*0 HTTP/1.0, headers = [getCaptionInfo.sec: 1]]
2012-05-04 09:05:45,620 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 10.0.0.11
2012-05-04 09:05:45,621 DEBUG [ResourceTransportRequestHandler] Resource request accepted. Using client 'IPAddress=/10.0.0.11, Profile=Samsung TV / player (C/D-series)'
2012-05-04 09:05:45,621 DEBUG [ResourceTransportRequestHandler] Request for resource 1000000000910001 and type 'MEDIA_ITEM' received
2012-05-04 09:05:45,621 DEBUG [MediaResourceRetrievalStrategy] Getting information about media item 1000000000910001 (online)
2012-05-04 09:05:45,621 DEBUG [OnlineRepositoryDAOImpl] Reading an OnlineRepository (id = 91)
2012-05-04 09:05:45,622 DEBUG [VideoDeliveryEngine] Retrieving resource information for item 1000000000910001, format MPEG_PS_NTSC and profile Samsung TV / player (C/D-series)
2012-05-04 09:05:45,622 DEBUG [AbstractTranscodingDeliveryEngine] Getting media info for transcoded version of file rtsp://tv.futubox.com:1935/live/z050001.stream
2012-05-04 09:05:45,622 DEBUG [VideoDeliveryEngine] Found Format profile for transcoded file rtsp://tv.futubox.com:1935/live/z050001.stream: MPEG_PS_PAL
2012-05-04 09:05:45,622 DEBUG [VideoDeliveryEngine] Found Format profile for transcoded file rtsp://tv.futubox.com:1935/live/z050001.stream: MPEG_PS_NTSC
2012-05-04 09:05:45,622 DEBUG [ResourceTransportRequestHandler] Sending HEAD response back
2012-05-04 09:05:45,622 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 200 OK, headers = [[Content-Type: video/mpeg,Content-Length: 50000000000,Date: Fri, 04 May 2012 06:05:45 GMT,Server: Windows 7, UPnP/1.0 DLNADOC/1.50, Serviio/0.6.2,Cache-control: no-cache,transferMode.dlna.org: Streaming]]
2012-05-04 09:05:47,308 DEBUG [WebServer] Incoming connection from /10.0.0.11:50948
2012-05-04 09:05:47,309 DEBUG [ServiceControlRequestHandler] ServiceControl request received for action '"urn:schemas-upnp-org:service:ContentDirectory:1#X_GetFeatureList"' from 10.0.0.11:
2012-05-04 09:05:47,309 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 10.0.0.11
2012-05-04 09:05:47,316 DEBUG [ServiceControlRequestHandler] Returning OK SOAP message
2012-05-04 09:05:47,327 DEBUG [WebServer] Incoming connection from /10.0.0.11:57378
2012-05-04 09:05:47,327 DEBUG [ServiceControlRequestHandler] ServiceControl request received for action '"urn:schemas-upnp-org:service:ContentDirectory:1#Browse"' from 10.0.0.11:
2012-05-04 09:05:47,327 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 10.0.0.11
2012-05-04 09:05:47,332 DEBUG [ContentDirectory] Browse() called for renderer LA37D550 (profile 7) with parameters: objectID = V_OF, browseFlag = BrowseDirectChildren, filter = *, startIndex = 0, count = 1, sortCriteria =
2012-05-04 09:05:47,332 DEBUG [OnlineRepositoryDAOImpl] Retrieving list of [FEED, WEB_RESOURCE] OnlineRepositories for VIDEO
2012-05-04 09:05:47,334 DEBUG [OnlineRepositoryDAOImpl] Retrieving list of [LIVE_STREAM] OnlineRepositories for VIDEO
2012-05-04 09:05:47,337 DEBUG [VideoDeliveryEngine] Retrieving resource information for item 1000000000910001 and profile Samsung TV / player (C/D-series)
2012-05-04 09:05:47,337 DEBUG [VideoDeliveryEngine] Found Format profile for transcoded file rtsp://tv.futubox.com:1935/live/z050001.stream: MPEG_PS_PAL
2012-05-04 09:05:47,337 DEBUG [VideoDeliveryEngine] Found Format profile for transcoded file rtsp://tv.futubox.com:1935/live/z050001.stream: MPEG_PS_NTSC
2012-05-04 09:05:47,337 DEBUG [OnlineRepositoryDAOImpl] Retrieving list of [FEED, WEB_RESOURCE] OnlineRepositories for VIDEO
2012-05-04 09:05:47,339 DEBUG [OnlineRepositoryDAOImpl] Retrieving list of [LIVE_STREAM] OnlineRepositories for VIDEO
