Clean or Backup log file after services restarted
Post Sun May 06, 2012 12:41 pm
Is it possible to clean, better, create an "_old.log" file when serviio services are restarted ?
Post Sun May 06, 2012 5:54 pm
Re: Clean or Backup log file after services restarted
try changing this value in log4j.xml
<param name="Append" value="true" />
to
<param name="Append" value="false" />
Post Sun May 06, 2012 6:18 pm
zip wrote:try changing this value in log4j.xml
Ok, perfect, I suggest to set "false" as default value after installation.
Post Sun May 06, 2012 6:27 pm
does it actually work? What happens with the old log?
Post Mon May 07, 2012 11:45 am
zip wrote:does it actually work? What happens with the old log?
Hum... not 100% in fact.
When service restarted, a new clean serviio.log is created but no backup is done :?
So this is not the solution.
Xmantium
Post Tue May 08, 2012 11:52 pm
Illico wrote:When service restarted, a new clean serviio.log is created but no backup is done :?
I actually prefer this on my everyday use NAS build! Thanks :)
Return to Feature requests
