FFmpeg for noobs like me
smifft
Post Tue Apr 24, 2012 11:56 pm
Re: FFmpeg for noobs like me
First off let me just say that I am a recent convert from TVersity and I am LOVING Serviio. Kudos on an amazing application. Now on to my issue, I am having no luck playing a few of my .mp4 files. Here is one in particular:
C:\Program Files\Serviio\lib>ffmpeg.exe -i "F:\Movies\Alien Anthology\1992 Alien III.mp4"
configuration: --enable-static --disable-shared --disable-ffplay --disable-ffserver --enable-memalign-hack --enable-libmp3lame --enable-librtmp --extra-libs='-lrtmp -lpolarssl -l
ws2_32 -lwinmm' --arch=x86 --enable-runtime-cpudetect --enable-pthreads --target-os=mingw32 --cross-prefix=i686-mingw32- --pkg-config=pkg-config
libavutil 51. 32. 0 / 51. 32. 0
libavcodec 53. 42. 0 / 53. 42. 0
libavformat 53. 24. 0 / 53. 24. 0
libavdevice 53. 4. 0 / 53. 4. 0
libavfilter 2. 53. 0 / 2. 53. 0
libswscale 2. 1. 0 / 2. 1. 0
Seems stream 0 codec frame rate differs from container frame rate: 47.95 (5000000/104271) -> 23.98 (24000/1001)
Input #0, mov,mp4,m4a,3gp,3g2,mj2, from 'F:\Movies\Alien Anthology\1992 Alien III.mp4':
major_brand : isom
minor_version : 1
compatible_brands: isomavc1
creation_time : 2011-02-11 09:32:27
Duration: 02:24:52.86, start: 0.000000, bitrate: 1837 kb/s
Stream #0:0(und): Video: h264 (High) (avc1 / 0x31637661), yuv420p, 1920x816 [SAR 1:1 DAR 40:17], 1436 kb/s, 23.98 fps, 23.98 tbr, 24k tbn, 47.95 tbc
handler_name : GPAC ISO Video Handler
Stream #0:1(eng): Audio: aac (mp4a / 0x6134706D), 48000 Hz, 5.1, s16, 397 kb/s
creation_time : 2011-02-11 09:33:15
handler_name : GPAC ISO Audio Handler
Any help with this issue will be appreciated. Oh, and this is on Win7 Home Premium x64 , streaming to an XBOX360.
Post Wed Apr 25, 2012 11:35 am
Could you also provide MediaInfotools result of this movie (in text format) ?
smifft
Post Wed Apr 25, 2012 2:20 pm
Illico wrote:Could you also provide MediaInfotools result of this movie (in text format) ?
Complete name : F:\Movies\Alien Anthology\1992 Alien III.mp4
Format : MPEG-4
Format profile : Base Media
Codec ID : isom
File size : 1.86 GiB
Duration : 2h 24mn
Overall bit rate : 1 837 Kbps
Encoded date : UTC 2011-02-11 09:32:27
Tagged date : UTC 2011-02-11 09:32:27
Format : AVC
Format profile : High@L4.0
Format settings, CABAC : Yes
Codec ID : avc1
Codec ID/Info : Advanced Video Coding
Duration : 2h 24mn
Bit rate : 1 437 Kbps
Maximum bit rate : 13.1 Mbps
Width : 1 920 pixels
Height : 816 pixels
Display aspect ratio : 2.35:1
Frame rate mode : Constant
Frame rate : 23.976 fps
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Progressive
Bits/(Pixel*Frame) : 0.038
Stream size : 1.45 GiB (78%)
Writing library : FASM Quality Enhancer Bitrate Squeezer 3.4 (c)2010 Fachman
Tagged date : UTC 2011-02-11 09:33:27
Color primaries : BT.709-5, BT.1361, IEC 61966-2-4, SMPTE RP177
Transfer characteristics : BT.709-5, BT.1361
Matrix coefficients : BT.709-5, BT.1361, IEC 61966-2-4 709, SMPTE RP177
Format : AAC
Format profile : LC
Codec ID : 40
Duration : 2h 24mn
Bit rate mode : Variable
Bit rate : 397 Kbps
Maximum bit rate : 455 Kbps
Channel(s) : 6 channels
Sampling rate : 48.0 KHz
Compression mode : Lossy
Delay relative to video : -3s 337ms
Stream size : 411 MiB (22%)
Language : English
Encoded date : UTC 2011-02-11 09:33:15
smifft
Post Tue May 08, 2012 9:12 pm
So after hours and hours or research it appears that the issue the container holding the data streams. I stumbled across : http://blogs.msdn.com/b/xboxteam/archiv ... k-faq.aspx . So my understanding is that ffmpeg is the underlying issue in regards to transcoding the audio to a suitable ?codec? for the Xbox to play. I thought that perhaps the newest ffmpeg would include that functionality,but it's just a presumption. Why can't I code the Xbox serviio profile to transcode the file to an AVI with ac3 audio? According to that Microsoft site, that should do the trick. I'm sure I'm missing something here. Please feel free to enlighten me.
Post Thu May 10, 2012 8:02 pm
avi is not suitable container for on-the-fly transcoding (file being written to while playing)
antl
Post Tue May 29, 2012 8:22 pm
cant play xvids ?
C:\Program Files\Serviio\lib>ffmpeg -i "C:\backup stuff\Movies\How To Train Your
Dragon (2010) DVDRip XviD AC3-DMZ.avi"
nfig
Seems stream 0 codec frame rate differs from container frame rate: 23.98 (65535/
2733) -> 23.98 (2500000/104271)
Input #0, avi, from 'C:\backup stuff\Movies\How To Train Your Dragon (2010) DVDR
ip XviD AC3-DMZ.avi':
encoder : AVI-Mux GUI 1.17.8.3, Feb 16 201019:42:50
JUNK :
Duration: 01:37:51.04, start: 0.000000, bitrate: 1059 kb/s
Stream #0:0: Video: mpeg4 (Advanced Simple Profile) (XVID / 0x44495658), yuv
420p, 720x304 [SAR 1:1 DAR 45:19], 23.98 tbr, 23.98 tbn, 23.98 tbc
Stream #0:1: Audio: ac3 ([0] [0][0] / 0x2000), 48000 Hz, stereo, s16, 192 kb
/s
title : T2_Audio - 5.1 channels_new
Post Wed May 30, 2012 11:14 am
locking this topic, it's intended to help people use FFMpeg. Post your playback problems in new topics.
Previous
Users browsing this forum: No registered users and 64 guests