2012-05-04 09:05:47,348 DEBUG [ServiceControlRequestHandler] Returning OK SOAP message
2012-05-04 09:05:47,358 DEBUG [WebServer] Incoming connection from /10.0.0.11:57707
2012-05-04 09:05:47,358 DEBUG [ServiceControlRequestHandler] ServiceControl request received for action '"urn:schemas-upnp-org:service:ContentDirectory:1#Browse"' from 10.0.0.11:
2012-05-04 09:05:47,358 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 10.0.0.11
2012-05-04 09:05:47,362 DEBUG [ContentDirectory] Browse() called for renderer LA37D550 (profile 7) with parameters: objectID = V_OF, browseFlag = BrowseDirectChildren, filter = @id,@parentID,@restricted,dc:title,upnp:class,res,dc:date,@childCount,sec:CaptionInfo,sec:CaptionInfoEx, sec:dcmInfo, sec:MetaFileInfo,res@resolution,res@size,upnp:genre,dc:date,upnp:album,res@duration,upnp:albumArtURI,res@bitrate,dc:creator, startIndex = 0, count = 30, sortCriteria =
2012-05-04 09:05:47,362 DEBUG [OnlineRepositoryDAOImpl] Retrieving list of [FEED, WEB_RESOURCE] OnlineRepositories for VIDEO
2012-05-04 09:05:47,363 DEBUG [OnlineRepositoryDAOImpl] Retrieving list of [LIVE_STREAM] OnlineRepositories for VIDEO
2012-05-04 09:05:47,365 DEBUG [VideoDeliveryEngine] Retrieving resource information for item 1000000000910001 and profile Samsung TV / player (C/D-series)
2012-05-04 09:05:47,365 DEBUG [VideoDeliveryEngine] Found Format profile for transcoded file rtsp://tv.futubox.com:1935/live/z050001.stream: MPEG_PS_PAL
2012-05-04 09:05:47,365 DEBUG [VideoDeliveryEngine] Found Format profile for transcoded file rtsp://tv.futubox.com:1935/live/z050001.stream: MPEG_PS_NTSC
2012-05-04 09:05:47,365 DEBUG [OnlineRepositoryDAOImpl] Retrieving list of [FEED, WEB_RESOURCE] OnlineRepositories for VIDEO
2012-05-04 09:05:47,367 DEBUG [OnlineRepositoryDAOImpl] Retrieving list of [LIVE_STREAM] OnlineRepositories for VIDEO
2012-05-04 09:05:47,371 DEBUG [ServiceControlRequestHandler] Returning OK SOAP message
2012-05-04 09:05:47,395 DEBUG [WebServer] Incoming connection from /10.0.0.11:44575
2012-05-04 09:05:47,396 DEBUG [ResourceTransportRequestHandler] GET /resource/1000000000910001/COVER_IMAGE HTTP/1.0, headers = [HOST: 10.0.0.4:8895,ACCEPT-LANGUAGE: en-us,getcontentFeatures.dlna.org: 1,transferMode.dlna.org: Interactive]]
2012-05-04 09:05:47,396 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 10.0.0.11
2012-05-04 09:05:47,396 DEBUG [ResourceTransportRequestHandler] Resource request accepted. Using client 'IPAddress=/10.0.0.11, Profile=Samsung TV / player (C/D-series)'
2012-05-04 09:05:47,397 DEBUG [ResourceTransportRequestHandler] Request for resource 1000000000910001 and type 'COVER_IMAGE' received
2012-05-04 09:05:47,397 DEBUG [OnlineRepositoryDAOImpl] Reading an OnlineRepository (id = 91)
2012-05-04 09:05:47,397 DEBUG [CoverImageRetrievalStrategy] Retrieving Cover image with id 1000000000910001
2012-05-04 09:05:47,397 DEBUG [ResourceTransportRequestHandler] Creating stream entity with length: 2582
2012-05-04 09:05:47,398 DEBUG [ResourceTransportRequestHandler] Sending file back
2012-05-04 09:05:47,398 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 200 OK, headers = [[Content-Type: image/jpeg,Content-Length: 2582,Date: Fri, 04 May 2012 06:05:47 GMT,Server: Windows 7, UPnP/1.0 DLNADOC/1.50, Serviio/0.6.2,Cache-control: no-cache,contentFeatures.dlna.org: DLNA.ORG_PN=JPEG_TN;DLNA.ORG_OP=00;DLNA.ORG_CI=0;DLNA.ORG_FLAGS=00D00000000000000000000000000000,transferMode.dlna.org: Interactive]]
2012-05-04 09:05:47,501 DEBUG [WebServer] Incoming connection from /10.0.0.11:44576
2012-05-04 09:05:47,501 DEBUG [UPnPIconRequestHandler] UPnP icon request received for icon smallPNG
iplem
Post Fri May 04, 2012 7:58 am
Good News.
