Samsung .WTV no sound
ianLDN
Post Tue May 08, 2012 12:50 am
I have a Samsung UE40D7000 and everything is great regarding Serviio (0.6.2) apart from .wtv files. These are created using Windows Media Center TV Recording feature
The video of these play fine but have no sound.
I have tried taking the latest stable release of ffmpeg (ffmpeg-20120503-git-c1fe2db-win64-static) and replacing this into serviio\lib but still the same problem.
Profile of the TV in Serviio is shown as 'Samsung TV / Player (C/D-series). I have tried setting this to a B series but still no sound.
running ffmpeg.exe -i I see the following error ...
[mpeg2video @ 0000000001e100a0] mpeg_decode_postinit() failure
Here's the full output....
c:\Program Files\Serviio\lib>ffmpeg.exe -i "F:\Recorded TV\Coronation Street_ITV
1_2012_05_08_20_58_00.wtv"
ffmpeg version N-40301-gc1fe2db Copyright (c) 2000-2012 the FFmpeg developers
built on May 3 2012 11:44:06 with gcc 4.6.3
configuration: --enable-gpl --enable-version3 --disable-w32threads --enable-ru
ntime-cpudetect --enable-avisynth --enable-bzlib --enable-frei0r --enable-libass
--enable-libcelt --enable-libopencore-amrnb --enable-libopencore-amrwb --enable
-libfreetype --enable-libgsm --enable-libmp3lame --enable-libnut --enable-libope
njpeg --enable-librtmp --enable-libschroedinger --enable-libspeex --enable-libth
eora --enable-libutvideo --enable-libvo-aacenc --enable-libvo-amrwbenc --enable-
libvorbis --enable-libvpx --enable-libx264 --enable-libxavs --enable-libxvid --e
nable-zlib
libavutil 51. 49.100 / 51. 49.100
libavcodec 54. 17.101 / 54. 17.101
libavformat 54. 3.100 / 54. 3.100
libavdevice 53. 4.100 / 53. 4.100
libavfilter 2. 72.104 / 2. 72.104
libswresample 0. 11.100 / 0. 11.100
Last message repeated 13 times
Input #0, wtv, from 'F:\Recorded TV\Coronation Street_ITV1_2012_05_08_20_58_00.w
tv':
WM/MediaClassPrimaryID: db9830bd-3ab3-4fab-8a371a995f7ff74
WM/MediaClassSecondaryID: ba7f258a-62f7-47a9-b21f4651c42a000
Title : Coronation Street
WM/SubTitleDescription: Terry hatches a plan to free himself of Rick. The re
ality of life with Paul begins to dawn on Eileen. Is David on a path of self-des
truction?
genre : Shows;Soap
WM/OriginalReleaseTime: 0
WM/MediaCredits : Nigel Pivaro/Greg Wood/Tony Hirst/Sue Cleaver/Jack P Sheph
erd/Chris Fountain;Alan Grint;;
service_provider: ITV1
service_name : ITV1 London
WM/MediaOriginalChannel: 3
WM/MediaOriginalChannelSubNumber: 0
WM/MediaOriginalBroadcastDateTime: 2012-05-07T23:00:00Z
WM/MediaOriginalRunTime: 20984396440
WM/MediaIsStereo: false
WM/MediaIsRepeat: false
WM/MediaIsLive : false
WM/MediaIsTape : false
WM/MediaIsDelay : false
WM/MediaIsSubtitled: false
WM/MediaIsMovie : false
WM/MediaIsPremiere: false
WM/MediaIsFinale: false
WM/MediaIsSAP : false
WM/MediaIsSport : false
WM/Provider : MediaCenterDefault
WM/VideoClosedCaptioning: false
WM/WMRVEncodeTime: 2012-05-08 19:58:01
WM/WMRVSeriesUID: !GenericSeries!Coronation Street
WM/WMRVServiceID: !Generated!b68f801ba96b45d48b2f81d7a74fad08
WM/WMRVProgramID: !MCProgram!42812975
WM/WMRVRequestID: 0
WM/WMRVScheduleItemID: 0
WM/WMRVQuality : 0
WM/WMRVOriginalSoftPrePadding: 420
WM/WMRVOriginalSoftPostPadding: 180
