[SOLVED] Live video streams on Bravia KDL-40EX723 ?
FireFly
Post Sun May 06, 2012 11:46 am
I'm trying to get live video streaming working on this TV and I was wondering if anybody has got this working!
Streaming audio and video files that are stored on my PC work perfectly. However, any livestream that I add in "online sources" is not seen at all in the menu on my Bravia. If I go in the TV menu to Media > Videos > Serviio then I see all the shared files on my PC but I cannot see any live stream listed there. Also under "Bravia Internet Video" *(where BBC iPlayer etc is located) nothing shows up. I'm not sure WHERE it is supposed to show up but I cannot find it anywhere so I suppose it is just not working. (If I'm looking in the wrong place please tell me!)
Btw: I have put all the latest plugins in the plugin directory so that should be OK. Rebooted the PC, waited a long time for stuff to get organised, etc...
So I was hoping that somebody with this TV (or similar) has it working and can explain to me how it is done. Possibly with a stream and exact link to that stream so that I can reproduce that exactly. Many thanks if somebody wants to take that efford!
Cheers
Post Sun May 06, 2012 12:34 pm
Re: Live video streams on Bravia KDL-40EX723 ?
If "Bravia Internet Video" does not work, online source with serviio does not work too.
You have a internet connection problem.
try
Home -> Network Set-up -> View Network Status
Home -> Refresh Internet Content
What is your connection setup/configuration ?
FireFly
Post Sun May 06, 2012 4:20 pm
Illico wrote:If "Bravia Internet Video" does not work, online source with serviio does not work too.
try
Network status is OK and "Bravia Internet Video" works perfect. I use for example BBC iPlayer all the time. But I just don't see any live streams that I try to make available through Serviio. This is still the same also after "Refresh Internet Content".
Am I supposed to see them under "Bravia Internet Video"?
As I already mentioned, files stored on my PC stream to the Bravia flawlessly with Serviio. So internet works, Serviio communicates with Bravia, I just don't see the streams appearing. I must be overlooking something stupid....
FireFly
Post Sun May 06, 2012 5:22 pm
OK, it's working now! It appears that I was unlucky enough that none of the streams that I tried were working, even though they worked in my browser. But I have now found a few streams that work so nothing is wrong with my setup :P
Post Sun May 06, 2012 6:12 pm
Ok, enjoy now.
riiiiick
Post Fri May 25, 2012 3:01 pm
Re: [SOLVED] Live video streams on Bravia KDL-40EX723 ?
can you put up a screenshot of the live streams that are working for you? Or 1 of them, I am having a similar problem. Rss feeds work, web resource feeds work, but no live streams yet. Thanks.