Seems I was able to finally find a way to make it work.
After checking the logs, it comes out that it doesn't matter which Samsung profile I applied to the TV it always took from the general DLNA profile, since there was no RTSP container matches in the Samsung profiles. I copied the online transcoding from the general to the C/D section and added the maxVBitrate to it.
Now it works.
<Video targetContainer="mpeg" targetVCodec="mpeg2video" targetACodec="ac3" aBitrate="384" maxVBitrate="20000">
<Matches container="rtsp"/>
For those of you that had the same problem, try add it under your C/D profile and play with the maxVBittrate (decrease) in case you still have some issues. Also, don't forget to restart the service to be on the safe side.
Post Fri May 04, 2012 1:54 pm
It would not have used the generic profile since you have an online section in your c-d profile, which means it would have only used the flv rules in your c-d profile.
Both the stock and my profile only remux online H264.flv files, so if your D model cannot play H264.flv natively they will not work. (Note my model does play them natively but it is not documented in the manual)
Could you try this? It should transcode all local and online flv to mpeg2video. I think this is just the stock profile with just the original commented line removed.
         <!-- Transcode all h264 video with HIGH/MAIN > Level 4.1 on MPEG-TS stream with MPEG2VIDEO and ac3 audio transcoding -->
         <Video targetContainer="mpegts" targetVCodec="mpeg2video" targetACodec="ac3" aBitrate="192" maxVBitrate="20000">
            <Matches container="avi" vCodec="h264" profile="high" levelGreaterThan="4.2" />
            <Matches container="avi" vCodec="h264" profile="main" levelGreaterThan="4.2" />
            <Matches container="matroska" vCodec="h264" profile="high" levelGreaterThan="4.2" />
            <Matches container="matroska" vCodec="h264" profile="main" levelGreaterThan="4.2" />
            <Matches container="mpegts" vCodec="h264" profile="high" levelGreaterThan="4.2" />
               <Matches container="mpegts" vCodec="h264" profile="main" levelGreaterThan="4.2" />
         <!-- transcode H264 MP4 files with LPCM audio -->
            <Matches container="mpegts" aCodec="mp2" />
            <Matches container="mp4" aCodec="lpcm" />
            <Matches container="matroska" vCodec="vc1" />
            <Matches container="ogg" vCodec="mpeg4" />
            <Matches container="3gp" aCodec="amrnb" />
         <!-- transcode MKV with MPEG2 video, remux into mpeg2ts -->
         <!-- transcode AVI with AVC video -->
         <Video targetContainer="mpegts" targetACodec="ac3" targetVCodec="mpeg2video" maxVBitrate="20000">
            <Matches container="flv" />
            <Matches container="ogg" />
         <!-- For dvr-ms files force mpeg2video transcoding to fix monotone timestamps problems-->
         <Video targetContainer="mpegts" targetACodec="ac3" forceVTranscoding="true" maxVBitrate="20000">
            <Matches container="asf" vCodec="mpeg2video" />
            <Matches container="wtv" />
         <!-- transcode audio only for wmv with wmapro -->
         <Video targetContainer="asf" targetACodec="ac3" aBitrate="256">
            <Matches container="asf" aCodec="wmapro" />
            <Matches container="mp4" />
            <Matches container="flac" />
            <Matches container="adts" />
         </Audio>
      <OnlineTranscoding>
                <Matches container="applehttp" vCodec="h264"/>
         <Video targetContainer="mpegts" targetVCodec="mpeg2video" targetACodec="ac3" aBitrate="384" maxVBitrate="20000">
            <Matches container="asf" /> <!-- mms -->
      </OnlineTranscoding>
iplem
Post Fri May 04, 2012 2:43 pm
I tried but it doesn't work. As far as I understand, the streaming container is rtsp and the format is MPEG_PS_NTSC (or PAL), according to the mediaformatprofile the mime-type is mpeg, thus once I try to see the rtsp link, it looks for mpeg/rtsp match container and transcode it. Am I missing something?
Post Fri May 04, 2012 4:18 pm
No I think it will (obviously does) detect the rtsp container, but I would have expected that profile to detect the flv stream first and apply that transcode rule as it does for me. Could you try it again and send me the debug log so we can figure out why it works for me but not for you?
Post Fri May 04, 2012 4:44 pm
jhb50 wrote:It would not have used the generic profile since you have an online section in your c-d profile, which means it would have only used the flv rules in your c-d profile.
It should not be necessary to add it to c/d profile, as the generic one forces inheritance of the rtsp block (forceInheritance="true"). That way this forced transcoding config will be added to the c/d online transcoding config (with the lowest priority), and it should therefore be used.
