playlist
giorgino
Post Wed May 02, 2012 10:05 am
playlist
I downloaded last version of serviio so I would like to know when playlist will be available. Also in which way playlist will work? For example creating a pls that have been processed by the player? In other word sho is responsible to play the songs of the playlist one after the other. DLNA has defined a specific? Thanks in advance
Post Wed May 02, 2012 10:13 am
Re: playlist
Playlists are being tested at the moment as part of the 1.0 beta testing.
They are processed by the server so will appear to the device as just a 'normal' folder e.g. Audio -> Playlists -> My Playlist will be a folder containing all of the tracks from the playlist 'My Playlist'
giorgino
Post Mon May 07, 2012 7:12 am
Re: playlist
Thank you for the answer. In other word I have only a collection of a songs everyone with his relative url, that forms a single playlist and not a file .m3u.
Having only a collection of songs in which ways I can tell a standard DLNA media renderer to play all the songs of the playlist? For what I see there isn't a way defined by the standard, but with a media controller I have to monitor when a song finish to put in the command for another song of the playlist. I said something wrong? Is there another way?
Thanks G.
Post Mon May 07, 2012 8:39 am
Re: playlist
Well it is up the device to choose to start playing the next song/video. Which device do you have? I was trying to say that if you press play in a folder at the moment and your device automatically plays the next file, then it will work just the same with playlists.
Return to Feature requests
