PS3 dts to ac3 5.1
Kryspy
Post Sun May 06, 2012 3:19 pm
PS3 dts to ac3 5.1
    What settings would I need in order to have serviio transcode dts to ac3 5.1? Specifically dvd vob files. I tried a setting but screwed up my profile xml and serviio wouldnt load.
    Thanks in advance
    Kryspy
    Post Sun May 06, 2012 6:02 pm
    Re: PS3 dts to ac3 5.1
    you have to match for aCodec dca and transcode to targetACodec ac3.
    Kryspy
    Post Sun May 06, 2012 9:04 pm
    I am not usually one to be spoonfed but where is a safe place to enter this line in the ps3 profile?
    Kryspy
    Post Sun May 06, 2012 10:26 pm
    it depends on what file type it is. You have to run ffmpeg -i on the file(s) and then work out the source/target container you want to transcode from/to.