Post Fri May 04, 2012 4:53 pm
Please clarify..if I have a local or online transcode flv rule in the c-d profile and an inherited rtsp rule in the generic..which rule will rtmp's use and which rule will rtsp's use.
I assume the rtmps will use the local or online transcode flv rule in c-d and rtsp's will use the rtsp rule in the generic, but if so why did the above use need to add the rtsp rule to c-d before it would work?
cartucho
Post Fri May 04, 2012 5:13 pm
My Samsung also play natively H264.flv (tested via USB with this file).
But I check with your C-D profile the RSS [LiveFeeds_HD_ChannelsRTSP.rss] but no luck :cry: the Codec error still pop up.
cartucho
Post Fri May 04, 2012 6:28 pm
zip wrote:It should not be necessary to add it to c/d profile, as the generic one forces inheritance of the rtsp block (forceInheritance="true"). That way this forced transcoding config will be added to the c/d online transcoding config (with the lowest priority), and it should therefore be used.
Well... I check the solution posted by by iplem (adding the rstp protocol to the Online transcode section of my C-D profile) and now works! so the forceInheritance="true" is not working right now...
Post Sat May 05, 2012 10:12 am
jhb50 wrote:Please clarify..if I have a local or online transcode flv rule in the c-d profile and an inherited rtsp rule in the generic..which rule will rtmp's use and which rule will rtsp's use.
RTSP is (in the sense of FFmpeg) a container, so it'll only be caught if you specify container="rtsp" ... therefore your flv based matchers are not invkoed. RTMP, however, is represented as flv/mp4 containers and there your flv matchers will work - just as you suggest.
From the previous logs you can see that rtsp was transcoded as defined in the Generic profile. The only difference I see is the bitrate constraint, so maybe that 'fixed' the stream for the TV. Might be related to this particular stream only though.
iplem
Post Sat May 05, 2012 6:58 pm
The reason I added under c/d profile and not under the general is because I didn't want the bitrate to be widely used, but for the specific TV only. Actually, would be interest to have a way to match not only a rtsp container but a specific link (regex), so we can fix it for some links and leave others without the bitrate.
foxmul
Post Tue May 08, 2012 8:37 pm
sorry but...
I'm a very dummy and I don' understand all this post...
I have the servo 0.6.2 and a samsung TV C series and I have problems with hd channels like that: viewtopic.php?f=41&t=5117
Does anybody helm me with easy instructions???
Thanks and sorry again...
iplem
Post Wed May 09, 2012 6:16 am
Which issues are you referring to?
The HD channels are off and on lately, so your issue might no be related to this thread
foxmul
Post Wed May 09, 2012 10:09 am
iplem wrote:Which issues are you referring to?
This one :
HD_Movies - all in 1280x720 HD.
Featuring Cinemax, Film 4, MGM , Sky Action, Sky Cinema, Sky Comedy,
Sky Drama & Romance, Sky Family, Sky Modern Greats, Sky SciFi & Horror, and Sky Thriller.
https://sites.google.com/site/serviiors ... Movies.rss
iplem
Post Wed May 09, 2012 2:18 pm
What I meant, is what kind of errors you got in your TV (codec, format, etc...) when trying the HD links
Post Wed May 09, 2012 4:18 pm
Iplem, Could we get this thread back on track please. We are attempting to find out why some D550's play rtsp and some do not.
I had asked "Could you try it again and send me the debug log so we can figure out why it works for me but not for you?" but have not had a response. Since the rtmp links are down again, I may have to revert to rtsp so you D550 owners will be SOL if we don't figure this out.
Foxmul, please post your problem in a more appropriate thread, or open a new one.
foxmul
Post Wed May 09, 2012 6:11 pm
iplem wrote:What I meant, is what kind of errors you got in your TV (codec, format, etc...) when trying the HD links
Sorry
"FILE FORMAT NOT SUPPORTED"
I tried with samsunf c/d and generic profile on servo
("rtsp://" sources work correctly)
iplem
Post Wed May 09, 2012 8:18 pm
Foxmul, this message mean that the link is not working, this is not related to this thread
Jhb50, I will rerun again once I can and take logs, my guess though, that it is related to the source distance and line quality. Thats why the bitrate seems to fix.
optimo
Post Thu May 10, 2012 2:10 pm
I have an LN40D550. I can confirm similar issues as reported by iplem and cartucho. Using iplem's solution (I only added the max bitrate to the generic profile), it seemed to correct the "codec not supported" issue. In addition, I can report that before applying the solution, under the HD Channels livefeed, I was only able to see "Home & Garden" in Serviio. After the applying the solution, the other channels became available (e.g. Animal Planet, Comedy Central, etc).
Users browsing this forum: Baidu [Spider] and 7 guests