WM/WMRVHardPrePadding: -300
WM/WMRVHardPostPadding: 0
WM/WMRVATSCContent: false
WM/WMRVDTVContent: true
WM/WMRVHDContent: false
WM/MediaThumbType: 3
Duration : 21598699635
WM/WMRVEndTime : 2012-05-08 20:34:01
WM/WMRVBitrate : 4.038231
WM/WMRVKeepUntil: -1
WM/WMRVActualSoftPrePadding: 418
WM/WMRVActualSoftPostPadding: 180
WM/WMRVContentProtected: false
WM/WMRVContentProtectedPercent: 0
WM/WMRVExpirationSpan: 9223372036854775807
WM/WMRVInBandRatingSystem: 255
WM/WMRVInBandRatingLevel: 255
WM/WMRVInBandRatingAttributes: 0
WM/WMRVWatched : true
Duration: 00:35:59.56, start: 1.596464, bitrate: 4038 kb/s
Stream #0:0[0xbd](eng): Subtitle: dvb_subtitle
Stream #0:1[0xbe](eng): Audio: mp2 (P[0][0][0] / 0x0050), 48000 Hz, mono, s1
6, 64 kb/s (hearing impaired)
Stream #0:2[0xbf]: Video: mpeg2video (Main), yuv420p, 704x576 [SAR 16:11 DAR
16:9], 15000 kb/s, 62.50 fps, 25 tbr, 10000k tbn, 50 tbc
Stream #0:3[0xc0](eng): Audio: mp2 (P[0][0][0] / 0x0050), 48000 Hz, stereo,
s16, 192 kb/s
Stream #0:4[0x0]: Attachment: mjpeg
title : TV Thumbnail
Any ideas? Thanks
Ian
ianLDN
Post Sun May 13, 2012 12:41 am
Re: Samsung .WTV no sound
I have been investigating this a little and I have found that if I set the following
<Video targetContainer="mpegts" targetACodec="ac3" targetVCodec="mpeg2video" forceVTranscoding="true">
<Matches container="wtv" />
then SOME .wtv files are transcoded correctly. This is very strange as the source of the .wtv files is the same? For the files that do not transcode; I see a 'File Type Not Supported' error on the TV and in the serviio.log file I see this error.
2012-05-13 01:29:36,854 WARN [ProcessExecutor] Process cmd has a return code of 255! This is a possible error.
2012-05-13 01:29:42,346 ERROR [ResourceTransportRequestHandler] Error while processing resource, sending back 500 error. Message: FFmpeg execution failed
at org.serviio.delivery.resource.transcode.FileBasedTranscodingDeliveryStrategy.createInputStream(FileBasedTranscodingDeliveryStrategy.java:47)
at org.serviio.delivery.resource.transcode.AbstractTranscodingDeliveryEngine.retrieveTranscodedResource(AbstractTranscodingDeliveryEngine.java:129)
at org.serviio.delivery.resource.AbstractDeliveryEngine.deliver(AbstractDeliveryEngine.java:96)
at org.serviio.delivery.MediaResourceRetrievalStrategy.retrieveResource(MediaResourceRetrievalStrategy.java:121)
at org.serviio.upnp.webserver.ResourceTransportRequestHandler.handleRequest(ResourceTransportRequestHandler.java:116)
Ideally I don't want to use transcoding as I'm sure that Serviio supports .wtv
To add to my confusion I have also tried the following config
<Video targetContainer="mpegts" targetACodec="ac3" targetVCodec="mpeg2video" >
so no transcoding and again SOME files will play - others again are failing with 'Unsupported File Type'. Again ALL files are created by Windows Media Center on the same PC using the same TV card.
Any explanation as to why some play and others don't would be appreciated. File size is comparable between working and non-working files.
Ian
Post Sun May 13, 2012 6:43 pm
wtv can't be played natively by the Samsung, so you'll have to transcode. Both your examples set transcoding to mpeg2video anyway.
