Instructions for testing plugins in plugins-readme.txt
wae3iejohhohZae5
Post Sat May 05, 2012 8:35 pm
Plugins usually carry a "static void main(args)" method that is used for testing whether the plugin/feed is working correctly.
It would be useful if plugins/plugins-readme.txt would carry instructions about how to run those methods for testing.
wae3iejohhohZae5
Post Sat May 05, 2012 9:10 pm
Re: Instructions for testing plugins in plugins-readme.txt
I had to use this to make it work
for x in lib/*.jar; do libpath=$x:$libpath; done; groovy -cp $libpath plugins/LiveFeeds.groovy
This is bash on Ubuntu 12.04 with the groovy package installed.
Post Sat May 05, 2012 9:53 pm
You will find the instructions in the wiki http://wiki.serviio.org/doku.php?id=servio_plugins
wae3iejohhohZae5
Post Sat May 05, 2012 10:33 pm
jhb50 wrote:You will find the instructions in the wiki http://wiki.serviio.org/doku.php?id=servio_plugins
Thanks. Maybe a link to this page should be added to the readme file.
Post Sun May 06, 2012 10:29 am
will add it, thanks
Return to Feature requests
